Hi Steve,
As per your support, I have successfully upgraded Tegra-A and Tegra-B. But still the control is not coming out from minicom . Down I am copying the dmesg from Tegra-A captured from ttyUSB2 in minicom,
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan 1 2014, 17:13:19.
Port /dev/ttyUSB2, 20:41:44
Press CTRL-A Z for help on special keys
Starting Hostname Service...
[ OK ] Started Hostname Service.
Starting Cleanup of Temporary Directories…
[ OK ] Started Cleanup of Temporary Directories.
[* ] A start job is running for Setup Wizard (20min 8s / no limit)NOTICE: BL31: v1.3(release):tegra-5.0.4.0-drv-5.0-linux-4.9-20171017-1-g
8d54454
NOTICE: BL31: Built : 21:25:51, Nov 29 2017
���� 396901|HV/c0: Start…
�MMFLAGS=1
Starting RM server
�starting app i2c_server
starting app bpmp_incoming
�Registered governor: pid_thermal_gov
�starting app gdb_agent
�starting app bpmp_ping
starting app thermal
trip_update_worker: Failed to get current temperature for zone 1
starting app bpmp_server
starting app cpufreq_hv
�Setting BOARD_SHUTDOWN_DLL to /proc/boot/libnvshutdown.so if not set already
Done…
[ audio_server_parse_guest_info() : 55] ERROR: Audio Server IVC queues not Set up
[ main() : 173] ERROR: Failed to initialize audio server
[ main() : 174] ERROR: Exiting…
�starting app se_server
�[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.38-rt25-tegra (buildbrain@mobile-u64-290) (gcc version 4.9.2 (GCC) ) #1 SMP PREEMPT RT Mon Jan 8 01:00:48 PST
2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7fe00000
[ 0.000000] OF: fdt: - 100000000 , 15ca00000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003110000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node generic_carveout, compatible id nvidia,generic_carveout
[ 0.000000] cma: Reserved 256 MiB at 0x00000000bec00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1dc82e000 s56192 r8192 d29824 u94208
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1723176
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 earlycon=uart8250,mmio32,0x03110000 console=ttyS0,115200n8 no_console_suspend=1 tegra_k
eep_boot_clocks cma=268435456 tegraid=18.1.2.0.0 ratchet_status=0x0 uid=1642d98421c0000001fe0200 earlycon=uart8250,mmio32,0x03110000 bl_prof_d
ataptr=65536@0x25e4b0000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6556088K/7002112K available (12414K kernel code, 2284K rwdata, 5176K rodata, 4736K init, 829K bss, 183880K reserved, 262
144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ca0000 ( 12416 KB)
[ 0.000000] .rodata : 0xffffff8008ca0000 - 0xffffff80091c0000 ( 5248 KB)
[ 0.000000] .init : 0xffffff80091c0000 - 0xffffff8009660000 ( 4736 KB)
[ 0.000000] .data : 0xffffff8009660000 - 0xffffff800989b008 ( 2285 KB)
[ 0.000000] .bss : 0xffffff800989b008 - 0xffffff800996a528 ( 830 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07728000 ( 119 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1dca00000 ( 7626 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000]
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000234] Console: colour dummy device 80x25
[ 0.365394] kmemleak: Kernel memory leak detector disabled
[ 0.365403] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.365405] pid_max: default: 32768 minimum: 301
[ 0.365458] Security Framework initialized
[ 0.365486] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.365488] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.367290] sched-energy: Sched-energy-costs installed from DT
[ 0.410054] ASID allocator initialised with 65536 entries
[ 0.462853] tegra-id: chipid=21817.
[ 0.463101] tegra-id: opt_subrevision=1.
