Environment: nvCOMP 5.3.0.16 (pip nvidia-nvcomp-cu12), CUDA 12.8, driver 580.82.07,
NVIDIA RTX PRO 6000 Blackwell Server Edition (sm_120), Linux.
A single valid zstd frame (1136 B, content size 8192 B, one compressed block) decodes in ~6 ms with status 0.
The same frame with one byte changed (offset 291, 0x3f → 0xc6, inside the sequences section) makes
nvcompBatchedZstdDecompressAsync run forever: the kernel is still running after 60 s, so
cudaStreamSynchronize never returns. libzstd 1.5.5 rejects the same frame with “Data corruption detected”;
frame and block headers are valid.
Expected: a non-success entry in device_statuses, as for other invalid input.
Actual: the kernel does not terminate; the process has to be killed.
Output:
good.zst: 1136 bytes, frame content size 8192
finished in 5.897 ms: status 0, decompressed 8192 bytes
bad.zst: 1136 bytes, frame content size 8192
HANG: the decompression kernel has not finished after 60 s
Recreate the inputs:
base64 -d good.b64 > good.zst
cp good.zst bad.zst && printf '\xc6' | dd of=bad.zst bs=1 seek=291 conv=notrunc
Build and run (NVCOMP = directory of the pip package nvidia-nvcomp-cu12):
nvcc -O2 -I$NVCOMP/include -L$NVCOMP/lib64 -o repro repro.cu -l:libnvcomp.so.5
export LD_LIBRARY_PATH=$NVCOMP/lib64
./repro good.zst # OK
./repro bad.zst # HANG
good.b64: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=
repro.cu:
// Decode one zstd frame with nvCOMP's batched zstd decompressor (batch of 1).
// Usage: ./repro <frame.zst>
// The decompressed size is read from the frame header (Frame_Content_Size).
// A watchdog polls the stream for 60 s; if the kernel has not finished by then, it prints HANG and exits.
#include <cuda_runtime.h>
#include <nvcomp/zstd.h>
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <thread>
#include <unistd.h>
#include <vector>
#define CK(x) do { cudaError_t e_ = (x); if (e_ != cudaSuccess) { printf("CUDA error %s at line %d\n", cudaGetErrorString(e_), __LINE__); return 2; } } while (0)
static size_t content_size(const std::vector<unsigned char>& f) { // RFC 8878 frame header
if (f.size() < 6 || f[0] != 0x28 || f[1] != 0xB5 || f[2] != 0x2F || f[3] != 0xFD) return 0;
const unsigned fhd = f[4], flag = fhd >> 6, single = (fhd >> 5) & 1, dict = fhd & 3;
const size_t p = 5 + (single ? 0 : 1) + (dict == 3 ? 4 : dict);
const unsigned n = flag == 0 ? (single ? 1 : 0) : (flag == 1 ? 2 : flag == 2 ? 4 : 8);
size_t v = 0;
for (unsigned i = 0; i < n && p + i < f.size(); i++) v |= (size_t)f[p + i] << (8 * i);
return n == 2 ? v + 256 : v;
int main(int argc, char** argv) {
if (argc < 2) { fprintf(stderr, "usage: %s <frame.zst>\n", argv[0]); return 1; }
FILE* fp = fopen(argv[1], "rb");
if (!fp) { perror(argv[1]); return 1; }
std::vector<unsigned char> in;
fseek(fp, 0, SEEK_END); in.resize(ftell(fp)); fseek(fp, 0, SEEK_SET);
if (fread(in.data(), 1, in.size(), fp) != in.size()) return 1;
fclose(fp);
const size_t out_size = content_size(in);
if (!out_size) { printf("no Frame_Content_Size in %s\n", argv[1]); return 1; }
printf("%s: %zu bytes, frame content size %zu\n", argv[1], in.size(), out_size);
void *d_in, *d_out, *d_temp; void **d_in_ptrs, **d_out_ptrs;
size_t *d_in_bytes, *d_out_bytes, *d_actual; nvcompStatus_t* d_status;
size_t temp_bytes = 0;
nvcompStatus_t s = nvcompBatchedZstdDecompressGetTempSizeAsync(1, out_size, nvcompBatchedZstdDecompressDefaultOpts, &temp_bytes, out_size);
if (s != nvcompSuccess) { printf("GetTempSizeAsync: status %d\n", (int)s); return 3; }
CK(cudaMalloc(&d_in, in.size())); CK(cudaMalloc(&d_out, out_size)); CK(cudaMalloc(&d_temp, temp_bytes ? temp_bytes : 1));
CK(cudaMalloc(&d_in_ptrs, sizeof(void*))); CK(cudaMalloc(&d_out_ptrs, sizeof(void*)));
CK(cudaMalloc(&d_in_bytes, sizeof(size_t))); CK(cudaMalloc(&d_out_bytes, sizeof(size_t)));
CK(cudaMalloc(&d_actual, sizeof(size_t))); CK(cudaMalloc(&d_status, sizeof(nvcompStatus_t)));
const size_t in_bytes = in.size();
CK(cudaMemcpy(d_in, in.data(), in.size(), cudaMemcpyHostToDevice));
CK(cudaMemcpy(d_in_ptrs, &d_in, sizeof(void*), cudaMemcpyHostToDevice));
CK(cudaMemcpy(d_out_ptrs, &d_out, sizeof(void*), cudaMemcpyHostToDevice));
CK(cudaMemcpy(d_in_bytes, &in_bytes, sizeof(size_t), cudaMemcpyHostToDevice));
CK(cudaMemcpy(d_out_bytes, &out_size, sizeof(size_t), cudaMemcpyHostToDevice));
cudaStream_t st; CK(cudaStreamCreate(&st));
const auto t0 = std::chrono::steady_clock::now();
s = nvcompBatchedZstdDecompressAsync((const void* const*)d_in_ptrs, d_in_bytes, d_out_bytes, d_actual, 1, d_temp, temp_bytes,
d_out_ptrs, nvcompBatchedZstdDecompressDefaultOpts, d_status, st);
if (s != nvcompSuccess) { printf("DecompressAsync: status %d\n", (int)s); return 3; }
for (;;) { // watchdog: cudaStreamSynchronize would wait forever
const cudaError_t q = cudaStreamQuery(st);
if (q == cudaSuccess) break;
if (q != cudaErrorNotReady) { printf("CUDA error %s\n", cudaGetErrorString(q)); return 2; }
if (std::chrono::duration<double>(std::chrono::steady_clock::now() - t0).count() > 60) {
printf("HANG: the decompression kernel has not finished after 60 s\n"); fflush(stdout); _exit(4);
std::this_thread::sleep_for(std::chrono::milliseconds(1));
CK(cudaStreamSynchronize(st));
const double ms = std::chrono::duration<double, std::milli>(std::chrono::steady_clock::now() - t0).count();
nvcompStatus_t status; size_t actual = 0;
CK(cudaMemcpy(&status, d_status, sizeof status, cudaMemcpyDeviceToHost));
CK(cudaMemcpy(&actual, d_actual, sizeof actual, cudaMemcpyDeviceToHost));
printf("finished in %.3f ms: status %d, decompressed %zu bytes\n", ms, (int)status, actual);
return 0;
