Dear All,
I recently started working with CUDA, so consider me a novice in this domain. I am also a new member on this forum, so kindly excuse me if I am off topic on my post! :)
I installed CUDA on a machine with GeForce 1080 Ti, with Visual studio 2015 and 2013. I want to implement a fast wavelet based algorithm, with as much real time speed as possible. I found an opensource third party library PDWT (https://github.com/pierrepaleo/PDWT/tree/master/src), which looked like a good starting point to me. However, I am unable to build it because of an NVCC error. A full log of the build output is attached at the end of this message.
I will be very grateful if someone here could help me resolve the problem. Also, if you have any advice on a fast wavelet library based on CUDA, please share that as well. Any help will be very valuable for my project.
Thanks and Regards,
Sanat
Ouput Log appended below:
1>------ Build started: Project: CudaEx2, Configuration: Debug x64 ------
1>Build started 10/19/2018 9:06:32 PM.
1> 1>
1>Building with tools version “14.0”.
1> Project file contains ToolsVersion=“4.0”. This toolset may be unknown or missing, in which case you may be able to resolve this by installing the appropriate version of MSBuild, or the build may have been forced to a particular ToolsVersion for policy reasons. Treating the project as if it had ToolsVersion=“14.0”. For more information, please see http://go.microsoft.com/fwlink/?LinkId=293424.
1> 1>
1>Target “_CheckForInvalidConfigurationAndPlatform” in file “C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (entry point):
1> Task “Error” skipped, due to false condition; ( ‘(_InvalidConfigurationError)' == 'true' ) was evaluated as ( '' == 'true' ).
1> Task "Warning" skipped, due to false condition; ( '(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Using “Message” task from assembly “Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Message”
1> Configuration=Debug
1> Done executing task “Message”.
1> Task “Message”
1> Platform=x64
1> Task “Error” skipped, due to false condition; (’(OutDir)' != '' and !HasTrailingSlash('(OutDir)’)) was evaluated as (‘G:\GPUCudaC\CudaEx2\x64\Debug’ != ‘’ and !HasTrailingSlash(‘G:\GPUCudaC\CudaEx2\x64\Debug’)).
1> Task “Error” skipped, due to false condition; (’(BaseIntermediateOutputPath)' != '' and !HasTrailingSlash('(BaseIntermediateOutputPath)’)) was evaluated as (‘obj’ != ‘’ and !HasTrailingSlash(‘obj’)).
1> Task “Error” skipped, due to false condition; (’(IntermediateOutputPath)' != '' and !HasTrailingSlash('(IntermediateOutputPath)’)) was evaluated as (‘x64\Debug’ != ‘’ and !HasTrailingSlash(‘x64\Debug’)).
1> 1>
1>Done building target “_CheckForInvalidConfigurationAndPlatform” in project “CudaEx2.vcxproj”.
1> 1>
1>Target “_PrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.BuildSteps.Targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “Build” depends on it):
1> Task “CreateItem” skipped, due to false condition; (’%(CustomBuild.IncludeFileToTool)’!=’’) was evaluated as (’’!=’’).
1> 1>
1>Done building target “_PrepareForBuild” in project “CudaEx2.vcxproj”.
1> 1>
1>Target “_PrepareForReferenceResolution” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “ResolveReferences” depends on it):
1> Task “Message” skipped, due to false condition; (’(_REFERENCE_DEBUG)'=='true') was evaluated as (''=='true').
1> 1>
1>Done building target "_PrepareForReferenceResolution" in project "CudaEx2.vcxproj".
1> Target "ComputeCrtSDKReference" skipped, due to false condition; ('@(ClCompile)'!='' and '(WindowsAppContainer)’==‘true’ and ‘(UseCrtSDKReference)' != 'false') was evaluated as ('..\..\..\CPPThirdParty\PDWT-master\PDWT-master\src\demo.cpp;..\..\..\CPPThirdParty\PDWT-master\PDWT-master\src\filters.cpp;..\..\..\CPPThirdParty\PDWT-master\PDWT-master\src\io.cpp'!='' and 'false'=='true' and '' != 'false').
1> 1>
1>Target "BeforeResolveReferences" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveReferences" depends on it):
1> 1>
1>Done building target "BeforeResolveReferences" in project "CudaEx2.vcxproj".
