NVDEC Gstreamer Element Issue
Hi all,
I’ve recently installed the nvenc, nvdec GST elements following the guides [1, 2] here on Ubuntu 18.04 with a RTX 3080 card, with the latest Video Codec SDK.
gst-inspect-1.0 nvdec
Factory Details:
  Rank                     primary (256)
  Long-name                NVDEC video decoder
  Klass                    Decoder/Video
  Description              NVDEC video decoder
  Author                   Ericsson AB, http://www.ericsson.com
Plugin Details:
  Name                     nvdec
  Description              GStreamer NVDEC plugin
  Filename                 /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvdec.so
  Version                  1.14.5
  License                  BSD
  Source module            gst-plugins-bad
  Source release date      2019-05-29
  Binary package           GStreamer Bad Plug-ins source release
  Origin URL               Unknown package origin
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstVideoDecoder
                         +----GstNvDec
Pad Templates:
  SRC template: 'src'
    Availability: Always
    Capabilities:
      video/x-raw(memory:GLMemory)
                 format: NV12
                  width: [ 1, 2147483647 ]
                 height: [ 1, 2147483647 ]
              framerate: [ 0/1, 2147483647/1 ]
         texture-target: 2D
  SINK template: 'sink'
    Capabilities:
      video/x-h264
          stream-format: byte-stream
              alignment: au
      video/x-h265
              alignment: au
      video/mpeg
            mpegversion: { (int)1, (int)2, (int)4 }
           systemstream: false
      image/jpeg
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
  SINK: 'sink'
    Pad Template: 'sink'
  SRC: 'src'
    Pad Template: 'src'
Element Properties:
  name                : The name of the object
                        flags: readable, writable
                        String. Default: "nvdec0"
  parent              : The parent of the object
                        Object of type "GstObject"
I’m trying to use it to replace avdec_h264 in the working example GST pipeline below, running a test video file:
sudo gst-launch-1.0 filesrc location=test.mp4 ! qtdemux ! h264parse ! avdec_h264 ! autovideosink
sudo gst-launch-1.0 filesrc location=test.mp4 ! qtdemux ! h264parse ! nvdec ! autovideosink
But when I run the pipeline using nvdec, the video sink screen is entirely green, and the following error occurs:
Setting pipeline to PAUSED ...
error: XDG_RUNTIME_DIR not set in the environment.
Pipeline is PREROLLING ...
Got context from element 'autovideosink0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayX11\)\ gldisplayx11-0";
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Caught SIGSEGV
#0  0x00007f04b88e8cb9 in __GI___poll (fds=0x55a3998a3620, nfds=2, timeout=-1)
#1  0x00007f04b8e306e9 in  () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#2  0x00007f04b8e30a82 in g_main_loop_run ()
#3  0x00007f04b93949f3 in gst_bus_poll ()
#4  0x000055a397b8cbb3 in  ()
#5  0x000055a397b8bcb7 in  ()
#6  0x00007f04b87f5bf7 in __libc_start_main (main=
#7  0x000055a397b8c0da in  ()
Spinning.  Please run 'gdb gst-launch-1.0 16669' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Running nvidia-smi, I do see the process there.
nvidia-smi
Wed Dec  8 02:07:25 2021
| NVIDIA-SMI 470.86       Driver Version: 470.86       CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:04:00.0 Off |                  N/A |
|  0%   44C    P2   107W / 370W |    235MiB / 10018MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      2265      G   /usr/lib/xorg/Xorg                  9MiB |
|    0   N/A  N/A      2813      G   /usr/bin/gnome-shell               10MiB |
|    0   N/A  N/A     14701      C   gst-launch-1.0                    211MiB |
If anyone can assist me in getting nvdec working nicely with Gstreamer, that would be much appreciated!
Were You able to solve the problem ?
@kelvin.chan95hk I am getting the same Green Screen.Any Resolution for This.
