I installed CUDA9.1 with driver -version 387.34 on Ubuntu 16.04
I ran very simple example code, but I met this compile error.
Although I searched for solving this problem, there are only past information about 1 years ago.
They were almost related in CUDA7.5 and CUDA8, but I have CUDA9.1
How can I solve this problem?
this below code is my error message.
CompileError: nvcc preprocessing of /tmp/tmp1ni691lp.cu failed
[command: nvcc --preprocess -arch sm_61 -I/usr/local/lib/python3.5/dist-packages/pycuda/cuda /tmp/tmp1ni691lp.cu --compiler-options -P]
[stderr:
b"nvcc fatal : Value 'sm_61' is not defined for option 'gpu-architecture'\n"]
I also made PATH in ~/.bashrc
export PATH=/usr/local/cuda-9.1/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-9.1/lib64\{LD_LIBRARY_PATH:+:${$LIBRARY_PATH}}