1> 1>
1>Target "AssignProjectConfiguration" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveReferences" depends on it):
1> Using "AssignProjectConfiguration" task from assembly "Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
1> Task "AssignProjectConfiguration"
1> Done executing task "AssignProjectConfiguration".
1> 1>
1>Done building target "AssignProjectConfiguration" in project "CudaEx2.vcxproj".
1> Target "AssignProjectConfiguration" skipped. Previously built successfully.
1> 1>
1>Target "_SplitProjectReferencesByFileExistence" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveProjectReferences" depends on it):
1> Task "ResolveNonMSBuildProjectOutput" skipped, due to false condition; ('(BuildingInsideVisualStudio)’==‘true’ and ‘@(ProjectReferenceWithConfiguration)’!=’’) was evaluated as (‘true’==‘true’ and ‘’!=’’).
1> 1>
1>Done building target “_SplitProjectReferencesByFileExistence” in project “CudaEx2.vcxproj”.
1> Target “_RemoveNameMetadataFromProjectReferenceItems” skipped, due to false condition; (’@(ProjectReference)’!=’’) was evaluated as (’’!=’’).
1> 1>
1>Target “ResolveProjectReferences” in file “C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “ResolveReferences” depends on it):
1> Task “MSBuild” skipped, due to false condition; (’%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (’(BuildingInsideVisualStudio)' == 'true' or '(BuildProjectReferences)’ != ‘true’) and ‘(VisualStudioVersion)' != '10.0' and '@(_MSBuildProjectReferenceExistent)' != '') was evaluated as ('' == 'true' and '' != '' and ('true' == 'true' or 'true' != 'true') and '14.0' != '10.0' and '' != '').
1> Task "MSBuild" skipped, due to false condition; ('%(_MSBuildProjectReferenceExistent.BuildReference)' == 'true' and '@(ProjectReferenceWithConfiguration)' != '' and ('(BuildingInsideVisualStudio)’ == ‘true’ or ‘(BuildProjectReferences)' != 'true') and '(VisualStudioVersion)’ == ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (’’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘14.0’ == ‘10.0’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (’%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘(BuildingInsideVisualStudio)' != 'true' and '(BuildProjectReferences)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (’’ == ‘true’ and ‘’ != ‘’ and ‘true’ != ‘true’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (’%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘(BuildingProject)' == 'true' and '@(_MSBuildProjectReferenceExistent)' != '') was evaluated as ('' == 'true' and '' != '' and 'true' == 'true' and '' != '').
1> Task "Warning" skipped, due to false condition; ('@(ProjectReferenceWithConfiguration)' != '' and '@(_MSBuildProjectReferenceNonexistent)' != '') was evaluated as ('' != '' and '' != '').
1> 1>
1>Done building target "ResolveProjectReferences" in project "CudaEx2.vcxproj".
1> Target "FindInvalidProjectReferences" skipped, due to false condition; ('(FindInvalidProjectReferences)’ == ‘true’) was evaluated as (’’ == ‘true’).
1> Target “ResolveNativeReferences” skipped, due to false condition; (’@(NativeReference)’!=’’) was evaluated as (’’!=’’).
1> Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1> 1>
1>Target “GetFrameworkPaths” in file “C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.NetFramework.CurrentVersion.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1> 1>
1>Done building target “GetFrameworkPaths” in project “CudaEx2.vcxproj”.
1> Target “GetWinFXPath” skipped, due to false condition; ((’@(Page)’ != ‘’ or ‘@(ApplicationDefinition)’ != ‘’ or ‘@(Resource)’ != ‘’) and (’(GetWinFXNativePath)' != '' or '(GetWinFXWoWPath)’ != ‘’ )) was evaluated as ((’’ != ‘’ or ‘’ != ‘’ or ‘’ != ‘’) and (’’ != ‘’ or ‘’ != ‘’ )).
1> 1>
1>Target “GetReferenceAssemblyPaths” in file “C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1> Task “GetReferenceAssemblyPaths” skipped, due to false condition; (’(TargetFrameworkMoniker)' != '' and ('(_TargetFrameworkDirectories)’ == ‘’ or ‘(_FullFrameworkReferenceAssemblyPaths)' == '')) was evaluated as ('' != '' and ('C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.0' == '' or 'C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.0' == '')).
1> 1>
1>Done building target "GetReferenceAssemblyPaths" in project "CudaEx2.vcxproj".
