Nvcr.io/nvidia/vllm:25.12-py3 Fails to Execute Qwen3-VL-8B Image Inference with Engine Error
I pulled the following container: nvcr.io/nvidia/vllm:25.12-py3. The run command is as follows:
sudo docker run --platform linux/arm64 --runtime=nvidia -itd
–name qwen_vl_service
–gpus all
-p 8000:8000
-v /home/cv/LM/qwen3:/model
-v /home/cv/AI/qWen3-VL-Server:/app
–ipc=host
–ulimit memlock=-1
–ulimit stack=67108864
–env TORCH_CUDA_ARCH_LIST=“11.0a”
–env VLLM_WORKER_MULTIPROC_METHOD=“fork”
–env TRITON_PTXAS_PATH=“/usr/local/cuda/bin/ptxas”
–env PATH=“/usr/local/cuda/bin:$PATH”
–env LD_LIBRARY_PATH=“/usr/local/cuda/lib64:$LD_LIBRARY_PATH”
bash -c "
vllm serve /model
–trust-remote-code
–dtype bfloat16
–gpu-memory-utilization 0.55
–enforce-eager
–disable-log-stats
–port 8000
–skip-mm-profiling
–limit-mm-per-prompt ‘{“image”:5,“video”:0}’
It has been verified that vLLM can load the model normally and perform pure text inference, but it crashes when performing image inference. The core error is:
(APIServer pid=144) (EngineCore_DP0 pid=183) RuntimeError: GET was unable to find an engine to execute this computation.
Detailed startup and runtime logs are as follows:cv@cv:~/AI/qWen3-VL-Server$ sudo docker logs -f qwen_vl_service
== vLLM ==
NVIDIA Release 25.12 (build 245720122)
vLLM Version 0.11.1+9114fd76
Container image Copyright (c) 2025, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
GOVERNING TERMS: The software and materials are governed by the NVIDIA Software License Agreement
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/nvidia-software-license-agreement/)
and the Product-Specific Terms for NVIDIA AI Products
(found at https://www.nvidia.com/en-us/agreements/enterprise-software/product-specific-terms-for-ai-products/).
WARNING: CUDA Minor Version Compatibility mode ENABLED.
Using driver version 580.00 which has support for CUDA 13.0. This container
was built with CUDA 13.1 and will be run in Minor Version Compatibility mode.
CUDA Forward Compatibility is preferred over Minor Version Compatibility for use
with this container but was unavailable:
[[System has unsupported display driver / cuda driver combination (CUDA_ERROR_SYSTEM_DRIVER_MISMATCH) cuInit()=803]]
See CUDA Compatibility — CUDA Compatibility for details.
/usr/local/lib/python3.12/dist-packages/torchvision/io/image.py:14: UserWarning: Failed to load image Python extension: ‘Could not load this library: /usr/local/lib/python3.12/dist-packages/torchvision/image.so’If you don’t plan on using image functionality from torchvision.io, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have libjpeg or libpng installed before building torchvision from source?
warn(
INFO 01-06 01:29:54 [scheduler.py:216] Chunked prefill is enabled with max_num_batched_tokens=2048.
(APIServer pid=144) INFO 01-06 01:29:54 [api_server.py:1980] vLLM API server version 0.11.1+9114fd76.nv25.12
(APIServer pid=144) INFO 01-06 01:29:54 [utils.py:253] non-default args: {‘model_tag’: ‘/model’, ‘model’: ‘/model’, ‘trust_remote_code’: True, ‘dtype’: ‘bfloat16’, ‘enforce_eager’: True, ‘gpu_memory_utilization’: 0.55, ‘limit_mm_per_prompt’: {‘image’: 5, ‘video’: 0}, ‘skip_mm_profiling’: True, ‘disable_log_stats’: True}
(APIServer pid=144) The argument trust_remote_code is to be used with Auto classes. It has no effect here and is ignored.
