NVdCF tracker issue with 2 T4
• Hardware Platform Nvidia Tesla T4
• DeepStream Version 5.1
• TensorRT Version 7.2.2.3
• NVIDIA GPU Driver Version (valid for GPU only) 460.32…03
• Issue Type( questions, new requirements, bugs) question
Hi, while running deepstream with NVDCF tracker with 2 T4 , i am getting the error-
“GPUassert: invalid device ordinal src/modules/NvDCF/NvDCF.cpp 1250”
No idea with this as it is running fine when using KLT tracker.
Please suggest…
KLT tracker does not use GPU.
Can you run the sample without nvdcf tracker?
As i already said, it works with KLT tracker.
Also without nvdcf tracker it works
Can you specify how we could repro your issue with nvdcf tracker?
I am using 16 cameras with 2T4. OS is Redhat8.
For 8 cameras i have provided gpu-id=0 and rest gpu-id=1
Also checked “nvbuf-memory-type=0/3”.
But when i used KLT, then i have to make nvbuf-memory-type=0 and it runs.
With NvDCF, nothing works and same error for GPUassert.
Can you share the configuration run failed?
