NvDCF tracker output video vibration issue (again)
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2, Docker Image nvcr.io/nvidia/deepstream:6.2-base
• TensorRT Version 8.5.0.2
• NVIDIA GPU Driver Version (valid for GPU only) 530.41.03
• Issue Type( questions, new requirements, bugs) Bug
In my previous post, I found that Deepstream pipeline generate “vibrating” videos with input resolution width=1920, height=1080, NvDCF tracker on, and nvinfer interval > 0, and I claimed that the issue was fixed in Deepstream 6.2 release.
But it is NOT fixed. I don’t know if it is because I upgrade my GPU driver, or I haven’t test it thouroghly when 6.2 was released. Recently I’m able to reproduce the vibration issue with the same pipeline, model and configs in the original post.
@kesong Sorry but can you reinvestigate this issue? I really want to just reopen that post/issue like github, but this is nvidia forum so no.
We have plan to fix the issue.
But you have workaround for the issue in: Minor frame "vibration" in output video when using NvDCF tracker and nvinfer interval>0 - #6 by 413405663
Does the workaround works for you now?
Yes, the workaround is still good in current version.
Nice to know that you are working on a fix, should I keep this post open?
Let’s close this topic as there is no more action in the forum.