(APIServer pid=144) INFO 01-06 01:29:59 [model.py:631] Resolved architecture: Qwen3VLForConditionalGeneration
(APIServer pid=144) INFO 01-06 01:29:59 [model.py:1745] Using max model len 262144
(APIServer pid=144) INFO 01-06 01:29:59 [scheduler.py:216] Chunked prefill is enabled with max_num_batched_tokens=2048.
(APIServer pid=144) INFO 01-06 01:29:59 [vllm.py:500] Cudagraph is disabled under eager mode
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:00 [core.py:93] Initializing a V1 LLM engine (v0.11.1+9114fd76.nv25.12) with config: model=’/model’, speculative_config=None, tokenizer=‘/model’, skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=True, dtype=torch.bfloat16, max_seq_len=262144, download_dir=None, load_format=auto, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, disable_custom_all_reduce=False, quantization=None, enforce_eager=True, kv_cache_dtype=auto, device_config=cuda, structured_outputs_config=StructuredOutputsConfig(backend=‘auto’, disable_fallback=False, disable_any_whitespace=False, disable_additional_properties=False, reasoning_parser=‘’, reasoning_parser_plugin=‘’, enable_in_reasoning=False), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None), seed=0, served_model_name=/model, enable_prefix_caching=True, enable_chunked_prefill=True, pooler_config=None, compilation_config={‘level’: None, ‘mode’: <CompilationMode.NONE: 0>, ‘debug_dump_path’: None, ‘cache_dir’: ‘’, ‘compile_cache_save_format’: ‘binary’, ‘backend’: ‘inductor’, ‘custom_ops’: [‘all’], ‘splitting_ops’: None, ‘compile_mm_encoder’: False, ‘use_inductor’: None, ‘compile_sizes’: , ‘inductor_compile_config’: {‘enable_auto_functionalized_v2’: False, ‘combo_kernels’: True, ‘benchmark_combo_kernel’: True}, ‘inductor_passes’: {}, ‘cudagraph_mode’: <CUDAGraphMode.NONE: 0>, ‘cudagraph_num_of_warmups’: 0, ‘cudagraph_capture_sizes’: , ‘cudagraph_copy_inputs’: False, ‘cudagraph_specialize_lora’: True, ‘use_inductor_graph_partition’: False, ‘pass_config’: {}, ‘max_cudagraph_capture_size’: 0, ‘local_cache_dir’: None}
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:00 [parallel_state.py:1208] world_size=1 rank=0 local_rank=0 distributed_init_method=tcp://172.17.0.2:60861 backend=nccl
[Gloo] Rank 0 is connected to 0 peer ranks. Expected number of connected peer ranks is : 0
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:00 [parallel_state.py:1394] rank 0 in world size 1 is assigned as DP rank 0, PP rank 0, TP rank 0, EP rank 0
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:08 [gpu_model_runner.py:3255] Starting to load model /model…
(APIServer pid=144) (EngineCore_DP0 pid=183) /usr/local/lib/python3.12/dist-packages/torch/library.py:356: UserWarning: Warning only once for all operators, other operators may also be overridden.
(APIServer pid=144) (EngineCore_DP0 pid=183) Overriding a previously registered kernel for the same operator and the same dispatch key
(APIServer pid=144) (EngineCore_DP0 pid=183) operator: flash_attn::_flash_attn_backward(Tensor dout, Tensor q, Tensor k, Tensor v, Tensor out, Tensor softmax_lse, Tensor(a6!)? dq, Tensor(a7!)? dk, Tensor(a8!)? dv, float dropout_p, float softmax_scale, bool causal, SymInt window_size_left, SymInt window_size_right, float softcap, Tensor? alibi_slopes, bool deterministic, Tensor? rng_state=None) → Tensor
(APIServer pid=144) (EngineCore_DP0 pid=183) registered at /usr/local/lib/python3.12/dist-packages/torch/_library/custom_ops.py:922
(APIServer pid=144) (EngineCore_DP0 pid=183) dispatch key: ADInplaceOrView
(APIServer pid=144) (EngineCore_DP0 pid=183) previous kernel: no debug info
(APIServer pid=144) (EngineCore_DP0 pid=183) new kernel: registered at /usr/local/lib/python3.12/dist-packages/torch/_library/custom_ops.py:922 (Triggered internally at /opt/pytorch/pytorch/aten/src/ATen/core/dispatch/OperatorEntry.cpp:208.)
