I need to obtain two RTSP streams using a Gstreamer pipeline. I am using Nvstreamdemux to do this. My pipeline is as follows:
filesrc1 → videoflip1 → dewarper1 → mux.sink_0 → nvinfer → nvstreamdemux.src_0 → rstp_1
filesrc2 → videoflip2 → dewarper2 → mux.sink_1 → nvinfer → nvstreamdemux.src_1 → rstp_2
However, I get an error when I try to do so. Could someone that has worked with such a pipeline kindly help me? I am having problems because of the dewarper in the pipeline. I can get a similar pipeline to work without the dewarper.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
