I ran into the following assertion error when I tried to compile my code:
Assertion failure at line 1543 of …/…/be/cg/cgemit.cxx:
Compiler Error in file /tmp/tmpxft_00002b38_00000000-7_testPA.cpp3.i during Assembly phase:
incorrect register class for operand 0
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be returned non-zero status 1
I tried both NVCC 2.1 for Fedora9_x86_64 and EL5_x86, both with the same error.
Compile option:
NVCC testPA.cu -arch=compute_13
The code is as follows:
// PA.h
#ifndef PA_H
#define PA_H
#include <cuda.h>
namespace MACU{
typedef unsigned int uint32;
typedef int int32;
typedef unsigned long long uint64;
struct __align__(8) BlockListHeadDesc{
int32 first_avail:32;
uint64 tag:32;
struct BlockList{
BlockListHeadDesc head_desc;
__device__ int32 pop();
struct Superblock{
BlockList avail_list;
__device__ void * get_block();
__device__ int32 BlockList::pop(){
BlockListHeadDesc new_desc,old_desc;
while(1){
new_desc=old_desc=head_desc;
if(old_desc.first_avail==-1)
return -1;
new_desc.tag++;
if(*(uint64*)&old_desc==atomicCAS((uint64*)&head_desc,*(uint64*)&old_desc,*(uint64*)&new_desc))
return 0;
__device__ void * Superblock::get_block(){
while(1){
uint32 block_num=avail_list.pop();
return NULL;
#endif
// testPA.cu
#include “PA.h”
#include <cuda.h>
#include <stdio.h>
using namespace MACU;
global void foo(int * arr){
Superblock * sb=(Superblock *)(NULL);
void * p=sb->get_block();
int main(){
return 0;
PA.h (905 Bytes)