(APIServer pid=144) (EngineCore_DP0 pid=183) self.m.impl(
(APIServer pid=144) (EngineCore_DP0 pid=183) WARNING 01-06 01:30:08 [qwen2_5_vl.py:366] Flash attention backend requires head_dim to be a multiple of 32, but got 72. Falling back to TORCH_SDPA backend.
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:24 [cuda.py:418] Valid backends: [‘FLASH_ATTN’, ‘FLASHINFER’, ‘TRITON_ATTN’, ‘FLEX_ATTENTION’]
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:24 [cuda.py:427] Using FLASH_ATTN backend.
Loading safetensors checkpoint shards: 0% Completed | 0/4 [00:00<?, ?it/s]
Loading safetensors checkpoint shards: 25% Completed | 1/4 [00:01<00:04, 1.59s/it]
Loading safetensors checkpoint shards: 50% Completed | 2/4 [00:03<00:03, 1.66s/it]
Loading safetensors checkpoint shards: 75% Completed | 3/4 [00:04<00:01, 1.37s/it]
Loading safetensors checkpoint shards: 100% Completed | 4/4 [00:05<00:00, 1.47s/it]
Loading safetensors checkpoint shards: 100% Completed | 4/4 [00:05<00:00, 1.49s/it]
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:31 [default_loader.py:314] Loading weights took 6.10 seconds
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:31 [gpu_model_runner.py:3334] Model loading took 16.6397 GiB memory and 22.955288 seconds
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:32 [gpu_model_runner.py:4067] Skipping memory profiling for multimodal encoder and encoder cache.
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:34 [gpu_worker.py:359] Available KV cache memory: 46.32 GiB
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:34 [kv_cache_utils.py:1229] GPU KV cache size: 337,312 tokens
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:34 [kv_cache_utils.py:1234] Maximum concurrency for 262,144 tokens per request: 1.29x
(APIServer pid=144) (EngineCore_DP0 pid=183) 2026-01-06 01:30:35,902 - INFO - autotuner.py:256 - flashinfer.jit: [Autotuner]: Autotuning process starts …
(APIServer pid=144) (EngineCore_DP0 pid=183) 2026-01-06 01:30:35,930 - INFO - autotuner.py:262 - flashinfer.jit: [Autotuner]: Autotuning process ends
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:36 [core.py:250] init engine (profile, create kv cache, warmup model) took 4.60 seconds
(APIServer pid=144) (EngineCore_DP0 pid=183) INFO 01-06 01:30:41 [vllm.py:500] Cudagraph is disabled under eager mode
(APIServer pid=144) INFO 01-06 01:30:41 [api_server.py:1728] Supported tasks: [‘generate’]
(APIServer pid=144) WARNING 01-06 01:30:41 [model.py:1568] Default sampling parameters have been overridden by the model’s Hugging Face generation config recommended from the model creator. If this is not intended, please relaunch vLLM instance with --generation-config vllm.
(APIServer pid=144) INFO 01-06 01:30:41 [serving_responses.py:154] Using default chat sampling params from model: {‘temperature’: 0.7, ‘top_k’: 20, ‘top_p’: 0.8}
(APIServer pid=144) INFO 01-06 01:30:41 [serving_chat.py:131] Using default chat sampling params from model: {‘temperature’: 0.7, ‘top_k’: 20, ‘top_p’: 0.8}
(APIServer pid=144) INFO 01-06 01:30:41 [serving_completion.py:73] Using default completion sampling params from model: {‘temperature’: 0.7, ‘top_k’: 20, ‘top_p’: 0.8}
(APIServer pid=144) INFO 01-06 01:30:41 [api_server.py:2055] Starting vLLM API server 0 on http://0.0.0.0:8000
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:38] Available routes are:
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /openapi.json, Methods: HEAD, GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /docs, Methods: HEAD, GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /docs/oauth2-redirect, Methods: HEAD, GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /redoc, Methods: HEAD, GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /health, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /load, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /tokenize, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /detokenize, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/models, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /version, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/responses, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/responses/{response_id}, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/responses/{response_id}/cancel, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/messages, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/chat/completions, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/completions, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/embeddings, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /pooling, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /classify, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /score, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/score, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/audio/transcriptions, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/audio/translations, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /rerank, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v1/rerank, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /v2/rerank, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /scale_elastic_ep, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /is_scaling_elastic_ep, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /inference/v1/generate, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /ping, Methods: GET
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /ping, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /invocations, Methods: POST
(APIServer pid=144) INFO 01-06 01:30:41 [launcher.py:46] Route: /metrics, Methods: GET
(APIServer pid=144) INFO: Started server process [144]
(APIServer pid=144) INFO: Waiting for application startup.