[ 0.466903] Tegra Revision: A02p SKU: 144 CPU Process: 0 SoC Process: 0
[ 0.473508] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platfor
m/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-safety-vm.dts
[ 0.492658] DTB Build time: Dec 2 2017 10:53:08
[ 0.556996] CPU1: Booted secondary processor [4e0f0030]
[ 0.600986] CPU2: Booted secondary processor [4e0f0030]
[ 0.644951] CPU3: Booted secondary processor [411fd073]
[ 0.689039] CPU4: Booted secondary processor [411fd073]
[ 0.733121] CPU5: Booted secondary processor [411fd073]
[ 0.733184] Brought up 6 CPUs
[ 0.758978] SMP: Total of 6 processors activated.
[ 0.763679] CPU features: detected feature: 32-bit EL0 Support
[ 0.769831] CPU: All CPU(s) started at EL1
[ 0.774464] devtmpfs: initialized
[ 0.787443] Initilizing CustomIPI irq domain
[ 0.788553] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.798130] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.808227] pinctrl core: initialized pinctrl subsystem
[ 0.810596] regulator-dummy: no parameters
[ 0.814447] Initializing plugin-manager
[ 0.818169] Plugin module not found
[ 0.822693] Adding domain adsp-pd to PM domain ape-pd
[ 0.827882] tegra_hv: adding ivc0: rx_base=ffffff8009a00000 tx_base = ffffff8009a08000 size=8000 irq = 5 (321)
[ 0.836660] tegra_hv: added ivc0
[ 0.839892] tegra_hv: adding ivc1: rx_base=ffffff8009a10000 tx_base = ffffff8009a18000 size=8000 irq = 6 (322)
[ 0.849824] tegra_hv: added ivc1
[ 0.853150] tegra_hv: adding ivc2: rx_base=ffffff8009a20000 tx_base = ffffff8009a28000 size=8000 irq = 7 (323)
[ 0.863054] tegra_hv: added ivc2
[ 0.866420] tegra_hv: adding ivc3: rx_base=ffffff8009a30000 tx_base = ffffff8009a38000 size=8000 irq = 8 (324)
[ 0.876356] tegra_hv: added ivc3
[ 0.879564] tegra_hv: adding ivc4: rx_base=ffffff8009a40000 tx_base = ffffff8009a48000 size=8000 irq = 9 (325)
[ 0.889521] tegra_hv: added ivc4
[ 0.892847] tegra_hv: adding ivc5: rx_base=ffffff8009a50000 tx_base = ffffff8009a58000 size=8000 irq = 10 (326)
[ 0.902911] tegra_hv: added ivc5
[ 0.906128] tegra_hv: adding ivc6: rx_base=ffffff8009a60000 tx_base = ffffff8009a68000 size=8000 irq = 11 (327)
[ 0.916232] tegra_hv: added ivc6
[ 0.919443] tegra_hv: adding ivc7: rx_base=ffffff8009a70000 tx_base = ffffff8009a78000 size=8000 irq = 12 (328)
[ 0.929551] tegra_hv: added ivc7
[ 0.932830] tegra_hv: adding ivc8: rx_base=ffffff8009a80000 tx_base = ffffff8009a88000 size=8000 irq = 13 (329)
[ 0.942806] tegra_hv: added ivc8
[ 0.946194] tegra_hv: adding ivc9: rx_base=ffffff8009a90000 tx_base = ffffff8009a98000 size=8000 irq = 14 (330)
[ 0.956115] tegra_hv: added ivc9
[ 0.959456] tegra_hv: adding ivc10: rx_base=ffffff8009aa0000 tx_base = ffffff8009aa8000 size=8000 irq = 15 (331)
[ 0.969521] tegra_hv: added ivc10
[ 0.972874] tegra_hv: adding ivc11: rx_base=ffffff8009ab0000 tx_base = ffffff8009ab8000 size=8000 irq = 16 (332)
[ 0.983092] tegra_hv: added ivc11
[ 0.986438] tegra_hv: adding ivc12: rx_base=ffffff8009ac0000 tx_base = ffffff8009ac8000 size=8000 irq = 17 (333)
[ 0.996512] tegra_hv: added ivc12
[ 0.999857] tegra_hv: adding ivc13: rx_base=ffffff8009ad0000 tx_base = ffffff8009ad8000 size=8000 irq = 18 (334)
[ 1.010082] tegra_hv: added ivc13
[ 1.013429] tegra_hv: adding ivc28: rx_base=ffffff8009980000 tx_base = ffffff8009988000 size=8000 irq = 19 (335)
