I can’t for the life of me build some binaries for Jetson.
Here are my settings:
on the host machine I have Ubuntu 14.04 and I use Nsight Eclipse Edition with the CUDA Toolkit 6.5 toolchain
my target system CPU Architecture is set to ARM
I build with the following compiler settings: nvcc -std=c++11 -mfloat-abi=softfp -mfpu=neon
No matter what I try, when I include arm_neon.h I always get the error “You must enable NEON instructions (e.g. -mfloat-abi=softfp -mfpu=neon) to use arm_neon.h”
Probably, you get more information of the compilation error by added “-v” option(nvcc verbose output).
Is it possible to provide a sample code here to exhibit this problem?