(APIServer pid=144) INFO: Application startup complete.
(APIServer pid=144) INFO 01-06 01:30:50 [chat_utils.py:557] Detected the chat template content format to be ‘openai’. You can set --chat-template-content-format to override this.
(APIServer pid=144) INFO: 10.19.120.171:51819 - “POST /v1/chat/completions HTTP/1.1” 200 OK
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:72] Dumping input data for V1 LLM engine (v0.11.1+9114fd76.nv25.12) with config: model=‘/model’, speculative_config=None, tokenizer=‘/model’, skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=True, dtype=torch.bfloat16, max_seq_len=262144, download_dir=None, load_format=auto, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, disable_custom_all_reduce=False, quantization=None, enforce_eager=True, kv_cache_dtype=auto, device_config=cuda, structured_outputs_config=StructuredOutputsConfig(backend=‘auto’, disable_fallback=False, disable_any_whitespace=False, disable_additional_properties=False, reasoning_parser=‘’, reasoning_parser_plugin=‘’, enable_in_reasoning=False), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None), seed=0, served_model_name=/model, enable_prefix_caching=True, enable_chunked_prefill=True, pooler_config=None, compilation_config={‘level’: None, ‘mode’: <CompilationMode.NONE: 0>, ‘debug_dump_path’: None, ‘cache_dir’: ‘’, ‘compile_cache_save_format’: ‘binary’, ‘backend’: ‘inductor’, ‘custom_ops’: [‘all’], ‘splitting_ops’: None, ‘compile_mm_encoder’: False, ‘use_inductor’: None, ‘compile_sizes’: , ‘inductor_compile_config’: {‘enable_auto_functionalized_v2’: False, ‘combo_kernels’: True, ‘benchmark_combo_kernel’: True}, ‘inductor_passes’: {}, ‘cudagraph_mode’: <CUDAGraphMode.NONE: 0>, ‘cudagraph_num_of_warmups’: 0, ‘cudagraph_capture_sizes’: , ‘cudagraph_copy_inputs’: False, ‘cudagraph_specialize_lora’: True, ‘use_inductor_graph_partition’: False, ‘pass_config’: {}, ‘max_cudagraph_capture_size’: 0, ‘local_cache_dir’: None},
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] Dumping scheduler output for model execution: SchedulerOutput(scheduled_new_reqs=[NewRequestData(req_id=chatcmpl-d3947879b8574b228701fbba28997aaa,prompt_token_ids_len=4773,mm_features=[MultiModalFeatureSpec(data={‘image_grid_thw’: MultiModalFieldElem(modality=‘image’, key=‘image_grid_thw’, data=tensor([ 1, 244, 78]), field=MultiModalBatchedField()), ‘pixel_values’: MultiModalFieldElem(modality=‘image’, key=‘pixel_values’, data=tensor([[-0.9062, -0.9062, -0.9062, …, 0.6484, 0.6484, 0.6484],
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] [-0.9062, -0.9062, -0.9062, …, 0.6328, 0.6328, 0.6328],
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] [-0.8984, -0.9141, -0.8984, …, 0.6328, 0.6484, 0.6328],
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] …,
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] [-0.5938, -0.5938, -0.5938, …, 0.6016, 0.6016, 0.6016],
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] [-0.5938, -0.5938, -0.5938, …, 0.6016, 0.6016, 0.6016]],
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [dump_input.py:79] dtype=torch.bfloat16), field=MultiModalFlatField(slices=[[slice(0, 19032, None)]], dim=0))}, modality=‘image’, identifier=‘cd8838b8a6eef80b2311a56f147b1a3afe3a998f8089fac62e4e3824ab88db15’, mm_position=PlaceholderRange(offset=9, length=4758, is_embed=None))],sampling_params=SamplingParams(n=1, presence_penalty=0.0, frequency_penalty=0.0, repetition_penalty=1.0, temperature=0.7, top_p=0.8, top_k=20, min_p=0.0, seed=None, stop=, stop_token_ids=[151643], bad_words=, include_stop_str_in_output=False, ignore_eos=False, max_tokens=256, min_tokens=0, logprobs=None, prompt_logprobs=None, skip_special_tokens=True, spaces_between_special_tokens=True, truncate_prompt_tokens=None, structured_outputs=None, extra_args=None),block_ids=([6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133],),num_computed_tokens=0,lora_request=None,prompt_embeds_shape=None)], scheduled_cached_reqs=CachedRequestData(req_ids=, resumed_req_ids=, new_token_ids=, all_token_ids={}, new_block_ids=, num_computed_tokens=, num_output_tokens=), num_scheduled_tokens={chatcmpl-d3947879b8574b228701fbba28997aaa: 2048}, total_num_scheduled_tokens=2048, scheduled_spec_decode_tokens={}, scheduled_encoder_inputs={chatcmpl-d3947879b8574b228701fbba28997aaa: [0]}, num_common_prefix_blocks=[128], finished_req_ids=, free_encoder_mm_hashes=, pending_structured_output_tokens=false, kv_connector_metadata=null, ec_connector_metadata=null)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] EngineCore encountered a fatal error.
