Nvc++ generating 1-dimension grid exactly the number of SMs, causing low performance
I am trying to offload a CPU winograd convolution implemented formerly in OpenMP.
The compiler is nvhpc@23.9.
Here is the code ( a naive batched gem for example)
void sgemm_batched(const int64_t batch_size,
                   const int64_t M,
                   const int64_t N,
                   const int64_t K,
                   float *A,
                   float *B,
                   float *C) {
  typedef float(*A_tensor_t)[M][K];
  typedef float(*B_tensor_t)[N][K];
  typedef float(*C_tensor_t)[N][M];
  A_tensor_t A_tensor = (A_tensor_t)A;
  B_tensor_t B_tensor = (B_tensor_t)B;
  C_tensor_t C_tensor = (C_tensor_t)C;
#pragma omp target
#pragma omp parallel for collapse(3)
#pragma acc parallel loop collapse(3)
  for (int64_t batch = 0; batch < batch_size; ++batch) {
    for (int64_t m = 0; m < M; ++m) {
      for (int64_t n = 0; n < N; ++n) {
        C_tensor[batch][n][m] = 0;
        for (int64_t k = 0; k < K; ++k) {
          C_tensor[batch][n][m] += A_tensor[batch][m][k] * B_tensor[batch][n][k];
The makefile (I am notice on the similarity between OpenAcc and OpenMP , so I put their directives together.):
OMP_FLAG = -O3 -g -Wall -mp=gpu,multicore -gpu=cc89,managed -std=c++17 -Minfo=mp
ACC_FLAG = -O1 -g -Wall -acc=gpu,multicore -gpu=cc89,managed,time -std=c++17 -Minfo=acc
# Also , -O3 causes panic during optimization(appears on both nvhpc 23.9 and 24.3), I disabled it
# message: /.../.../24.3/compilers/share/llvm/bin/opt: /tmp/nvc++3hqDdLpcQBm_0.ll:809:23: error: use of undefined value '%_T2_6083.addr'
#                   %178 = load i64, ptr %_T2_6083.addr, align 8, !tbaa !925, !dbg !997
CXX=nvc++
omp:
	${CXX} driver.cc winograd.cc ${OMP_FLAG} -o winograd
acc:
	${CXX} driver.cc winograd.cc ${ACC_FLAG} -o winograd
The GPU is a L40, here is a output of nvaccelinfo
CUDA Driver Version:           12060
NVRM version:                  NVIDIA UNIX x86_64 Kernel Module  560.35.03  Fri Aug 16 21:39:15 UTC 2024
Device Number:                 0
Device Name:                   NVIDIA L40
Device Revision Number:        8.9
Global Memory Size:            47929425920
Number of Multiprocessors:     142
Concurrent Copy and Execution: Yes
Total Constant Memory:         65536
Total Shared Memory per Block: 49152
Registers per Block:           65536
Warp Size:                     32
Maximum Threads per Block:     1024
Maximum Block Dimensions:      1024, 1024, 64
Maximum Grid Dimensions:       2147483647 x 65535 x 65535
Maximum Memory Pitch:          2147483647B
Texture Alignment:             512B
Clock Rate:                    2490 MHz
Execution Timeout:             No
Integrated Device:             No
Can Map Host Memory:           Yes
Compute Mode:                  default
Concurrent Kernels:            Yes
ECC Enabled:                   Yes
Memory Clock Rate:             9001 MHz
Memory Bus Width:              384 bits
L2 Cache Size:                 100663296 bytes
Max Threads Per SMP:           1536
Async Engines:                 2
Unified Addressing:            Yes
Managed Memory:                Yes
Concurrent Managed Memory:     Yes
Preemption Supported:          Yes
Cooperative Launch:            Yes
Default Target:                cc89
The build command : make omp.
The problem: I found it quite slow, so i use nsys profile. The grid sizes of all kernels are (142,1,1), exactly , the same as the number of SMs of L40 (142).
That caused a low occupancy, shown in the section of ncu output below:
    Section: Occupancy
    Metric Name                     Metric Unit Metric Value
    Block Limit SM                        block           24
    Block Limit Registers                 block           10
    Block Limit Shared Mem                block           24
    Block Limit Warps                     block           12
    Theoretical Active Warps per SM        warp           40
    Theoretical Occupancy                     %        83.33
    Achieved Occupancy                        %         8.32
    Achieved Active Warps Per SM           warp         3.99
How can I fix this? Thanks for responses!
My best guess is that it’s due to “teams distribute” missing.
Try
#pragma omp target teams distribute parallel for collapse(3)
or use the “loop” construct:
#pragma omp target teams loop collapse(3)
Thank you, it works for me.
                   const int64_t M,
                   const int64_t N,
                   const int64_t K,
                   float *A,
                   float *B,
                   float *C) {