[ 1.023501] tegra_hv: added ivc28
[ 1.026861] tegra_hv: adding ivc29: rx_base=ffffff8009990000 tx_base = ffffff8009998000 size=8000 irq = 20 (336)
[ 1.036993] tegra_hv: added ivc29
[ 1.040343] tegra_hv: adding ivc30: rx_base=ffffff80099a0000 tx_base = ffffff80099a8000 size=8000 irq = 21 (337)
[ 1.050560] tegra_hv: added ivc30
[ 1.053923] tegra_hv: adding ivc31: rx_base=ffffff80099b0000 tx_base = ffffff80099b8000 size=8000 irq = 22 (338)
[ 1.064056] tegra_hv: added ivc31
[ 1.067401] tegra_hv: adding ivc32: rx_base=ffffff8008040000 tx_base = ffffff8008048000 size=8000 irq = 23 (339)
[ 1.077478] tegra_hv: added ivc32
[ 1.080830] tegra_hv: adding ivc33: rx_base=ffffff8009b00000 tx_base = ffffff8009b18000 size=18000 irq = 24 (340)
[ 1.091059] tegra_hv: added ivc33
[ 1.094408] tegra_hv: adding ivc56: rx_base=ffffff80099c0000 tx_base = ffffff80099c8000 size=8000 irq = 25 (341)
[ 1.104635] tegra_hv: added ivc56
[ 1.107974] tegra_hv: adding ivc76: rx_base=ffffff8009b40000 tx_base = ffffff8009b50000 size=10000 irq = 26 (342)
[ 1.118206] tegra_hv: added ivc76
[ 1.121547] tegra_hv: adding ivc99: rx_base=ffffff8009ae0000 tx_base = ffffff8009ae8000 size=8000 irq = 27 (343)
[ 1.131623] tegra_hv: added ivc99
[ 1.134987] tegra_hv: adding ivc101: rx_base=ffffff80099d0000 tx_base = ffffff80099d8000 size=8000 irq = 28 (344)
[ 1.145283] tegra_hv: added ivc101
[ 1.148642] tegra_hv: adding ivc102: rx_base=ffffff8008060000 tx_base = ffffff8008068000 size=8000 irq = 29 (345)
[ 1.158876] tegra_hv: added ivc102
[ 1.162351] tegra_hv: added mempool 0: ipa=25cd80000 size=400000 peer=2
[ 1.168963] tegra_hv: added mempool 1: ipa=25d180000 size=800000 peer=2
[ 1.175579] tegra_hv: added mempool 2: ipa=25d980000 size=10000 peer=2
[ 1.182038] tegra_hv: added mempool 3: ipa=25da00000 size=400000 peer=1
[ 1.188704] tegra_hv: added mempool 5: ipa=25de00000 size=40000 peer=5
[ 1.195184] tegra_hv: added mempool 6: ipa=25de40000 size=10000 peer=3
[ 1.201789] tegra_hv: added mempool 7: ipa=25de50000 size=40000 peer=6
[ 1.208239] tegra_hv: initialized
[ 1.212094] NET: Registered protocol family 16
[ 1.218047] pstore: using zlib compression
[ 1.220931] console [pstore-1] enabled
[ 1.223842] pstore: Registered ramoops as persistent store backend
[ 1.230088] ramoops: attached 0x200000@0xffc00000, ecc: 0/0
[ 1.241622] bpmp: mail init ok
[ 1.243260] arm-smmu 12000000.iommu: probing hardware configuration…
[ 1.247934] arm-smmu 12000000.iommu: SMMUv2 with:
[ 1.252661] arm-smmu 12000000.iommu: stage 1 translation
[ 1.257982] arm-smmu 12000000.iommu: stream indexing with 128 indices
[ 1.264512] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 1.275107] arm-smmu 12000000.iommu: 32 context banks (0 stage-2 only)
[ 1.281721] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 1.293257] vdso: 2 pages (1 code @ ffffff8008ca7000, 1 data @ ffffff8009664000)
[ 1.297417] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.306147] atomic_pool_init():529: DMA: preallocated 2048 KiB pool for atomic allocations
[ 1.313524] Registering BPMP clocks…
[ 1.316348] clock init ok
[ 1.319121] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 1.327812] tegra_powergate_init: DONE
[ 1.328297] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platfor
[ 1.347441] DTB Build time: Dec 2 2017 10:53:08
[ 1.351975] Tegra reboot handler registered.