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] Traceback (most recent call last):
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 835, in run_engine_core
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] engine_core.run_busy_loop()
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 862, in run_busy_loop
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] self._process_engine_step()
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 891, in _process_engine_step
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] outputs, model_executed = self.step_fn()
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 342, in step
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] model_output = future.result()
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/lib/python3.12/concurrent/futures/_base.py”, line 449, in result
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return self.__get_result()
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/lib/python3.12/concurrent/futures/_base.py”, line 401, in __get_result
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] raise self._exception
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/uniproc_executor.py”, line 79, in collective_rpc
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] result = run_method(self.driver_worker, method, args, kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py”, line 479, in run_method
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return func(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py”, line 367, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return self.worker.execute_model(scheduler_output, *args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py”, line 124, in decorate_context
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py”, line 563, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] output = self.model_runner.execute_model(
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 2753, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] ) = self._preprocess(
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 2328, in _preprocess
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] self._execute_mm_encoder(scheduler_output)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 1975, in _execute_mm_encoder
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] curr_group_outputs = model.embed_multimodal(**mm_kwargs_group)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 1496, in embed_multimodal
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] image_embeddings = self._process_image_input(multimodal_input)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 1375, in _process_image_input
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] image_embeds = self.visual(pixel_values, grid_thw=grid_thw)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1783, in _wrapped_call_impl
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return self._call_impl(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1794, in _call_impl
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return forward_call(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 540, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] hidden_states = self.patch_embed(hidden_states)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 151, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] x = self.proj(x).view(L, self.hidden_size)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/custom_op.py”, line 46, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return self._forward_method(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py”, line 236, in forward_cuda
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] return self._forward_conv(x)
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py”, line 210, in _forward_conv
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] x = F.conv3d(
(APIServer pid=144) (EngineCore_DP0 pid=183) ERROR 01-06 01:31:06 [core.py:844] RuntimeError: GET was unable to find an engine to execute this computation
(APIServer pid=144) (EngineCore_DP0 pid=183) Process EngineCore_DP0:
(APIServer pid=144) (EngineCore_DP0 pid=183) Traceback (most recent call last):
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] AsyncLLM output_handler failed.
