I got the above error when i try to build my project which contains relocatable device code.
Till-now, when i use the device code in one file i.e. kernel.cu, building went just fine. Now i had a function which is used by both the device and host, so i modified that function with a prefix host device and passed -dc flag to nvcc.
When i tried building the project using Cmake/make, it shows the following
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/test_zip1_gpu.dir/dlink.txt --verbose=1
/usr/bin/nvcc -arch=sm_50 --ptxas-options=-v -Xptxas -dlcm=ca -dc -Xcompiler=-fPIC -shared -dlink CMakeFiles/test_zip1_gpu.dir/src/kernel.cu.o CMakeFiles/test_zip1_gpu.dir/src/main.cu.o CMakeFiles/test_zip1_gpu.dir/src/adler32.c.o CMakeFiles/test_zip1_gpu.dir/src/END_OF_CENTRAL_DIR.cu.o CMakeFiles/test_zip1_gpu.dir/src/CENTRAL_DIR.cu.o CMakeFiles/test_zip1_gpu.dir/src/LOCAL_FILE_HEADER.cu.o CMakeFiles/test_zip1_gpu.dir/src/ENCRYPTION_HEADER.cu.o CMakeFiles/test_zip1_gpu.dir/src/DATA_DESCRIPTOR.cu.o CMakeFiles/test_zip1_gpu.dir/src/MEMORY_FREE_AVAILABLE.cu.o CMakeFiles/test_zip1_gpu.dir/src/EXTRACT_DATA_BYTES.cu.o CMakeFiles/test_zip1_gpu.dir/src/crc32_checksum.cu.o CMakeFiles/test_zip1_gpu.dir/src/AES_STRUCTURE.cu.o CMakeFiles/test_zip1_gpu.dir/src/aes_modes.c.o CMakeFiles/test_zip1_gpu.dir/src/aescrypt.c.o CMakeFiles/test_zip1_gpu.dir/src/aeskey.c.o CMakeFiles/test_zip1_gpu.dir/src/aestab.c.o CMakeFiles/test_zip1_gpu.dir/src/aes_ni.c.o CMakeFiles/test_zip1_gpu.dir/src/pwd2key.c.o CMakeFiles/test_zip1_gpu.dir/src/hmac.c.o CMakeFiles/test_zip1_gpu.dir/src/sha1.c.o CMakeFiles/test_zip1_gpu.dir/src/sha2.c.o CMakeFiles/test_zip1_gpu.dir/src/fileenc.c.o CMakeFiles/test_zip1_gpu.dir/src/DECRYPTION.cu.o -o CMakeFiles/test_zip1_gpu.dir/cmake_device_link.o -Xnvlink libz.so.1.2.11 -L"/usr/lib/x86_64-linux-gnu"
nvcc fatal : A single input file is required for a non-link phase when an outputfile is specified
CMakeFiles/test_zip1_gpu.dir/build.make:414: recipe for target 'CMakeFiles/test_zip1_gpu.dir/cmake_device_link.o' failed
I would like to paste the cmake file here for more info
cmake_minimum_required(VERSION 3.8)
project(test_zip1_gpu LANGUAGES CUDA C)
option(ASM686 "Enable building i686 assembly implementation")
option(AMD64 "Enable building amd64 assembly implementation")
#CUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-9.2/
set(INSTALL_BIN_DIR "${CMAKE_INSTALL_PREFIX}/bin" CACHE PATH "Installation directory for executables")
set(INSTALL_LIB_DIR "${CMAKE_INSTALL_PREFIX}/lib" CACHE PATH "Installation directory for libraries")
set(INSTALL_INC_DIR "${CMAKE_INSTALL_PREFIX}/include" CACHE PATH "Installation directory for include")
set(INSTALL_MAN_DIR "${CMAKE_INSTALL_PREFIX}/share/man" CACHE PATH "Installation directory for manual pages")
set(INSTALL_PKGCONFIG_DIR "${CMAKE_INSTALL_PREFIX}/share/pkgconfig" CACHE PATH "Installation directory for pkgconfig (.pc) files")
include(CheckTypeSize)
include(CheckFunctionExists)
include(CheckIncludeFile)
include(CheckCSourceCompiles)
enable_testing()
check_include_file(sys/types.h HAVE_SYS_TYPES_H)
check_include_file(stdint.h HAVE_STDINT_H)
check_include_file(stddef.h HAVE_STDDEF_H)
# Check to see if we have large file support
set(CMAKE_REQUIRED_DEFINITIONS -D_LARGEFILE64_SOURCE=1)
