I am implementing a CUDA kernel for a 12x12 (complex) matrix inversion by LDL_dag decomposition.
The code is production proven to work by verfication on CPU architectures.
Right now I have a strange behaviour where my conclusion at the moment is a possible bug in NVCC compiler chain?
I reproduced the error with a reduced setup. Sorry for the 280 lines.
With CUDA 4.2 if I compile it with
nvcc -arch sm_20 -o main main.cu
and run it on a Fermi card on Linux 64 I get:
kernel call: unspecified launch failure
In the kernel body there is a #if switch. If I set it to #if 0 (thus the alternate if-block get used) the error disappears. But the code executed should be the same/equivalent in either case. (hasOrderedRep is true!!)
#include "cuda.h"
#include "stdio.h"
#include <iostream>
using namespace std;
// First some basic types I need
// Implementation of a templated
// scalar and complex number
template<class T> class RScalar
public:
__device__ RScalar() {}
__device__ ~RScalar() {}
template<class T1> __device__
RScalar(const RScalar<T1>& rhs) : F(rhs.elem()) {}
RScalar(const T1& rhs) : F(rhs) {}
template<class T1> __device__ inline
RScalar& operator=(const RScalar<T1>& rhs) {
elem() = rhs.elem();
return *this;
public:
__device__ T& elem() {return F;}
__device__ const T& elem() const {return F;}
private:
T F;
template<class T> class RComplex
public:
__device__ RComplex() {}
__device__ ~RComplex() {}
template<class T1, class T2> __device__
RComplex(const RScalar<T1>& _re, const RScalar<T2>& _im):
re(_re.elem()), im(_im.elem()) {}
RComplex(const T1& _re, const T2& _im): re(_re), im(_im) {}
RComplex(const T1& _re): re(_re), im() {}
template<class T1>
__device__ inline
RComplex& operator*=(const RScalar<T1>& rhs)
real() *= rhs.elem();
imag() *= rhs.elem();
return *this;
template<class T1>
__device__ inline
RComplex& operator-=(const RComplex<T1>& rhs)
real() -= rhs.real();
imag() -= rhs.imag();
return *this;
RComplex& operator/=(const RComplex<T1>& rhs)
RComplex<T> d;
d = *this / rhs;
real() = d.real();
imag() = d.imag();
return *this;
public:
__device__ T& real() {return re;}
__device__ const T& real() const {return re;}
__device__ T& imag() {return im;}
__device__ const T& imag() const {return im;}
private:
T re;
T im;
template<class T> __device__ RComplex<T>
operator*(const RComplex<T>& __restrict__ l,
const RComplex<T>& __restrict__ r)
return RComplex<T>(l.real()*r.real() - l.imag()*r.imag(),
l.real()*r.imag() + l.imag()*r.real());
operator/(const RComplex<T>& l, const RComplex<T>& r)
T tmp = T(1.0) / (r.real()*r.real() + r.imag()*r.imag());
return RComplex<T>((l.real()*r.real() + l.imag()*r.imag()) * tmp,
(l.imag()*r.real() - l.real()*r.imag()) * tmp);
operator*(const RComplex<T>& l, const RScalar<T>& r)
return RComplex<T>(l.real()*r.elem(),
l.imag()*r.elem());
#define REALT float
#define Nc 3
struct PrimitiveClovTriang
RScalar<REALT> diag[2][2*Nc];
RComplex<REALT> offd[2][2*Nc*Nc-Nc];
__global__ void kernel(bool hasOrderedRep, int * siteTable,
PrimitiveClovTriang* tri)
RScalar<REALT> zip=0;
int N = 2*Nc;
int site;
// First basic block results in an error,
// second, runs fine! Since hasOrderedRep
// is true, the code blocks should be
// identical.