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] Traceback (most recent call last):
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/async_llm.py”, line 477, in output_handler
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] outputs = await engine_core.get_output_async()
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py”, line 883, in get_output_async
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] raise self._format_exception(outputs) from None
(APIServer pid=144) ERROR 01-06 01:31:06 [async_llm.py:525] vllm.v1.engine.exceptions.EngineDeadError: EngineCore encountered an issue. See stack trace (above) for the root cause.
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/lib/python3.12/multiprocessing/process.py”, line 314, in _bootstrap
(APIServer pid=144) (EngineCore_DP0 pid=183) self.run()
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/lib/python3.12/multiprocessing/process.py”, line 108, in run
(APIServer pid=144) (EngineCore_DP0 pid=183) self._target(*self._args, **self._kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 846, in run_engine_core
(APIServer pid=144) (EngineCore_DP0 pid=183) raise e
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 835, in run_engine_core
(APIServer pid=144) (EngineCore_DP0 pid=183) engine_core.run_busy_loop()
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 862, in run_busy_loop
(APIServer pid=144) (EngineCore_DP0 pid=183) self._process_engine_step()
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 891, in _process_engine_step
(APIServer pid=144) (EngineCore_DP0 pid=183) outputs, model_executed = self.step_fn()
(APIServer pid=144) (EngineCore_DP0 pid=183) ^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py”, line 342, in step
(APIServer pid=144) (EngineCore_DP0 pid=183) model_output = future.result()
(APIServer pid=144) (EngineCore_DP0 pid=183) ^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/lib/python3.12/concurrent/futures/_base.py”, line 449, in result
(APIServer pid=144) (EngineCore_DP0 pid=183) return self.__get_result()
(APIServer pid=144) (EngineCore_DP0 pid=183) ^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/lib/python3.12/concurrent/futures/_base.py”, line 401, in __get_result
(APIServer pid=144) (EngineCore_DP0 pid=183) raise self._exception
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/uniproc_executor.py”, line 79, in collective_rpc
(APIServer pid=144) (EngineCore_DP0 pid=183) result = run_method(self.driver_worker, method, args, kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py”, line 479, in run_method
(APIServer pid=144) (EngineCore_DP0 pid=183) return func(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py”, line 367, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) return self.worker.execute_model(scheduler_output, *args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py”, line 124, in decorate_context
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py”, line 563, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) output = self.model_runner.execute_model(
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 2753, in execute_model
(APIServer pid=144) (EngineCore_DP0 pid=183) ) = self._preprocess(
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 2328, in _preprocess
(APIServer pid=144) (EngineCore_DP0 pid=183) self._execute_mm_encoder(scheduler_output)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py”, line 1975, in _execute_mm_encoder
(APIServer pid=144) (EngineCore_DP0 pid=183) curr_group_outputs = model.embed_multimodal(**mm_kwargs_group)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 1496, in embed_multimodal
(APIServer pid=144) (EngineCore_DP0 pid=183) image_embeddings = self._process_image_input(multimodal_input)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 1375, in _process_image_input
(APIServer pid=144) (EngineCore_DP0 pid=183) image_embeds = self.visual(pixel_values, grid_thw=grid_thw)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1783, in _wrapped_call_impl
(APIServer pid=144) (EngineCore_DP0 pid=183) return self._call_impl(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1794, in _call_impl
(APIServer pid=144) (EngineCore_DP0 pid=183) return forward_call(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 540, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) hidden_states = self.patch_embed(hidden_states)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/qwen3_vl.py”, line 151, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) x = self.proj(x).view(L, self.hidden_size)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/custom_op.py”, line 46, in forward
(APIServer pid=144) (EngineCore_DP0 pid=183) return self._forward_method(*args, **kwargs)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py”, line 236, in forward_cuda
(APIServer pid=144) (EngineCore_DP0 pid=183) return self._forward_conv(x)
(APIServer pid=144) (EngineCore_DP0 pid=183) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py”, line 210, in _forward_conv
(APIServer pid=144) (EngineCore_DP0 pid=183) x = F.conv3d(
(APIServer pid=144) INFO: 10.19.120.171:51823 - “POST /v1/chat/completions HTTP/1.1” 500 Internal Server Error
(APIServer pid=144) INFO: Shutting down
(APIServer pid=144) INFO: Waiting for application shutdown.
