Good day. I am trying to use code from cudahandbook
I tried to compile it on the Windows with the following options:
nvcc -I …/chLib -o a.exe -cuda normalizedCrossCorrelation.cu -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.28.29333\bin\Hostx64\x64”
when I am trying to start a.exe file:
“a.exe is not compatible with the version of Windows you’re running. Check your computer’s system information and then contact the software publisher.”
Also I tried to compile the same with jetson javier
nvcc -I …/chLib -o a.out normalizedCrossCorrelation.cu
And it even not compiled :
…/chLib/chError.h(115): error: identifier “CUDA_ERROR_STUB_LIBRARY” is undefined
…/chLib/chError.h(117): error: identifier “CUDA_ERROR_DEVICE_NOT_LICENSED” is undefined
…/chLib/chError.h(122): error: identifier “CUDA_ERROR_JIT_COMPILATION_DISABLED” is undefined
…/chLib/chError.h(123): error: identifier “CUDA_ERROR_UNSUPPORTED_PTX_VERSION” is undefined
4 errors detected in the compilation of “/tmp/tmpxft_00002fb2_00000000-8_normalizedCrossCorrelation.cpp1.ii”
Please tell me what I am doing wrong
Thank you!
