Hi all,
I am new to CUDA, I’ve found it today.
I am trying to implement your KNN_Mono algorithm because the OpenCV FastNlMeanDenoising is way too slow.
I did the following:
- Install Nvidia CUDA
- Open VisualStudio Code with Anaconda3 and then “pip install PyCuda”
I downloaded an example from https://github.com/AlainPaillou/PyCuda_Denoise_Filters that have an implementation of your algorithm in python.
I started the py program running “python cudatest.py” (cudatest.py is my python file)
Now I get this error:
[command: nvcc --cubin -arch sm_61 -m64 -Ic:\users\XXXXXXX\anaconda3\lib\site-packages\pycuda\cuda kernel.cu]
[stdout:
nvcc fatal : Cannot find compiler ‘cl.exe’ in PATH
I tried to add to the ‘Environment Variables’ settings the PATH where cl.exe is but that’s not working (I made a StackOverflow post there with images https://stackoverflow.com/questions/59735926/cannot-find-compiler-cl-exe-in-path-visualstudio)
This is my version:
PS C:\Users\XXXXXXX\Desktop\XXXXXXX\Py Script> nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_19:32:27_Pacific_Daylight_Time_2019
Cuda compilation tools, release 10.2, V10.2.89
Do you have any suggestions? I am struggling for hours.
