nvCOMP 5.3: ANS FLOAT8_E4M3 single-byte decompression leaves device_statuses unchanged
Hi NVIDIA team,
I have reported a reproducible nvCOMP 5.3 ANS decompression status issue on GitHub, including a complete standalone C++ reproducer and build commands:
When decompressing a chunk containing one uncompressed byte encoded with NVCOMP_TYPE_FLOAT8_E4M3, nvcompBatchedANSDecompressAsync produces the correct output and reports an actual decompressed size of 1. However, device_statuses[0] remains at the sentinel value 0x55555555 that I explicitly initialized before the call, rather than being updated to nvcompSuccess.
All API calls and CUDA synchronization succeed. The reproducer uses only nvCOMP, CUDA Runtime, and the C++ standard library—no framework, model weights, custom allocator, or workspace pool.
Reproducibility
Across 10 separate process invocations:
  • All 40 E4M3 single-byte cases reproduced the unchanged status.
  • All 320 control cases produced correct output and success statuses.
  • A separate Compute Sanitizer memcheck run reproduced the issue and reported 0 errors.
The affected cases include both explicit dtype selection and bitstream autodetection, with both the default and explicit CUDA decompression backends.
E4M3 chunks of 2 and 33 bytes, CHAR chunks of 1, 2 and 33 bytes, and FLOAT16 chunks of 2, 4 and 66 bytes behaved normally.
Environment
  • NVIDIA GeForce RTX 3070 Laptop GPU, compute capability 8.6
  • NVIDIA driver 617.14
  • Ubuntu 22.04.5 container running through WSL2
  • nvCOMP runtime version 5300; reported CUDA build version 13030
  • CUDA toolkit compiler V13.0.88
  • GCC 11.4.0
Only this GPU/environment has been tested.
Question
Could you confirm whether this is a status-write omission in the single-byte E4M3 path, or whether the reproducer violates an undocumented requirement?
Calling nvcompBatchedANSDecompressGetTempSizeSync first writes a success status, which remains successful after decoding. However, that does not establish that DecompressAsync itself updates the status. Is the synchronous query required before the Async-query/DecompressAsync sequence?
Please use the linked GitHub issue as the primary report; I am cross-posting here for visibility and guidance.
Thank you.
