NVCSI access in Jetpack 36.4 on an Jetson AGX Orin Developer Kit
Hi
i am debugging some CSI lines and VI configurations into an Orin AGX DevKit. whenever i try to read something via
sudo busybox devmem 0x15a0c710
it returns
0xffffffff
when i try to follow the steps as recommended for older versions of Jetpack like
or
it then results with the system hanging and becoming unresponsive.
what steps should i follow to be able to access the NVCIS or VI registers as defined in the TRM section 7.2?
After disabled the firewall you also need to launch the camera to turn of the power gate to access the NVCSI/VI REG.
