nvcc compiler: auto convert clamp to branchless select?
Conditional statements such as:
int  i;
if( i < 0 ) i = 0;
can be written as branchless code:
int  i, sel;
sel  =  - (i > 0 );
      i    =  i & sel;
The same is true for other conditional statements such as:
int    i, i_max;
      float  f, f_max;
if( i > i_max ) i = i_max;
if( f < 0.0f )  f = 0.0f;
if( f > f_max ) f = f_max;
Question: Does the nvcc compiler automatically convert such conditionals into branchless statements?
Yes it does. It uses a SETP and then a predicated MOV, which actually has a higher throughput than the bitwise AND.
