NvDCF tracker get different results running application from cmd vs. docker container
Jetson Nano
• DeepStream Version
5.0
4.4
• TensorRT Version
TensorRT: 7.0.0
bugs, tracker
nvcr.io/nvidia/deepstream:5.0-20.07-base
Customerized pipeline with pgie + nvdcf tracker
I have noticed some lingering bbox problem, so change some params in tracker_config.yml from the default one in /config/deepstream-app/
Test by running the application from cmd on test videos, the lingering bbox was removed.
So deploy in production which is running the same application with same tracker_config.yml from docker container. nvcr.io/nvidia/deepstream:5.0-20.07-base
Although lingering bbox was removed, lots of objects are missed/not tracked when running app in docker container
quite different results compared with when running the application from cmd, on the same test video with same tracker_config.yml
Puzzeled why nvdcf tracker yields different results with same config when running app from cmd vs. docker container
on the same nano device.
Please find the tracker_config.yml attached. Thank you very much.
tracker_config.yml (6.6 KB)
Hey customer,
The behaviour should be same within or without docker, could you check “cat /opt/nvidia/deepstream/deepstream-5.0/version” to check if DS are on the same version.
