I have looked all over the place for a solution to this problem. This means there are two equally likely possibilities. Either this problem is tricky or really obvious. If it’s the second one, bear with me.
Ok, so I go to compile my beautifully written CUDA code. To my horror I get the message that the CUDA types I use all have incomplete type, or that their storage size of unknown. See for yourself:
This example code:
#line 2
// Common functions, such as initialization and freeing.
#ifndef EXAMPLE_C
#define EXAMPLE_C
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include "matrix_types.h"
// Reporting and diagnostic functions.
#define REPORT_FAILURE(__DEATH_MESSAGE__) printf("%s.%d : FAILURE : %s\n", __FILE__, __LINE__, __DEATH_MESSAGE__);exit(-1);
void reportcudaProperties(char * return_string, int dev)
// Compiler says:
// error: storage size of ‘properties’ isn’t known
struct cudaDeviceProp properties;
cudaGetDeviceProperties(&properties, dev);
sprintf(return_string, "Device Name : %s\n", properties.name);
sprintf(return_string, "Total Global Memory (bytes) : %d\n", properties.totalGlobalMem);
sprintf(return_string, "Shared Memory per Block (bytes) : %d\n", properties.sharedMemPerBlock);
sprintf(return_string, "Total Multiprocessors : %d\n", properties.multiProcessorCount);
sprintf(return_string, "Registers Per Block : %d\n", properties.regsPerBlock);
sprintf(return_string, "Warp Size : %d\n", properties.warpSize);
sprintf(return_string, "Maximum Pitch (bytes) : %d\n", properties.memPitch);
sprintf(return_string, "Maximum Threads per Block : %d\n", properties.maxThreadsPerBlock);
sprintf(return_string, "Max Block Dimensions (x,y,z) : (%d,%d,%d) \n",
properties.maxThreadsDim[0],
properties.maxThreadsDim[1],
properties.maxThreadsDim[2]);
sprintf(return_string, "Max. Grid Size (x,y,z) : (%d,%d,%d) \n",
properties.maxGridSize[0],
properties.maxGridSize[1],
properties.maxGridSize[2]);
sprintf(return_string, "Total Constant Memory (bytes) : %d\n", properties.totalConstMem);
sprintf(return_string, "Compute Capability : %d.%d\n",
properties.major, properties.minor);
sprintf(return_string, "Clock Rate (Kilohertz) : %d\n", properties.clockrate);
sprintf(return_string, "Texture Alignment : %d\n", properties.textureAlignment);
sprintf(return_string, "Can copy memory during kernel execution ?\n----> %s",
(properties.deviceOverlap == 1 ? "yes" : "no"));
// Initialize a matrix into device memory memory.
matrix_error_t matrix_int_init(matrix_int * ret_matrix,
int rows,
int cols)
if ((rows <= 0) || (cols <= 0)) {
REPORT_FAILURE("Improper matrix dimensions");
// Allocate a cudaMatrix on the device.
size_t pitch;
struct cudaError_t error_code = cudaMallocPitch((void **) &(ret_matrix->contents), &pitch,
sizeof(int) * rows, cols);
if (error_code != cudaSuccess) {
REPORT_ERROR(cudaGetErrorString(error_code));
ret_matrix->rows = rows;
ret_matrix->cols = cols;
ret_matrix->pitch = pitch;
#endif // EXAMPLE_C
Generates the following errors:
$ nvcc example.c
example.c: In function ‘reportcudaProperties’:
example.c:33: error: storage size of ‘properties’ isn’t known
example.c: In function ‘matrix_int_init’:
example.c:73: error: variable ‘error_code’ has initializer but incomplete type
example.c:73: error: storage size of ‘error_code’ isn’t known
example.c:76: error: ‘cudaSuccess’ undeclared (first use in this function)
example.c:76: error: (Each undeclared identifier is reported only once
example.c:76: error: for each function it appears in.)
I doubt it’s something on the end of the CUDA developer, but this i something one might expect to see when a type is declared as extern…
Any ideas?
