Nvcc command not found in deepstream container
**• Hardware Platform: GPU
**• DeepStream Version5.1
**• TensorRT Version7.2.2.3
Hi all.
In my deepstream container(nvcr.io/nvidia/deepstream:5.1-21.02-samples), I have cuda-11-1
I added the cuda path to $PATH and $LD_LIBRARY_PATH variables. but the nvcc command is not found.
I want to install pycuda, since it doesn’t have nvcc (cuda compiler driver) it failed to install the pycuda.
What can I do?
any help would be appreciated
Hey which deepstream container are u using? I can found the nvcc in nvcr.io/nvidia/deepstream:5.1-21.02-devel
root@p4station:/opt/nvidia/deepstream/deepstream-5.1# which nvcc
/usr/local/cuda/bin/nvcc
when I cd to this path
bash: cd: /usr/local/cuda/bin/: No such file or directory
or this:
bash: cd: /usr/local/cuda-11-1/bin/: No such file or directory
I got this error.
the name of my docker container is : nvcr.io/nvidia/deepstream:5.1-21.02-samples
any solution?
I think it should be a setup issue, could you follow Quickstart Guide — DeepStream 6.1.1 Release documentation
