NVCC not working
After going through the toolkit download on my Jetson AGX Orin here:
NVCC isn’t recognized as a command. “which nvcc” doesn’t pull up anything. I tried looking for the cuda toolkit download location, but couldn’t find it.
I also tried “export PATH=/opt/local/NVIDIA/cuda-10.0/bin:$PATH”
but that didn’t work.
What else should I do?
We have JetPack 6 GA release which contains CUDA 12 so you don’t need to upgrade it manually.
If you prefer to do so, the upgradable CUDA uses compat lib.
Please check the below topic to export the path accordingly.
So how do I use NVCC on my Orin board if it isn’t a recognized command?
Please check the topic to export some global variables and nvcc will work normally.
After running export PATH=/usr/local/cuda-12/bin:${PATH}
export LD_LIBRARY_PATH=/usr/local/cuda-12.0/compat
nvcc works, however when i try to use cudaMalloc I get the following error: “CUDA driver version is insufficient for CUDA runtime version”
How can I fix that?
It looks like you are using CUDA 12.4.
So please upgrade the path to 12.4.
$ export LD_LIBRARY_PATH=/usr/local/cuda-12.4/compat
More, the package is built for Ubuntu 22.04.
Do you use the r36 branch that comes from JetPack 6?
Things are working for nvcc now, but when I use the following makefile I get an error.
NVCC=nvcc
These are the default install
locations on most linux distros
OPENCV_LIBPATH=/usr/lib
OPENCV_INCLUDEPATH=/usr/include
On Macs the default install locations are below
#OPENCV_LIBPATH=/usr/local/lib
#OPENCV_INCLUDEPATH=/usr/local/include
or if using MacPorts
#OPENCV_LIBPATH=/opt/local/lib
#OPENCV_INCLUDEPATH=/opt/local/include
OPENCV_LIBS=-lopencv_core -lopencv_imgproc -lopencv_highgui
CUDA_INCLUDEPATH=/opt/local/cuda-10.0/include
#CUDA_INCLUDEPATH=/usr/local/cuda/include
#CUDA_LIBPATH=/usr/local/cuda/lib
NVCC_OPTS=-O3 -arch=sm_61 -Xcompiler -Wall -Xcompiler -Wextra -m64
GCC_OPTS=-O3 -Wall -Wextra -m64
student: main.o student_func.o compare.o reference_calc.o Makefile
$(NVCC) -o HW1 main.o student_func.o compare.o reference_calc.o -L $(OPENCV_LIBPATH) $(OPENCV_LIBS) $(NVCC_OPTS)
main.o: main.cpp timer.h utils.h reference_calc.cpp compare.cpp HW1.cpp
g++ -c main.cpp $(GCC_OPTS) -I $(CUDA_INCLUDEPATH) -I $(OPENCV_INCLUDEPATH)
student_func.o: student_func.cu utils.h
nvcc -c student_func.cu $(NVCC_OPTS)
compare.o: compare.cpp compare.h
g++ -c compare.cpp -I $(OPENCV_INCLUDEPATH) $(GCC_OPTS) -I $(CUDA_INCLUDEPATH)
reference_calc.o: reference_calc.cpp reference_calc.h
g++ -c reference_calc.cpp -I $(OPENCV_INCLUDEPATH) $(GCC_OPTS) -I $(CUDA_INCLUDEPATH)
clean:
rm -f *.o *.png hw
Error: g++ -c main.cpp -O3 -Wall -Wextra -m64 -I /opt/local/cuda-10.0/include -I /usr/include
g++: error: unrecognized command line option ‘-m64’
make: *** [Makefile:43: main.o] Error 1
How can I fix that?
Could you remove the -m64 config and try it again?
Now the error I get is:
In file included from main.cpp:4:
timer.h:4:10: fatal error: cuda_runtime.h: No such file or directory
4 | include <cuda_runtime.h>
compilation terminated.
You should find the file under /usr/local/cuda/include/.
Please add the path to the included path.
This is what is already in the makefile: #CUDA_INCLUDEPATH=/usr/local/cuda/include
should I update the path in my #include statement instead?
Could you share the complete compiling log so we can check if the path added to the compiling flag?
Where do I find that?
Usually it will show on the console.
Please run $make clean and $make. Then share the complete log with us.
Ok. here’s what I got.
g++ -c main.cpp -O3 -Wall -Wextra -I /opt/local/cuda-10.0/include -I /usr/include
    4 | #include <cuda_runtime.h>
make: *** [Makefile:44: main.o] Error 1
Hi
It looks like you are using an incorrect path.
The cuda_runtime.h is located at /usr/local/cuda/include, not the /opt/local/cuda-10.0/include.