(APIServer pid=144) INFO: Application shutdown complete.
(APIServer pid=144) INFO: Finished server process [144]
There is a newer nvcr.io/nvidia/vllm:25.12.post1-py3 container.
Could you try if the same issue occurs?
I am pulling nvcr.io/nvidia/sglang:25.12-py3 to serve Qwen3-VL-8B and failed with similar errors. Are they related?
my docker compose file
services:
  vlm-service:
build:
context: .
dockerfile: Dockerfile
shm_size: 32g
image: vlm-service:latest
container_name: vlm-service
network_mode: host
ipc: host
privileged: true
volumes:
      - ~/.cache/huggingface:/root/.cache/huggingface
ulimits:
memlock: -1
stack: 67108864
stdin_open: true
tty: true
# command: /bin/bash
logging:
driver: "json-file"
options:
max-size: "50m"
max-file: "5"
restart: no
runtime: nvidia
[2026-01-05 22:21:12] Scheduler hit an exception: Traceback (most recent call last):
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/scheduler.py”, line 2725, in run_scheduler_process
scheduler.event_loop_overlap()
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/scheduler.py”, line 1019, in event_loop_overlap
batch_result = self.run_batch(batch)
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/scheduler.py”, line 2021, in run_batch
batch_result = self.model_worker.forward_batch_generation(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/tp_worker.py”, line 371, in forward_batch_generation
logits_output, can_run_cuda_graph = self.model_runner.forward(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/model_executor/model_runner.py”, line 2160, in forward
output = self._forward_raw(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/model_executor/model_runner.py”, line 2217, in _forward_raw
ret = self.forward_extend(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/model_executor/model_runner.py”, line 2105, in forward_extend
return self.model.forward(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/models/qwen3_vl.py”, line 734, in forward
hidden_states = general_mm_embed_routine(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/mm_utils.py”, line 681, in general_mm_embed_routine
inputs_embeds, other_info = embed_mm_inputs(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/mm_utils.py”, line 572, in embed_mm_inputs
embedding, mask = get_embedding_and_mask(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/mm_utils.py”, line 477, in get_embedding_and_mask
embedding = _get_chunked_prefill_embedding(
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/managers/mm_utils.py”, line 387, in _get_chunked_prefill_embedding
embedding_per_req = data_embedding_func(embedding_items_per_req)
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/models/qwen3_vl.py”, line 678, in get_image_feature
image_embeds = self.visual(pixel_values, grid_thw=image_grid_thw)
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/models/qwen3_vl.py”, line 445, in forward
x = self.patch_embed(x)
File “/usr/local/lib/python3.12/dist-packages/sglang/srt/models/qwen3_vl.py”, line 118, in forward
hidden_states = self.proj(hidden_states.to(dtype=target_dtype)).view(
File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/conv.py”, line 723, in forward
return self._conv_forward(input, self.weight, self.bias)
File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/conv.py”, line 718, in _conv_forward
return F.conv3d(
When I use nvcr.io/nvidia/vllm:25.12.post1-py3 for inference, I encountered the same error:
(APIServer pid=145) (EngineCore_DP0 pid=184) File “/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py”, line 230, in _forward_conv
(APIServer pid=145) (EngineCore_DP0 pid=184) x = F.conv3d(
(APIServer pid=145) (EngineCore_DP0 pid=184) ^^^^^^^^^
(APIServer pid=145) (EngineCore_DP0 pid=184) RuntimeError: GET was unable to find an engine to execute this computation
Yes, I believe we encountered the same error. However, when using the official qwen_vl_utils from Qwen, image inference can proceed normally. Nevertheless, for optimal compatibility, I still hope that containers like nvcr.io/nvidia/vllm:25.12.post1-py3 can resolve this issue.
edit: just noticed you said “image”. when I started vllm with this command it said that and that’s probably the cause of your problem.
