Hi everyone,
I wonder if anybody could help me with my current dilemma. I’m stuck so any hints or help will be appreciated.
I have the following part of the code w/c I’ve isolated as the cause of problem:
//START of loadMatrixFile function
void loadMatrixFile( char *filename, int *array, int cols, int rows ) {
//assumes space separate integer values e.g. -1 23 4 -56 6 77 i.e. in row-major order
int x, y, *dummy;
FILE *matFile = fopen( filename, "r" );
if ( matFile == 0 ){
printf( "\n could not open file %s \n", filename );
else{
y = 1;
int offset = 4;
fscanf( matFile, "%d", &x );
while( !feof( matFile ) && y < rows * cols + offset ) {
if ( y < offset ){
printf( " A: y = %d x = %d \n ", y, x );
else {
fscanf( matFile, "%d", &dummy[ y - 4 ] );
//fscanf( matFile, "%d", &x );
//printf( " B: y = %d x = %d \n", y, x );
printf( " B: y = %d dummy[ z ] = %d \n", y, dummy[ y - 4 ] );
y++;
fclose( matFile );
if I compile it with nvcc I don’t get any errors. If I do run it:
./mulMatrix MatA MatB
(assuming you have a text file with integer values separated by spaces as input files e.g. MatA MatB in this case)
I get:
A: y = 1 x = 3
A: y = 2 x = 1
A: y = 3 x = 1
Bus error
That is, the fscanf in my code seems to be causing (or is a part of the cause) of the Bus error. I only get to my If, but not to my Else statement.
The details of my iMac are:
uname -a
Darwin theorylabs-P-System-iMac.local 9.8.0 Darwin Kernel Version 9.8.0: Wed Jul 15 16:55:01 PDT 2009; root:xnu-1228.15.4~1/RELEASE_I386 i386
Running Mac OS X 10.5.8 (Intel Core2Duo)
And using CUDA version 3.2.17.
Is there a bug in this version of CUDA for Mac perhaps?
Attached is the entire .cu source code.
mulMatrix.cu (5.43 KB)
