I am working on a C++ video application, and encounter a decode failure for H.264 frame sizes that exceed ~2 MB. I suspect the issue relates to a bitstream buffer overload within the NVDEC API. I am using an A16 GPU.
Any suggestions on how to solve this issue would be very appreciated.
Apologies for the delay. I’ve attached an mp4 file of a short input stream that involves decode fails (h264 does not appear to be an authorised file type on the forum). The first frame is a key frame that fails to decode, and the 3rd frame is a key frame that successfully decodes. Frames 4:10 are then standard frames that are successfully decoded. I noticed I incorrectly wrote that the decode fail occurs for frames that exceed ~2MB. I actually meant ~2Mb.
