I am trying to compile a *.cubin file from *.cu file , but I have a following error:
“nvcc fatal : Cannot find compiler cl.exe in PATH”. If I am not mistaken PATH it is envionment variable.
I add path for this file into PATH variable but problem is not disappear.
Does anyone know how can I sovle this problem?
I am using CUDA.NET accoding GASS documentation commad to complile is nvcc my_file_name.cu --cubin
Also I am using different files type (e.g. *.cu *.cu) but unsuccessfully
Does someone know where I can find documentation for nvcc error messages?
Unsure if this is your issue, but if you’re using the command line it sometimes helps to run C:\Program Files\Microsoft Visual Studio 8\Common7\Tools\vsvars32.bat before trying to compile a cu into a cubin as detailed in the nvcc manual to help set up the environment variables, then you might not have to move stuff around to make it work.