1> 1>
1>Target "SetBuildDefaultEnvironmentVariables" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.Cpp.Current.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "PrepareForBuild" depends on it):
1> Using "SetEnv" task from assembly "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.Build.CppTasks.Common.dll".
1> Task "SetEnv"
1> PATH=D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64;D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin;C:\Program Files (x86)\Windows Kits\8.1\bin\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools;D:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\tools;D:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;C:\Program Files (x86)\MSBuild\14.0\bin\;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\libnvvp;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath;D:\Program Files\Python36\Scripts\;D:\Program Files\Python36\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\WINDOWS\system32;F:\msys64\mingw64\bin;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;D:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin;C:\Program Files\Git\cmd;C:\Program Files\Git\bin;D:\Program Files (x86)\CMake\bin;D:\gstreamer\1.0\x86_64\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;D:\Program Files\MATLAB\R2018a\bin;G:\CPPThirdParty\opencv\build\bin;G:\CPPThirdParty\opencv\build\x64\vc14\bin;C:\Users\Sanat Upadhyay\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64;C:\Program Files (x86)\Windows Kits\8.1\bin\x86;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;C:\Program Files (x86)\Microsoft SDKs\TypeScript\1.0\;F:\msys64\mingw64\bin;C:\Users\Sanat Upadhyay\AppData\Local\Microsoft\WindowsApps;C:\Program Files\Git\bin;D:\gstreamer\1.0\x86_64\bin;;
1> Done executing task "SetEnv".
1> Task "SetEnv"
1> LIB=D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\lib\amd64;;D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\atlmfc\lib\amd64;;C:\Program Files (x86)\Windows Kits\10\lib\10.0.10240.0\ucrt\x64;;;C:\Program Files (x86)\Windows Kits\8.1\lib\winv6.3\um\x64;;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Lib\um\x64
1> Task "SetEnv"
1> LIBPATH=D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\atlmfc\lib\amd64;;D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\lib\amd64;
1> Task "SetEnv"
1> INCLUDE=D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include;;D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\atlmfc\include;;C:\Program Files (x86)\Windows Kits\10\Include\10.0.10240.0\ucrt;;;C:\Program Files (x86)\Windows Kits\8.1\Include\um;C:\Program Files (x86)\Windows Kits\8.1\Include\shared;C:\Program Files (x86)\Windows Kits\8.1\Include\winrt;;
1> 1>
1>Done building target "SetBuildDefaultEnvironmentVariables" in project "CudaEx2.vcxproj".
1> Target "SetUserMacroEnvironmentVariables" skipped, due to false condition; ('@(BuildMacro)' != '' and '(DesignTimeBuild)’ != ‘true’) was evaluated as (’’ != ‘’ and ‘’ != ‘true’).
1> 1>
1>Target “GetResolvedWinMD” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “PrepareForBuild” depends on it):
1> 1>
1>Done building target “GetResolvedWinMD” in project “CudaEx2.vcxproj”.
1> 1>
1>Target “PlatformPrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.Cpp.Platform.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “PrepareForBuild” depends on it):
1> Task “VCMessage” skipped, due to false condition; (’(_Error64bitToolsNotInstalled)' == 'true') was evaluated as ('' == 'true').
1> Task "VCMessage" skipped, due to false condition; ('(DesignTimeBuild)’!=‘true’ and ‘(_ToolsetFound)' != 'true' and '(PlatformToolset)’ == ‘v110’) was evaluated as (’’!=‘true’ and ‘true’ != ‘true’ and ‘v140’ == ‘v110’).
1> Task “VCMessage” skipped, due to false condition; (’(DesignTimeBuild)'!='true' and '(ToolsetFound)’ != ‘true’ and ‘(PlatformToolset)' == 'v100') was evaluated as (''!='true' and 'true' != 'true' and 'v140' == 'v100').
1> Task "VCMessage" skipped, due to false condition; ('(DesignTimeBuild)’!=‘true’ and ‘(_ToolsetFound)' != 'true' and '(PlatformToolset)’ == ‘v90’) was evaluated as (’’!=‘true’ and ‘true’ != ‘true’ and ‘v140’ == ‘v90’).
1> Task “VCMessage” skipped, due to false condition; (’(DesignTimeBuild)'!='true' and '(ToolsetFound)’ != ‘true’ and ‘(PlatformToolset)' != 'v90' and '(PlatformToolset)’ != ‘v100’ and ‘(PlatformToolset)' != 'v110') was evaluated as (''!='true' and 'true' != 'true' and 'v140' != 'v90' and 'v140' != 'v100' and 'v140' != 'v110').