# We add these other definitions here because CheckTypeSize.cmake
# in CMake 2.4.x does not automatically do so and we want
# compatibility with CMake 2.4.x.
if(HAVE_SYS_TYPES_H)
list(APPEND CMAKE_REQUIRED_DEFINITIONS -DHAVE_SYS_TYPES_H)
endif()
if(HAVE_STDINT_H)
list(APPEND CMAKE_REQUIRED_DEFINITIONS -DHAVE_STDINT_H)
endif()
if(HAVE_STDDEF_H)
list(APPEND CMAKE_REQUIRED_DEFINITIONS -DHAVE_STDDEF_H)
endif()
check_type_size(off64_t OFF64_T)
if(HAVE_OFF64_T)
add_definitions(-D_LARGEFILE64_SOURCE=1)
endif()
set(CMAKE_REQUIRED_DEFINITIONS) # clear variable
# Check for fseeko
check_function_exists(fseeko HAVE_FSEEKO)
if(NOT HAVE_FSEEKO)
add_definitions(-DNO_FSEEKO)
endif()
# Check for unistd.h
check_include_file(unistd.h Z_HAVE_UNISTD_H)
if(MSVC)
set(CMAKE_DEBUG_POSTFIX "d")
add_definitions(-D_CRT_SECURE_NO_DEPRECATE)
add_definitions(-D_CRT_NONSTDC_NO_DEPRECATE)
include_directories(${CMAKE_CURRENT_SOURCE_DIR})
endif()
if(NOT CMAKE_CURRENT_SOURCE_DIR STREQUAL CMAKE_CURRENT_BINARY_DIR)
# If we're doing an out of source build and the user has a zconf.h
# in their source tree...
if(EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/zconf.h)
message(STATUS "Renaming")
message(STATUS " ${CMAKE_CURRENT_SOURCE_DIR}/zconf.h")
message(STATUS "to 'zconf.h.included' because this file is included with zlib")
message(STATUS "but CMake generates it automatically in the build directory.")
file(RENAME ${CMAKE_CURRENT_SOURCE_DIR}/zconf.h ${CMAKE_CURRENT_SOURCE_DIR}/zconf.h.included)
endif()
endif()
set(ZLIB_PC ${CMAKE_CURRENT_BINARY_DIR}/zlib.pc)
configure_file( ${CMAKE_CURRENT_SOURCE_DIR}/zlib.pc.cmakein
${ZLIB_PC} @ONLY)
configure_file( ${CMAKE_CURRENT_SOURCE_DIR}/include/zconf.h.cmakein
${CMAKE_CURRENT_BINARY_DIR}/include/zconf.h @ONLY)
include_directories(${CMAKE_CURRENT_BINARY_DIR} ${CMAKE_SOURCE_DIR})
# zlib
set(ZLIB_PUBLIC_HDRS
${CMAKE_CURRENT_SOURCE_DIR}/include/zlib.h
set(ZLIB_PRIVATE_HDRS
${CMAKE_CURRENT_SOURCE_DIR}/include/crc32.h
${CMAKE_CURRENT_SOURCE_DIR}/include/deflate.h
${CMAKE_CURRENT_SOURCE_DIR}/include/gzguts.h
${CMAKE_CURRENT_SOURCE_DIR}/include/inffast.h
${CMAKE_CURRENT_SOURCE_DIR}/include/inffixed.h
${CMAKE_CURRENT_SOURCE_DIR}/include/inflate.h
${CMAKE_CURRENT_SOURCE_DIR}/include/inftrees.h
${CMAKE_CURRENT_SOURCE_DIR}/include/trees.h
${CMAKE_CURRENT_SOURCE_DIR}/include/zutil.h
set(ZLIB_SRCS
${CMAKE_CURRENT_SOURCE_DIR}/src/adler32.c
${CMAKE_CURRENT_SOURCE_DIR}/src/compress.c
${CMAKE_CURRENT_SOURCE_DIR}/src/crc32.c
${CMAKE_CURRENT_SOURCE_DIR}/src/deflate.c
${CMAKE_CURRENT_SOURCE_DIR}/src/gzclose.c
${CMAKE_CURRENT_SOURCE_DIR}/src/gzlib.c
${CMAKE_CURRENT_SOURCE_DIR}/src/gzread.c
${CMAKE_CURRENT_SOURCE_DIR}/src/gzwrite.c
${CMAKE_CURRENT_SOURCE_DIR}/src/inflate.c
${CMAKE_CURRENT_SOURCE_DIR}/src/infback.c
${CMAKE_CURRENT_SOURCE_DIR}/src/inftrees.c
${CMAKE_CURRENT_SOURCE_DIR}/src/inffast.c
${CMAKE_CURRENT_SOURCE_DIR}/src/trees.c
${CMAKE_CURRENT_SOURCE_DIR}/src/uncompr.c
${CMAKE_CURRENT_SOURCE_DIR}/src/zutil.c
if(NOT MINGW)
set(ZLIB_DLL_SRCS
win32/zlib1.rc # If present will override custom build rule below.