#if 1
if (hasOrderedRep) {
site = blockDim.x * blockIdx.x +
blockDim.x * gridDim.x * blockIdx.y +
threadIdx.x;
} else {
int idx0 = blockDim.x * blockIdx.x +
threadIdx.x;
site = ((int*)(siteTable))[idx0];
#else
site = blockDim.x * blockIdx.x + blockDim.x * gridDim.x * blockIdx.y + threadIdx.x;
#endif
int site_neg_logdet=0;
for(int block=0; block < 2; block++) {
RScalar<REALT> inv_d[6];
RComplex<REALT> inv_offd[15];
RComplex<REALT> v[6];
RScalar<REALT> diag_g[6];
for(int i=0; i < N; i++) {
inv_d[i] = tri[site].diag[block][i];
for(int i=0; i < 15; i++) {
inv_offd[i] =tri[site].offd[block][i];
for(int j=0; j < N; ++j) {
for(int i=0; i < j; i++) {
int elem_ji = j*(j-1)/2 + i;
RComplex<REALT> A_ii = RComplex<REALT>( inv_d[i], zip );
v[i] = A_ii*RComplex<REALT>(inv_offd[elem_ji].real(),-inv_offd[elem_ji].imag());
v[j] = RComplex<REALT>(inv_d[j],zip);
for(int k=0; k < j; k++) {
int elem_jk = j*(j-1)/2 + k;
v[j] -= inv_offd[elem_jk]*v[k];
inv_d[j].elem() = v[j].real();
for(int k=j+1; k < N; k++) {
int elem_kj = k*(k-1)/2 + j;
for(int l=0; l < j; l++) {
int elem_kl = k*(k-1)/2 + l;
inv_offd[elem_kj] -= inv_offd[elem_kl] * v[l];
inv_offd[elem_kj] /= v[j];
RScalar<REALT> one;
one.elem() = (REALT)1;
diag_g[i].elem() = one.elem()/inv_d[i].elem();
// ((PScalar<PScalar<RScalar<float> > > *)(args->dev_ptr[ 1 ] ))[site] .elem().elem().elem() += log(fabs(inv_d[i].elem()));
if( inv_d[i].elem() < 0 ) {
site_neg_logdet++;
RComplex<REALT> sum;
for(int k = 0; k < N; ++k) {
for(int i = 0; i < k; ++i) {
v[i].real()=v[i].imag()=0;
v[k] = RComplex<REALT>(diag_g[k],zip);
for(int i = k+1; i < N; ++i) {
for(int j = k; j < i; ++j) {
int elem_ij = i*(i-1)/2+j;
v[i] -= inv_offd[elem_ij] *inv_d[j]*v[j];
v[i] *= diag_g[i];
for(int i = N-2; (int)i >= (int)k; --i) {
for(int j = i+1; j < N; ++j) {
v[i] -= RComplex<REALT>(inv_offd[elem_ji].real(),-inv_offd[elem_ji].imag()) * v[j];
inv_d[k].elem() = v[k].real();
int elem_ik = i*(i-1)/2+k;
inv_offd[elem_ik] = v[i];
tri[site].diag[block][i] = inv_d[i];
tri[site].offd[block][i] = inv_offd[i];
if( site_neg_logdet != 0 ) {
int main()
int sites=1;
dim3 blocksPerGrid( 1 , 1 , 1 );
dim3 threadsPerBlock( sites , 1, 1);
PrimitiveClovTriang* tri_dev;
int * siteTable;
cudaMalloc( (void**)&tri_dev , sizeof(PrimitiveClovTriang) * sites );
cudaMalloc( (void**)&siteTable , sizeof(int) * sites );
bool ord=true;
kernel<<< blocksPerGrid , threadsPerBlock , 0 >>>( ord , siteTable , tri_dev );
cudaDeviceSynchronize();
cudaError_t kernel_call = cudaGetLastError();
cout << "kernel call: " << string(cudaGetErrorString(kernel_call)) << endl;
cudaFree(tri_dev);
cudaFree(siteTable);
return(0);
Update:
Just tried on a different machine which has CUDA 4.0 installed. There the error does not appear (same Fermi card model). Might be really a NVCC bug of CUDA 4.2. Since they switched to LLVM from CUDA 4.1 this is likely to be a bug in the new compiler suite.