1> 1>
1>Done building target "PlatformPrepareForBuild" in project "CudaEx2.vcxproj".
1> 1>
1>Target "Desktop_PlatformPrepareForBuild" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Platforms\x64\PlatformToolsets\v140\Toolset.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "PrepareForBuild" depends on it):
1> Task "VCMessage" skipped, due to false condition; ((MissingSDKProps) == ‘true’) was evaluated as ( == ‘true’).
1> 1>
1>Done building target “Desktop_PlatformPrepareForBuild” in project “CudaEx2.vcxproj”.
1> Target “GetFrameworkPaths” skipped. Previously built successfully.
1> Target “GetReferenceAssemblyPaths” skipped. Previously built successfully.
1> Target “AssignLinkMetadata” skipped, due to false condition; ( ‘(SynthesizeLinkMetadata)' == 'true' ) was evaluated as ( '' == 'true' ).
1> 1>
1>Target "SetCABuildNativeEnvironmentVariables" in file "C:\Program Files (x86)\MSBuild\Microsoft\VisualStudio\v14.0\CodeAnalysis\Microsoft.CodeAnalysis.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "PrepareForBuild" depends on it):
1> Initializing task factory "CodeTaskFactory" from assembly "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Build.Tasks.Core.dll".
1> Using "SetEnvironmentVariable" task from the task factory "Code Task Factory".
1> Task "SetEnvironmentVariable"
1> Done executing task "SetEnvironmentVariable".
1> 1>
1>Done building target "SetCABuildNativeEnvironmentVariables" in project "CudaEx2.vcxproj".
1> 1>
1>Target "PrepareForBuild" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveAssemblyReferences" depends on it):
1> Task "VCMessage" skipped, due to false condition; ('(DesignTimeBuild)’ != ‘true’ and ‘(ConfigurationPlatformExists)' != 'true') was evaluated as ('' != 'true' and 'true' != 'true').
1> Using "MakeDir" task from assembly "Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
1> Task "MakeDir"
1> Done executing task "MakeDir".
1> Task "VCMessage" skipped, due to false condition; ('(DesignTimeBuild)’!=‘true’ and ‘(WindowsAppContainer)'=='true' and '(ConfigurationType)’!=‘Application’ and ‘(ConfigurationType)'!='DynamicLibrary' and '(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (’’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1> Task “VCMessage” skipped, due to false condition; (’(DesignTimeBuild)'!='true' and '(VCInstallDir)’==’’ and ‘(UseEnv)' != 'true' and ('(TargetFrameworkVersion)’==‘v3.5’ or ‘(TargetFrameworkVersion)'=='v3.0' or '(TargetFrameworkVersion)’==‘v2.0’ )) was evaluated as (’’!=‘true’ and ‘D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC’==’’ and ‘’ != ‘true’ and (‘v4.0’==‘v3.5’ or ‘v4.0’==‘v3.0’ or ‘v4.0’==‘v2.0’ )).
1> Task “VCMessage” skipped, due to false condition; (’(DesignTimeBuild)'!='true' and '(VCInstallDir)’==’’ and ‘(UseEnv)' != 'true' and '(PlatformToolset)’==‘v90’) was evaluated as (’’!=‘true’ and ‘D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC’==’’ and ‘’ != ‘true’ and ‘v140’==‘v90’).
1> Task “VCMessage” skipped, due to false condition; (’(VCInstallDir)'=='' and '(UseEnv)’ != ‘true’) was evaluated as (‘D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC’==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’(WindowsSDKDir)'=='' and '(UseEnv)’ != ‘true’) was evaluated as (‘C:\Program Files (x86)\Windows Kits\8.1’==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’(IntDirTrailingSlashWarning)'=='true') was evaluated as (''=='true').
1> Task "VCMessage" skipped, due to false condition; ('(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (’’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (’%(CompatibilityIssues.Identity)’ != ‘’ and '(DesignTimeBuild)'!='true') was evaluated as ('' != '' and ''!='true').
