nvcc is a compiler driver and does a lot of steps “under the hood”. During this process it creates a variety of temporary files which by default get stored in the /tmp directory on linux.
Apparently whatever user account you are working from does not have the necessary privilege to access files in /tmp You can easily verify this with:
touch /tmp/test_file
and see if it succeeds or gives you an error message (from the non-root account). If you get an error message, you will need to sort out your user privileges.
as a possible work-around, you could specify
nvcc --keep ...
which will make a mess of your current directory, but will not use the default temporary directory.
http://docs.nvidia.com/cuda/cuda-compiler-driver-nvcc/index.html#keeping-intermediate-phase-files
