Hi All,
Thought I would post here before taking the device back to have it replaced, as something is bugged out. The flashing of 3.2 seemed fine. When cloning the jetson-inference tutorial and running anything that uses the onboard camera, all that is output is a green screen, followed by an internal system error indicating nvcamera-daemon crashed. It keeps having over and over and Ive spend upwards of 40 hours flashing this damn thing, just for the same result. The last time i used 3.1 hoping that would help, but no same exact result. nvcamera-daemon just crashes.
Now i am far from an expert on this, (yet), but here are the facts that I know for 100% certain:
- We purchased a tx2 at work, flashed it with the 3.2 dev version before prod came out.
- jetson-inference tutorials ran fine
- I got one at home to test outside of work
- Flashed exactly the same as the work one
- nvcamera-daemon crashed with SEGENV or segmentation faults over and over and over…
So im guessing the problem is either with this hardware i received or something else as these tutorials should just work, is there anything i can perhaps try before going crazy and tossing it out the window?
from journalctl -fu nvcamera-daemon:
Mar 11 02:00:24 tegra-ubuntu nvcamera-daemon[1881]: Started nvcamera daemon…
Mar 11 02:00:24 tegra-ubuntu nvcamera-daemon[1881]: nvcamera-daemon listening for clients to connect…
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: nvcamera-daemon started new client thread = 547668828640
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) USB Sensors : 0 CSI Sensors : 1
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) getSource successful
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: Available Sensor modes :
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: W= 2592 H= 1944 FR= 30.000000
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: W= 2592 H= 1458 FR= 30.000000
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: W= 1280 H= 720 FR= 120.000000
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) CreateSession Successful
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) Shared Memory: mmap address= 0x7f6c514000
Mar 11 02:02:23 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) Sensor Metadata: Available : 0 Sensor Metadata: W : 2592 Sensor Metadata: H : 0
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) New Resolution W = 2592 H = 1458
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 91
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 92
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 94
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 95
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 97
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 98
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 100
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 101
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 103
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 104
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 106
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 107
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 109
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 110
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 112
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 113
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 115
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 116
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_BAYER fd = 118
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: RECEIVED REGISTER_BUFFER_META fd = 119
Mar 11 02:02:24 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) REQ_NVCAM_ENABLE_METADATA Enabled=0
Mar 11 02:02:25 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) Error in calling capture= 3 result= 5
…(hundreds of these line before finally crashing)…
Mar 11 02:02:42 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) Error in calling capture= 3 result= 5
Mar 11 02:02:42 tegra-ubuntu nvcamera-daemon[1881]: (547668828640) Closing Client Connection Thread: nbytes 0
Mar 11 02:02:47 tegra-ubuntu systemd[1]: nvcamera-daemon.service: Main process exited, code=killed, status=11/SEGV
Mar 11 02:02:49 tegra-ubuntu systemd[1]: nvcamera-daemon.service: Unit entered failed state.
Mar 11 02:02:49 tegra-ubuntu systemd[1]: nvcamera-daemon.service: Failed with result ‘signal’.
Mar 11 02:02:49 tegra-ubuntu systemd[1]: nvcamera-daemon.service: Service hold-off time over, scheduling restart.
Mar 11 02:02:49 tegra-ubuntu systemd[1]: Stopped nvcamera daemon.
Mar 11 02:02:49 tegra-ubuntu systemd[1]: Started nvcamera daemon.
Mar 11 02:02:49 tegra-ubuntu nvcamera-daemon[1982]: Started nvcamera daemon…
Mar 11 02:02:49 tegra-ubuntu nvcamera-daemon[1982]: nvcamera-daemon listening for clients to connect.