1> Task "VCMessage" skipped, due to false condition; ('(MBCS_Using)’ == ‘true’ and ‘(_MBCS_Installed)' != 'true' and '(DesignTimeBuild)’ != ‘true’) was evaluated as (’’ == ‘true’ and ‘’ != ‘true’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’(IgnoreWarnIntDirSharingDetected)' != 'true' and '(IntDirSharingDetected)’ == ‘true’) was evaluated as (’’ != ‘true’ and ‘’ == ‘true’).
1> Task “VCMessage” skipped, due to false condition; (’(IgnoreWarnIntDirInTempDetected)' != 'true' and ('(IntDirFullpath.StartsWith((Tmp), true, null))' == 'true' or '(IntDirFullpath.StartsWith((Temp), true, null))' == 'true' or '(OutDirFullpath.StartsWith((Tmp), true, null))' == 'true' or '(OutDirFullpath.StartsWith((Temp), true, null))' == 'true')) was evaluated as ('' != 'true' and ('False' == 'true' or 'False' == 'true' or 'False' == 'true' or 'False' == 'true')).
1> Task "MakeDir"
1> 1>
1>Done building target "PrepareForBuild" in project "CudaEx2.vcxproj".
1> Target "_PrepareForReferenceResolution" skipped. Previously built successfully.
1> 1>
1>Target "GetInstalledSDKLocations" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveSDKReferences" depends on it):
1> Task "GetInstalledSDKLocations" skipped, due to false condition; ('@(SDKReference)' != '') was evaluated as ('' != '').
1> Task "GetInstalledSDKLocations" skipped, due to false condition; ('@(SDKReference)' != '' and '(SupportWindows81SDKs)’ == ‘true’ and ‘(TargetPlatformIdentifierWindows81)' != '' and '(TargetPlatformVersionWindows81)’ != ‘’) was evaluated as (’’ != ‘’ and ‘’ == ‘true’ and ‘’ != ‘’ and ‘’ != ‘’).
1> Task “GetInstalledSDKLocations” skipped, due to false condition; (’@(SDKReference)’ != ‘’ and ‘(SupportWindowsPhone81SDKs)' == 'true' and '(TargetPlatformIdentifierWindowsPhone81)’ != ‘’ and ‘(TargetPlatformVersionWindowsPhone81)' != '') was evaluated as ('' != '' and '' == 'true' and '' != '' and '' != '').
1> 1>
1>Done building target "GetInstalledSDKLocations" in project "CudaEx2.vcxproj".
1> 1>
1>Target "ModifyUnitTestPlatformVersion" in file "C:\Program Files (x86)\MSBuild\14.0\Microsoft.Common.targets\ImportBefore\Windows.8.1.UT_SDKReference.props" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveSDKReferences" depends on it):
1> 1>
1>Done building target "ModifyUnitTestPlatformVersion" in project "CudaEx2.vcxproj".
1> 1>
1>Target "ResolveSDKReferences" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveAssemblyReferences" depends on it):
1> Task "ResolveSDKReference" skipped, due to false condition; ('@(SDKReference)'!='') was evaluated as (''!='').
1> 1>
1>Done building target "ResolveSDKReferences" in project "CudaEx2.vcxproj".
1> Target "ResolveSDKReferences" skipped. Previously built successfully.
1> 1>
1>Target "ExpandSDKReferences" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveAssemblyReferences" depends on it):
1> Task "GetSDKReferenceFiles" skipped, due to false condition; ('@(ResolvedSDKReference)'!='') was evaluated as (''!='').
1> 1>
1>Done building target "ExpandSDKReferences" in project "CudaEx2.vcxproj".
1> Target "ResolveNuGetPackageAssets" skipped, due to false condition; ('(ResolveNuGetPackages)’ == ‘true’ and exists(’(ProjectLockFile)')) was evaluated as ('true' == 'true' and exists('project.lock.json')).
1> 1>
1>Target "ResolveAssemblyReferences" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "ResolveReferences" depends on it):
1> Task "ResolveAssemblyReference" skipped, due to false condition; ('@(Reference)'!='' or '@(_ResolvedProjectReferencePaths)'!='' or '@(_ExplicitReference)' != '') was evaluated as (''!='' or ''!='' or '' != '').
1> 1>
1>Done building target "ResolveAssemblyReferences" in project "CudaEx2.vcxproj".
1> Target "GenerateBindingRedirects" skipped, due to false condition; ('(AutoGenerateBindingRedirects)’ == ‘true’ and ‘(GenerateBindingRedirectsOutputType)' == 'true') was evaluated as ('' == 'true' and 'true' == 'true').