[ 1.357333] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
[ 1.363576] tegra-pmc: ### PMC reset source: Power on reset
[ 1.369123] tegra-pmc: ### PMC reset level: L0
[ 1.373639] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.378725] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 1.385838] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 1.392169] iommu: Adding device 3460000.sdhci to group 0
[ 1.399056] iommu: Adding device 3160000.i2c to group 1
[ 1.402785] iommu: Adding device c240000.i2c to group 2
[ 1.408011] iommu: Adding device 3180000.i2c to group 3
[ 1.413211] iommu: Adding device 3190000.i2c to group 4
[ 1.418475] iommu: Adding device 31b0000.i2c to group 5
[ 1.423628] iommu: Adding device 31c0000.i2c to group 6
[ 1.428787] iommu: Adding device c250000.i2c to group 7
[ 1.434004] iommu: Adding device 31e0000.i2c to group 8
[ 1.440353] iommu: Adding device 3210000.spi to group 9
[ 1.444500] iommu: Adding device 3230000.spi to group 10
[ 1.449836] iommu: Adding device 3270000.spi to group 11
[ 1.455347] iommu: Adding device 3110000.serial to group 12
[ 1.461365] iommu: Adding device 2490000.ether_qos to group 13
[ 1.466744] iommu: Adding device b040000.sce to group 14
[ 1.472235] iommu: Adding device smmu_test to group 15
[ 1.477065] mc: mapped MMIO address: 0xffffff8009f80000 → 0x2c10000
[ 1.483006] mc: mapped MMIO address: 0xffffff8009fa0000 → 0x2c20000
[ 1.489438] mc: mapped MMIO address: 0xffffff8009fc0000 → 0x2c30000
[ 1.495750] mc: mapped MMIO address: 0xffffff8009fe0000 → 0x2c40000
[ 1.502070] mc: mapped MMIO address: 0xffffff800b210000 → 0x2c50000
[ 1.508780] mc-err: mcerr ops are set to t18x
[ 1.513519] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 1.519685] iommu: Adding device 3530000.xhci to group 16
[ 1.524596] iommu: Adding device 3550000.xudc to group 17
[ 1.530565] iommu: Adding device 13e10000.host1x to group 18
[ 1.535608] iommu: Adding device 13e10000.host1x:ctx0 to group 19
[ 1.541706] iommu: Adding device 13e10000.host1x:ctx1 to group 20
[ 1.547715] iommu: Adding device 13e10000.host1x:ctx2 to group 21
[ 1.553820] iommu: Adding device 13e10000.host1x:ctx3 to group 22
[ 1.560038] iommu: Adding device 13e10000.host1x:ctx4 to group 23
[ 1.566005] iommu: Adding device 13e10000.host1x:ctx5 to group 24
[ 1.572211] iommu: Adding device 13e10000.host1x:ctx6 to group 25
[ 1.578189] iommu: Adding device 13e10000.host1x:ctx7 to group 26
[ 1.584425] iommu: Adding device 150c0000.nvcsi to group 27
[ 1.591645] tegra-reset 5000000.clock: registered 193 resets.
