• Hardware Platform (both Jetson and GPU)
• DeepStream Version: 6.1.1
• JetPack Version (5.0.2)
• TensorRT Version 8.4
• NVIDIA GPU Driver Version (515)
• Issue Type: questions
Hi, with a created cuda stream, what is intuitive way to use NvBufSurfTransform API with created cuda stream. I can not understand NvBufSurfTransformSetSessionParams function and how it can affect subsequence NvBufSurfTransform and NvBufSurfTransformAsync call
Please describe your use case and the complete information as applicable to your setup.
• TensorRT Version
• The pipeline being used
You can use NvBufSurfTransformSetSessionParams API to create a session with your own config paras. The NvBufSurfTransform module use this session to implement the related logic. But the session is an internal structure so
it is unnecessary for custom to concern its realization.
Hi, what if I want to use multiple sessions to call NvBufSurfTransform at parallel threads. How NvBufSurfTransform know which session to use when that is not pass directly as function parameters
So, as long as I call NvBufSurfTransformSetSessionParams in the same thread with NvBufSurfTransform, the behaviour is guaranteed?
A bit aside, NvBufSurfTransform with custom session means that the work is done on the specified CUDA stream and the stream is synchronized at the end of the function call. Am I correct?
Yes. You can open a new topic at any time when you encounter specific problems in your actual development.
