nvcc crashes during compilation
I have the following configuration:
    GeForce GTS 250
    Windows 7
    CUDA Toolkit 4.0
    GPU Computing SDK 4.0
    MS Visual C++ Express 2010
I write a simple program and save it in cuda.cu:
#include <stdio.h>
__global__ void kernel()
int main()
	kernel <<<1,1>>>();
	printf("Hello, world!!!");
	return 0;
Then I launch the compiler:
nvcc -ccbin C:\dev\MSVS\VC\bin cuda.cu
After a few seconds of working nvcc crashes. Notice that “nvcc -V” and “nvcc --help” works well. Sample programs from GPU Computing SDK also compile from Visual Studio without any problem.
What do I do wrong?
Can you show the exact output produced by the compiler when compiling this code with nvcc? As a side note, device-side printf() requires a GPU with compute capability 2.x, which I don’t think the GTS 250 has? By default, nvcc targets compute capability 1.0, you can use the compiler switches -arch or -gencode to target other compute capabilities.
Why did you decide that printf() is device-side? I supposed it to be host-side.
I found the reason of the problem. It is very strange and mysterious. The call nvcc --verbose -ccbin C:\dev\MSVS\VC\bin cuda.cu gives the following output:
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=(null)
and the compiler crashes.
But if use not nvcc but nvcc.exe everything goes ok. Thus nvcc.exe --verbose -ccbin C:\dev\MSVS\VC\bin cuda.cu outputs
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=<CUDA Toolkit install dir>
and compiles successfully.
It is very strange to me that adding .exe to the file’s name on Windows changes its behavior.
Sorry, I was reading too fast. Glad to hear you were able to resolve the issue.