1> Target "GenerateBindingRedirectsUpdateAppConfig" skipped, due to false condition; ('(AutoGenerateBindingRedirects)’ == ‘true’ and '(GenerateBindingRedirectsOutputType)' == 'true' and Exists('(GenerateBindingRedirectsIntermediateAppConfig)’)) was evaluated as (’’ == ‘true’ and ‘true’ == ‘true’ and Exists(‘x64\Debug\CudaEx2.vcxproj.CudaEx2.exe.config’)).
1> Target “ResolveComReferences” skipped, due to false condition; (’@(COMReference)’!=’’ or ‘@(COMFileReference)’!=’’) was evaluated as (’’!=’’ or ‘’!=’’).
1> 1>
1>Target “AfterResolveReferences” in file “C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “ResolveReferences” depends on it):
1> 1>
1>Done building target “AfterResolveReferences” in project “CudaEx2.vcxproj”.
1> Target “ImplicitlyExpandDesignTimeFacades” skipped, due to false condition; (’(ImplicitlyExpandDesignTimeFacades)' == 'true') was evaluated as ('' == 'true').
1> Target "ResolveTestReferences" skipped, due to false condition; ('@(Shadow)'!='') was evaluated as (''!='').
1> 1>
1>Target "ResolveReferences" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "Build" depends on it):
1> 1>
1>Done building target "ResolveReferences" in project "CudaEx2.vcxproj".
1> Target "PrepareForBuild" skipped. Previously built successfully.
1> 1>
1>Target "InitializeBuildStatus" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "Build" depends on it):
1> Using "ReadLinesFromFile" task from assembly "Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
1> Task "ReadLinesFromFile"
1> Done executing task "ReadLinesFromFile".
1> Using "WriteLinesToFile" task from assembly "Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
1> Task "WriteLinesToFile"
1> Done executing task "WriteLinesToFile".
1> Using "Touch" task from assembly "Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a".
1> Task "Touch"
1> Touching "x64\Debug\CudaEx2.tlog\unsuccessfulbuild".
1> Done executing task "Touch".
1> 1>
1>Done building target "InitializeBuildStatus" in project "CudaEx2.vcxproj".
1> Target "_SplitProjectReferencesByFileExistence" skipped. Previously built successfully.
1> 1>
1>Target "BuildGenerateSourcesTraverse" in file "C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "BuildGenerateSources" depends on it):
1> Task "MSBuild" skipped, due to false condition; ('(BuildPassReferences)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and '@(MSBuildProjectReferenceExistent)’ != ‘’ and '%(MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’) was evaluated as (’’ == ‘true’ and ‘’ != ‘’ and ‘’ != ‘’ and ‘’ == ‘true’).
1> 1>
1>Done building target “BuildGenerateSourcesTraverse” in project “CudaEx2.vcxproj”.
1> Target “PrepareForBuild” skipped. Previously built successfully.
1> Target “ResolveReferences” skipped. Previously built successfully.
1> 1>
1>Target “BeforeBuildGenerateSources” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.BuildSteps.Targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “BuildGenerateSourcesAction" depends on it):
1> 1>
1>Done building target “BeforeBuildGenerateSources” in project “CudaEx2.vcxproj”.
1> 1>
1>Target “PreBuildEvent” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppCommon.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target "BuildGenerateSourcesAction" depends on it):
1> Task “Message” skipped, due to false condition; (’%(PreBuildEvent.Message)’ != ‘’ and ‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (’’ != ‘’ and ‘’ != ‘’).
1> Task “Exec” skipped, due to false condition; (’%(PreBuildEvent.Command)’ != ‘’) was evaluated as (’’ != ‘’).
1> 1>
1>Done building target “PreBuildEvent” in project “CudaEx2.vcxproj”.
1> Target “CustomBuild” skipped, due to false condition; (’@(CustomBuild)’ != ‘’) was evaluated as (’’ != ‘’).
1> Target “FxExport” skipped, due to false condition; (’@(FxCompile)’ != ‘’) was evaluated as (’’ != ‘’).
1> Target “FxCompile” skipped, due to false condition; (’@(FxCompile)’ != ‘’) was evaluated as (’’ != ‘’).
1> Target “SetBuildDefaultEnvironmentVariables” skipped. Previously built successfully.
1> Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (’@(BuildMacro)’ != ‘’ and ‘(DesignTimeBuild)' != 'true') was evaluated as ('' != '' and '' != 'true').
1> 1>
1>Target "_SelectedFiles" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppBuild.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "CudaBuild" depends on it):
1> 1>
1>Done building target "_SelectedFiles" in project "CudaEx2.vcxproj".
1> Target "CudaFilterSelectedFiles" skipped, due to false condition; ('@(SelectedFiles)' != '') was evaluated as ('' != '').
1> 1>
1>Target "InitializeCudaHostProperties" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "AddCudaCompileMetadata" depends on it):
1> 1>
1>Done building target "InitializeCudaHostProperties" in project "CudaEx2.vcxproj".
1> 1>
1>Target "AddCudaCompileMetadata" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "CudaBuild" depends on it):
1> Building target "AddCudaCompileMetadata" completely.
1> No input files were specified.
1> Using "SanitizePaths" task from assembly "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\Nvda.Build.CudaTasks.v10.0.dll".
1> Task "SanitizePaths"
1> Done executing task "SanitizePaths".
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\common.cu-1473392950.deps')).
1> Using "SplitToItemMetadata" task from assembly "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\Nvda.Build.CudaTasks.v10.0.dll".
1> Task "SplitToItemMetadata"
1> Done executing task "SplitToItemMetadata".
1> 1>
1>Done building target "AddCudaCompileMetadata" in project "CudaEx2.vcxproj".
1> 1>
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\haar.cu693303656.deps')).
1> 1>
1> 1>
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\nonseparable.cu-1771243646.deps')).
1> 1>
1> 1>
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\separable.cu1680465003.deps')).
1> 1>
1> 1>
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\utils.cu547168686.deps')).
1> 1>
1> 1>
1> Task "ReadLinesFromFile" skipped, due to false condition; (Exists('%(CudaCompile.DepsOutputPath)')) was evaluated as (Exists('x64\Debug\wt.cu1244414593.deps')).
1> 1>
1> Target "AddCudaCompileMetadata" skipped. Previously built successfully.
1> Target "InitializeCudaHostProperties" skipped. Previously built successfully.
1> 1>
1>Target "InitializeCudaProjectProperties" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "AddCudaLinkMetadata" depends on it):
1> 1>
1>Done building target "InitializeCudaProjectProperties" in project "CudaEx2.vcxproj".
1> 1>
1>Target "AddCudaLinkMetadata" in file "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets" from project "G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj" (target "CudaBuild" depends on it):
1> Building target "AddCudaLinkMetadata" completely.
1> Using "ResolvePaths" task from assembly "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\Nvda.Build.CudaTasks.v10.0.dll".
1> Task "ResolvePaths"
1> Done executing task "ResolvePaths".
1> 1>
1>Done building target "AddCudaLinkMetadata" in project "CudaEx2.vcxproj".
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> 1>
1> Target "SetBuildDefaultEnvironmentVariables" skipped. Previously built successfully.
1> Target “AddCudaCompileMetadata” skipped. Previously built successfully.
1> 1>
1>Target “AddCudaCompileDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “CudaBuild” depends on it):
1> Building target “AddCudaCompileDeps” completely.
1> Output file “x64\Debug\common.cu-1473392950.deps” does not exist.
1> Using “GenerateDeps” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\Nvda.Build.CudaTasks.v10.0.dll”.
1> Task “GenerateDeps”
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include” /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\common.cu
1> Done executing task “GenerateDeps”.
1> Task “MakeDir”
1> Done executing task “MakeDir”.
1> Task “WriteLinesToFile”
1> Done executing task “WriteLinesToFile”.
1> 1>
1>Done building target “AddCudaCompileDeps” in project “CudaEx2.vcxproj”.
1> 1>
1> Output file “x64\Debug\haar.cu693303656.deps” does not exist.
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\haar.cu
1> Task “MakeDir”
1> 1>
1> 1>
1> Output file “x64\Debug\nonseparable.cu-1771243646.deps” does not exist.
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\nonseparable.cu
1> Task “MakeDir”
1> 1>
1> 1>
1> Output file “x64\Debug\separable.cu1680465003.deps” does not exist.
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\separable.cu
1> Task “MakeDir”
1> 1>
1> 1>
1> Output file “x64\Debug\utils.cu547168686.deps” does not exist.
