nvcamerasrc query
We will be connecting YUV sensor to TX1. So Bayer processing in ISP is not required.
Still We would like to use nvcamerasrc instead of v4l2src. This is because of its better performance.
As we are going to use nvcamerasrc in bypass mode kind of thing… Is ISP configuration for this YUV sensor required by TX1 ??
Palani
I think in any case nvcamerasrc will try to use the camera daemon and therefore the ISP. The performance should be similar actually if you use v4l2src it would imagine the overhead is less because the frame goes directly to memory. What difference in performance are you seeing? are you using tegrastats to measure the ARM load?
If you need help creating the driver let me know.
