Greetings,
building Qiskit-AER with CUDA 12.6 and GCC v13.3.0 fails,
similar to __builtin_ia32_ldtilecfg and __builtin_ia32_sttilecfg are undefined, with the following output.
[1/4] Building CUDA object qiskit_aer/backends/wrappers/CMakeFiles/controller_wrappers.dir/__/__/__/src/simulators/statevector/qv_avx2.cpp.o
FAILED: qiskit_aer/backends/wrappers/CMakeFiles/controller_wrappers.dir/__/__/__/src/simulators/statevector/qv_avx2.cpp.o
/opt/cuda/bin/nvcc -forward-unknown-to-host-compiler -DAER_THRUST_SUPPORTED=TRUE -DTHRUST_DEVICE_SYSTEM=THRUST_DEVICE_SYSTEM_CUDA -Dcontroller_wrappers_EXPORTS -I/usr/include/python3.12 -I/home/utz/.cache/uv/builds-v0/.tmpmND0UN/lib/python3.12/site-packages/pybind11/include -I/home/utz/qiskit-aer/src -O3 -DNDEBUG -std=c++14 "--generate-code=arch=compute_61,code=[compute_61,sm_61]" -Xcompiler=-fPIC -Xcompiler=-fvisibility=hidden --compiler-options -fopenmp -gencode arch=compute_61,code=sm_61 -DAER_THRUST_GPU -DAER_THRUST_CUDA -I/home/utz/qiskit-aer/src -isystem /home/utz/qiskit-aer/src/third-party/headers -use_fast_math --expt-extended-lambda --compiler-options -mfma --compiler-options -mavx2 -MD -MT qiskit_aer/backends/wrappers/CMakeFiles/controller_wrappers.dir/__/__/__/src/simulators/statevector/qv_avx2.cpp.o -MF qiskit_aer/backends/wrappers/CMakeFiles/controller_wrappers.dir/__/__/__/src/simulators/statevector/qv_avx2.cpp.o.d -x cu -c /home/utz/qiskit-aer/src/simulators/statevector/qv_avx2.cpp -o qiskit_aer/backends/wrappers/CMakeFiles/controller_wrappers.dir/__/__/__/src/simulators/statevector/qv_avx2.cpp.o
/usr/lib/gcc/x86_64-pc-linux-gnu/13.3.0/include/amxtileintrin.h(42): error: identifier "__builtin_ia32_ldtilecfg" is undefined
__builtin_ia32_ldtilecfg (__config);
/usr/lib/gcc/x86_64-pc-linux-gnu/13.3.0/include/amxtileintrin.h(49): error: identifier "__builtin_ia32_sttilecfg" is undefined
__builtin_ia32_sttilecfg (__config);
2 errors detected in the compilation of "/home/utz/qiskit-aer/src/simulators/statevector/qv_avx2.cpp".
To reproduce run:
git clone https://github.com/Qiskit/qiskit-aer -b 0.15.1
export DISABLE_CONAN=ON AER_THRUST_BACKEND=CUDA
cmake -S qiskit-aer -B qiskit-aer/build
make -C qiskit-aer/build
Any idea what the cause might be and how to resolve it?
