Hello everyone,
if I compile the following code with nvc++ segfaulttest.cpp -O2 -o segfaulttest
and execute it, it first prints the address of the pointer (as expected) and then gives a segmentation fault.
#include <complex>
#include <iostream>
int main(){
int size = 150000000;
auto pointer = (std::complex<double> *) malloc(size * sizeof(std::complex<double>));
// Make sure that allocation worked
if (pointer)
std::cout << pointer << std::endl;
for (int ind =0; ind < size; ++ind)
pointer[ind] *= 5.;
free(pointer);
return 0;
Any of the following actions resolves the issue:
- change nvc++ to g++
- reduce the optimization level to -O0 or -O1 (the problem occurs at -O2 and -O3)
- reduce the parameter
size
to less than about 130 million - print the index every now and then, e.g. by adding
if (ind % 1000000 == 0) std::cout << ind << std::endl;
to thefor
loop - write out the
operator aspointer[ind] = pointer[ind] * 5.;
, this was particularly surprising for me.
I tried it out on an Ubuntu 22.04 with HPC SDK version 22.9 and on a WSL2 Ubuntu 20.04 with HPC SDK version 22.5. Both show the same behavior.
Kind regards,
Simon