/usr/local/lib/python3.12/dist-packages/torchvision/io/image.py:14: UserWarning: Failed to load image Python extension: 'Could not load this library: /usr/local/lib/python3.12/dist-packages/torchvision/image.so'If you don't plan on using image functionality from `torchvision.io`, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have `libjpeg` or `libpng` installed before building `torchvision` from source?
This just worked for me.
docker run --name vllm --rm -it --network host \
  --runtime=nvidia --gpus all --ipc=host \
  --ulimit memlock=-1 --ulimit stack=67108864 --shm-size=16g \
  -e VLLM_WORKER_MULTIPROC=0 \
  -e HF_HOME=/root/.cache/huggingface \
  -v "$HOME/.cache:/root/.cache" \
  nvcr.io/nvidia/vllm:25.12.post1-py3 \
  python3 -m vllm.entrypoints.openai.api_server \
    --model nvidia/Qwen3-30B-A3B-NVFP4 \
    --host 0.0.0.0 --port 8000 \
    --tensor-parallel-size 1 \
    --max-model-len 512 \
    --max-num-seqs 2 \
    --gpu-memory-utilization 0.25 \
    --kv-cache-dtype=auto
In another terminal
curl -X 'POST' 'http://127.0.0.1:8000/v1/chat/completions' -H 'accept: application/json' -H 'Content-Type: application/json' -d '{
"model": "nvidia/Qwen3-30B-A3B-NVFP4",
"messages": [{"role":"user", "content": "What are Chihuahuas famous for?"}]
}' |jq
I have no issues with text inference; the problem only occurs during image inference. Are you referring to text inference or image inference when you say there’s no problem?
Thank you very much for your response. Regarding the issue you mentioned about the torchvision warning causing image inference failure, I would like to clarify:
The torchvision warning is not the root cause of the inference failure. As can be clearly seen in the logs, the actual error is:
text
This error occurs during the execution of F.conv3d, specifically in the patch_embed layer of the Qwen3-VL model’s visual processing module (qwen3_vl.py).
I added -e TORCH_CUDNN_V8_API_DISABLED=1 thinking it might help.
I don’t have image or video so I did not include --limit-mm-per-prompt ‘{“image”:5,“video”:0}’
Following worked to start vllm. With the same torchvision complaint. If you try it change to your model. and -v
  -e TORCH_CUDNN_V8_API_DISABLED=1 \
  -e TORCH_CUDA_ARCH_LIST="11.0a" \
  -e VLLM_WORKER_MULTIPROC_METHOD="fork" \
  -e TRITON_PTXAS_PATH="/usr/local/cuda/bin/ptxas" \
vllm serve --model nvidia/Qwen3-30B-A3B-NVFP4 \
  --trust-remote-code \
  --dtype bfloat16 \
  --enforce-eager \
  --disable-log-stats \
  --port 8000 \
  --skip-mm-profiling \
  --limit-mm-per-prompt '{\"image\":5,\"video\":0}'
Thank you very much. Adding -e TORCH_CUDNN_V8_API_DISABLED=1 indeed worked, but the inference speed seems to have decreased significantly.
You could try --dtype half and unset TORCH_CUDNN_V8_API_DISABLED
vllm serve --model yourmodel \
  --dtype half \
  --enforce-eager \
  --port 8000 \
Or try this to modify F.conv3d. Then restart vllm
sed -i '/def _forward_conv/,/return x/{
/def _forward_conv/a\
        x = x.contiguous()\
        orig_dtype = x.dtype\
        if orig_dtype == torch.bfloat16:\
            x = x.to(torch.float16)\
            w = self.weight.to(torch.float16)\
            b = None if self.bias is None else self.bias.to(torch.float16)\
        else:\
            w = self.weight\
            b = self.bias
/return x/i\
            x = x.to(torch.bfloat16)
}' /usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/conv.py
If they don’t help, for now maybe keep TORCH_CUDNN_V8_API_DISABLED=1