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\utils.cu
1> Task “MakeDir”
1> 1>
1> 1>
1> Output file “x64\Debug\wt.cu1244414593.deps” does not exist.
1> D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC /DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" /I. /FIcuda_runtime.h /c G:\CPPThirdParty\PDWT-master\PDWT-master\src\wt.cu
1> Task “MakeDir”
1> 1>
1> Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (’@(BuildMacro)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (’’ != ‘’ and ‘’ != ‘true’).
1> 1>
1>Target “AddCudaCompilePropsDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 10.0.targets” from project “G:\GPUCudaC\CudaEx2\CudaEx2\CudaEx2.vcxproj” (target “CudaBuild” depends on it):
1> Building target “AddCudaCompilePropsDeps” completely.
1> Output file “x64\Debug\common.cu.cache” does not exist.
1> Task “ReadLinesFromFile” skipped, due to false condition; (Exists(’%(CudaCompile.PropsCacheOutputPath)’)) was evaluated as (Exists(‘x64\Debug\common.cu.cache’)).
1> Using “XmlPeek” task from assembly “Microsoft.Build.Tasks.Core, Version=14.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “XmlPeek”
1> Found “CudaToolkitCustomDir”.
1> Found “AdditionalDeps”.
1> Found “CompileOut”.
1> Found “Include”.
1> Found “UseHostInclude”.
1> Found “Keep”.
1> Found “KeepDir”.
1> Found “GenerateRelocatableDeviceCode”.
1> Found “NvccCompilation”.
1> Found “CudaRuntime”.
1> Found “NvccPath”.
1> Found “RequiredIncludes”.
1> Found “TargetMachinePlatform”.
1> Found “InterleaveSourceInPTX”.
1> Found “CodeGeneration”.
1> Found “GPUDebugInfo”.
1> Found “GenerateLineInfo”.
1> Found “MaxRegCount”.
1> Found “PtxAsOptionV”.
1> Found “AdditionalCompilerOptions”.
1> Found “Defines”.
1> Found “UseHostDefines”.
1> Found “Emulation”.
1> Found “HostDebugInfo”.
1> Found “FastMath”.
1> Found “ProgramDataBaseFileName”.
1> Found “Optimization”.
1> Found “Runtime”.
1> Found “RuntimeChecks”.
1> Found “TypeInfo”.
1> Found “Warning”.
1> Found “AdditionalOptions”.
1> Found “CommandLineTemplate”.
1> Found “PerformDeviceLink”.
1> Found “LinkOut”.
1> Found “AdditionalLibraryDirectories”.
1> Found “UseHostLibraryDirectories”.
1> Found “AdditionalDependencies”.
1> Found “UseHostLibraryDependencies”.
1> Found “Warning”.
1> Found “Runtime”.
1> Found “Inputs”.
1> Done executing task “XmlPeek”.
1> Using “ReadMetadataLinesFromItems” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\Nvda.Build.CudaTasks.v10.0.dll”.
1> Task “ReadMetadataLinesFromItems”
1> Done executing task “ReadMetadataLinesFromItems”.
1> 1>
1>Done building target “AddCudaCompilePropsDeps” in project “CudaEx2.vcxproj”.
1> 1>
1> Output file “x64\Debug\haar.cu.cache” does not exist.
1> Task “ReadLinesFromFile” skipped, due to false condition; (Exists(’%(CudaCompile.PropsCacheOutputPath)’)) was evaluated as (Exists(‘x64\Debug\haar.cu.cache’)).
1> Task “XmlPeek”
1> Found “Include”.
1> Found “Keep”.
1> Found “KeepDir”.
1> Found “Defines”.
1> Found “Runtime”.
1> Found “Warning”.
1> Found “LinkOut”.
1> Found “Warning”.
1> Found “Runtime”.
1> Found “Inputs”.
1> 1>
1> 1>
1> Output file “x64\Debug\nonseparable.cu.cache” does not exist.
1> Task “ReadLinesFromFile” skipped, due to false condition; (Exists(’%(CudaCompile.PropsCacheOutputPath)’)) was evaluated as (Exists(‘x64\Debug\nonseparable.cu.cache’)).
1> Task “XmlPeek”
1> Found “Include”.
1> Found “Keep”.
1> Found “KeepDir”.
1> Found “Defines”.
1> Found “Runtime”.
1> Found “Warning”.
1>
