I’ve installed arm64v8/ubuntu:16.04 and all the dependencies on the Jetson TX2.
When trying to get the camera feed from OpenCV, the gstreamer plugin “nvcamerasrc” is not found. How can I install it please?
Thanks,
Brice
Thanks,
Brice
Have you installed a L4T(Linux for Tegra) version ? What gives? :
head -n 1 /etc/nv_tegra_release
For checking your install, you may also check the result of:
sha1sum -c /etc/nv_tegra_release
For using gstreamer plugin nvcamerasrc, in the output of previous command you should see:
/usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so: OK
and further have library
/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcamera.so
I haven’t installed L4T, just the drivers.
I have
but not
I found the gstreamer plugin, was in the nv_sample_apps folder in the driver package
