Hi all,
I noticed, that when running nvcc (5.0) with oprtion -G, an empty (0B) file with an apparently temporary name is created in the current directory each time nvcc is run.
Removing the -G option prevents the file from being created.
Example:
tmpxft_00002a9c_00000000-15_vector.compute_10.cpp3.o
From procmon, this is created by be.exe from the CUDA Toolkit.
Question:
What is this file and how can I tell nvcc to clean it as part of the build (and I don’t mean the -clean option, I mean to clean it as all other temp. files)?
Exact command line used:
“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.0\bin\nvcc.exe” -gencode=arch=compute_10,code="sm_10,compute_10" -gencode=arch=compute_20,code="sm_20,compute_20" -g -G --cl-version 2010 -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.1\include" -maxrregcount=0 --machine 32 --compile -DWIN32 -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MTd /FdWin32/Debug/vector.cu.pdb” -o “Win32/Debug/vector.cu.obj” vector.cu
