So the project I’m working on has gone from a small bunch of experiments into a major piece of code. I need to have a better way to build it than have a single file where I #include everything, so I’ve decided to split the code into .c files and figure out a compilation path I can take, the better to write a makefile.
However, I am getting odd linking issues with non-kernel code. When I compile a file using nvcc, the output of nm is as such, for two object files :
U _cudaFree
U _cudaMallocPitch
U _free
U _malloc
0000007e T _matrix_int_free
00000000 T _matrix_int_init
00000136 T _matrix_int_offline_free
000000af T _matrix_int_offline_init
U _cudaGetDeviceProperties
U _cudaMemcpy
U _matrix_int_offline_free
U _matrix_int_offline_init
00000000 T _matrix_int_print
0000019b T _matrix_int_swapoff
00000220 T _matrix_int_swapon
U _printf
U _putchar
000002a5 T _report_cuda_properties
U _sprintf
However, when I try to go and link the code, I get the following linker errors:
$ nvcc common.o transpose.o matrix_init.o test.o -L/usr/local/cuda/lib -lcudart
Undefined symbols:
"matrix_int_init(__matrix_int*, int, int)", referenced from:
_main in test.o
"matrix_int_print(__matrix_int, __sFILE*)", referenced from:
_main in test.o
_main in test.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
Clearly, the symbols are there, and they are even named as they should be, but the linker cannot see them. When I compile the code using nvcc for the kernels and gcc for the C code, I get the same errors. What gives?