endif()
if(CMAKE_COMPILER_IS_GNUCC)
if(ASM686)
set(ZLIB_ASMS contrib/asm686/match.S)
elseif (AMD64)
set(ZLIB_ASMS contrib/amd64/amd64-match.S)
endif ()
if(ZLIB_ASMS)
add_definitions(-DASMV)
set_source_files_properties(${ZLIB_ASMS} PROPERTIES LANGUAGE C COMPILE_FLAGS -DNO_UNDERLINE)
endif()
endif()
if(MSVC)
if(ASM686)
ENABLE_LANGUAGE(ASM_MASM)
set(ZLIB_ASMS
contrib/masmx86/inffas32.asm
contrib/masmx86/match686.asm
elseif (AMD64)
set(ZLIB_ASMS
contrib/masmx64/gvmat64.asm
contrib/masmx64/inffasx64.asm
endif()
if(ZLIB_ASMS)
add_definitions(-DASMV -DASMINF)
endif()
endif()
# parse the full version number from zlib.h and include in ZLIB_FULL_VERSION
file(READ include/zlib.h _zlib_h_contents)
string(REGEX REPLACE ".*#define[ \t]+ZLIB_VERSION[ \t]+\"([-0-9A-Za-z.]+)\".*"
"\1" ZLIB_FULL_VERSION ${_zlib_h_contents})
if(MINGW)
# This gets us DLL resource information when compiling on MinGW.
if(NOT CMAKE_RC_COMPILER)
set(CMAKE_RC_COMPILER windres.exe)
endif()
add_custom_command(OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/zlib1rc.obj
COMMAND ${CMAKE_RC_COMPILER}
-D GCC_WINDRES
-I ${CMAKE_CURRENT_SOURCE_DIR}
-I ${CMAKE_CURRENT_BINARY_DIR}
-o ${CMAKE_CURRENT_BINARY_DIR}/zlib1rc.obj
-i ${CMAKE_CURRENT_SOURCE_DIR}/win32/zlib1.rc)
set(ZLIB_DLL_SRCS ${CMAKE_CURRENT_BINARY_DIR}/zlib1rc.obj)
endif(MINGW)
add_library(zlib SHARED ${ZLIB_SRCS} ${ZLIB_ASMS} ${ZLIB_DLL_SRCS} ${ZLIB_PUBLIC_HDRS} ${ZLIB_PRIVATE_HDRS})
add_library(zlibstatic STATIC ${ZLIB_SRCS} ${ZLIB_ASMS} ${ZLIB_PUBLIC_HDRS} ${ZLIB_PRIVATE_HDRS})
set_target_properties(zlib PROPERTIES DEFINE_SYMBOL ZLIB_DLL)
set_target_properties(zlib PROPERTIES SOVERSION 1)
if(NOT CYGWIN)
# This property causes shared libraries on Linux to have the full version
# encoded into their final filename. We disable this on Cygwin because
# it causes cygz-${ZLIB_FULL_VERSION}.dll to be created when cygz.dll
# seems to be the default.
# This has no effect with MSVC, on that platform the version info for
# the DLL comes from the resource file win32/zlib1.rc
set_target_properties(zlib PROPERTIES VERSION ${ZLIB_FULL_VERSION})
endif()
if(UNIX)
# On unix-like platforms the library is almost always called libz
set_target_properties(zlib zlibstatic PROPERTIES OUTPUT_NAME z)
if(NOT APPLE)
set_target_properties(zlib PROPERTIES LINK_FLAGS "-Wl,--version-script,\"${CMAKE_CURRENT_SOURCE_DIR}/zlib.map\"")
endif()
elseif(BUILD_SHARED_LIBS AND WIN32)
# Creates zlib1.dll when building shared library version
set_target_properties(zlib PROPERTIES SUFFIX "1.dll")
endif()
if(NOT SKIP_INSTALL_LIBRARIES AND NOT SKIP_INSTALL_ALL )
install(TARGETS zlib zlibstatic
RUNTIME DESTINATION "${INSTALL_BIN_DIR}"
ARCHIVE DESTINATION "${INSTALL_LIB_DIR}"
LIBRARY DESTINATION "${INSTALL_LIB_DIR}" )
endif()
if(NOT SKIP_INSTALL_HEADERS AND NOT SKIP_INSTALL_ALL )
install(FILES ${ZLIB_PUBLIC_HDRS} DESTINATION "${INSTALL_INC_DIR}")
endif()
if(NOT SKIP_INSTALL_FILES AND NOT SKIP_INSTALL_ALL )
install(FILES zlib.3 DESTINATION "${INSTALL_MAN_DIR}/man3")
endif()
install(FILES ${ZLIB_PC} DESTINATION "${INSTALL_PKGCONFIG_DIR}")
endif()
# Example binaries
add_executable(test_zip1_gpu src/kernel.cu src/main.cu src/adler32.c src/END_OF_CENTRAL_DIR.cu src/CENTRAL_DIR.cu src/LOCAL_FILE_HEADER.cu src/ENCRYPTION_HEADER.cu src/DATA_DESCRIPTOR.cu src/MEMORY_FREE_AVAILABLE.cu src/EXTRACT_DATA_BYTES.cu src/crc32_checksum.cu src/AES_STRUCTURE.cu src/aes_modes.c src/aescrypt.c src/aeskey.c src/aestab.c src/aes_ni.c src/pwd2key.c src/hmac.c src/sha1.c src/sha2.c src/fileenc.c src/DECRYPTION.cu)
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -arch=sm_50 --ptxas-options=-v -Xptxas -dlcm=ca")
target_link_libraries(test_zip1_gpu zlib)
install(TARGETS test_zip1_gpu RUNTIME DESTINATION bin)
