When pulling from nvcr.io with the standard Docker Registry v2 bearer-token flow, we noticed that the token realm the registry advertises changes across the auth lifecycle, which leaves an anonymous client unable to refresh once its token expires.
- On the first request with no token, the registry returns
401with a challenge whose realm ishttps://nvcr.io/proxy_auth. - Following that realm anonymously returns
200 OKwith a bearer token (apullgrant for public repos), and the pull succeeds. - When that token expires and the client retries, the registry returns
401— but now the challenge points to a different realm,https://authn.nvidia.com/tokenwithservice="registry"anderror="invalid_token". - A client normally refreshes by following the realm in the challenge it just received. Following this second realm anonymously returns
401with no token — whereas the first realm (nvcr.io/proxy_auth) still issues one. So the client, having correctly followed the advertised realm, has no way to obtain a fresh token and the pull dead-ends.
In other words, the realm advertised when unauthenticated (nvcr.io/proxy_auth, which issues tokens anonymously) is not the realm advertised after a token is presented and rejected (authn.nvidia.com/token, which does not) — so anonymous token refresh after expiry terminates on a 401.
We also noticed the registry keeps accepting an expired token for a short grace window (still 200 shortly past the token’s exp, rejected a few minutes later) — a secondary inconsistency, though the realm switch above is the part that breaks refresh.
Expected behavior
- The registry should advertise a consistent token realm/
serviceacross the auth lifecycle — the realm in the post-expiry401should be the same one advertised on the initial401, so a client that follows the advertised realm can obtain a fresh token and retry. - If the intended realm is
authn.nvidia.com/token, it should be the one advertised from the start (and it should issue tokens for anonymous pulls of public content the same waynvcr.io/proxy_authdoes).
*To Reproduce
# 1) no token -> 401, realm A = nvcr.io/proxy_auth
curl -sS -D - -o /dev/null -H "Accept: application/vnd.oci.image.index.v1+json" \
https://nvcr.io/v2/nvidia/tritonserver/manifests/sha256:58df7489c3f2276f9591d500a012dee03e23d35543ce3c390b4c001e6bf90794
# 401 ; WWW-Authenticate: Bearer realm="https://nvcr.io/proxy_auth",scope="repository:nvidia/tritonserver:pull"
# 2) follow realm A anonymously -> 200 + token (pull grant); the pull works
curl -sS "https://nvcr.io/proxy_auth?scope=repository:nvidia/tritonserver:pull"
# 200 ; {"token":"<jwt, ~10 min lifetime>"}
# 3) after the token expires, retry -> 401, realm B = authn.nvidia.com/token (DIFFERENT)
curl -sS -D - -o /dev/null -H "Authorization: Bearer <expired token from step 2>" \
https://nvcr.io/v2/nvidia/tritonserver/manifests/sha256:58df7489...
# 401 ; WWW-Authenticate: Bearer realm="https://authn.nvidia.com/token",service="registry",scope="repository:nvidia/tritonserver:pull",error="invalid_token"
# 4) follow realm B anonymously -> 401, no token issued (refresh dead-ends)
curl -sS -D - -o /dev/null "https://authn.nvidia.com/token?service=registry&scope=repository:nvidia/tritonserver:pull"
# 401
# (contrast) realm A still issues a token anonymously
curl -sS -D - -o /dev/null "https://nvcr.io/proxy_auth?scope=repository:nvidia/tritonserver:pull"
# 200