[ 1.595999] iommu: Adding device d000000.bpmp to group 28
[ 1.601060] bpmp d000000.bpmp: Found mempool with id 3
[ 1.605928] bpmp d000000.bpmp: ivm 0x000000025da00000
[ 1.611243] bpmp: ping status is 0
[ 1.614529] bpmp d000000.bpmp: firmware tag is 7a20186dd4ae720b05ab8a27657a7223
[ 1.625819] bpmp d000000.bpmp: probe ok
[ 1.628242] iommu: Adding device 2600000.dma to group 29
[ 1.633752] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.647324] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 1.655321] iommu: Adding device 10003000.pcie-controller to group 30
[ 1.660690] iommu: Adding device c1a0000.aon to group 31
[ 1.665155] sys-3v3: 3300 mV
[ 1.667827] sys-5v0: 5000 mV
[ 1.673302] iommu: Adding device 13e20000.host1xb to group 32
[ 1.676791] iommu: Adding device 15600000.isp to group 33
[ 1.681923] iommu: Adding device 15340000.vic to group 34
[ 1.687368] iommu: Adding device 154c0000.nvenc to group 35
[ 1.692873] iommu: Adding device 15480000.nvdec to group 36
[ 1.698545] iommu: Adding device 15380000.nvjpg to group 37
[ 1.703974] iommu: Adding device 15500000.tsec to group 38
[ 1.709545] iommu: Adding device 15100000.tsecb to group 39
[ 1.716034] iommu: Adding device vse@15810000 to group 40
[ 1.720599] iommu: Adding device vse@15820000 to group 41
[ 1.725786] iommu: Adding device vse@15830000 to group 42
[ 1.731185] iommu: Adding device vse@15840000 to group 43
[ 1.736996] irq: type mismatch, failed to map hwirq-328 for /interrupt-controller@3881000!
[ 1.744829] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 1.762668] SCSI subsystem initialized
[ 1.763593] usbcore: registered new interface driver usbfs
[ 1.768661] usbcore: registered new interface driver hub
[ 1.774094] usbcore: registered new device driver usb
[ 1.796090] media: Linux media interface: v0.10
[ 1.797291] Linux video capture interface: v2.00
[ 1.801982] pps_core: LinuxPPS API ver. 1 registered
[ 1.806845] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.816074] PTP clock support registered
[ 1.820502] trusty trusty: trusty version: Built: 21:28:29 Nov 29 2017
[ 1.826626] trusty trusty: selected api version: 3 (requested 3)
[ 1.835051] max77620 4-003c: PMIC Version OTP:0x4A and ES:0x1
[ 1.839965] max77620-sd0: at 1125 mV
[ 1.842727] max77620-sd1: at 1200 mV
[ 1.846397] max77620-sd2: at 1800 mV
[ 1.850069] max77620-sd3: at 3300 mV
[ 1.853722] max77620-sd4: at 600 mV
[ 1.857304] max77620-ldo0: at 1800 mV
[ 1.860887] max77620-ldo1: at 800 mV
[ 1.864388] max77620-ldo2: at 3300 mV
[ 1.868484] i2c i2c-4: deserialize_i2c ret -22
[ 1.872054] i2c i2c-4: — message dump for debugging —
[ 1.877453] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.882591] i2c i2c-4: 29
[ 1.885364] i2c i2c-4: f2
[ 1.887986] i2c i2c-4:
[ 1.890425] max77620-pmic max20024-pmic: Regulator 8 mode set failed: -22
[ 1.897215] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo3
[ 1.906068] max77620-ldo3: at 3300 mV
[ 1.910081] max77620-ldo4: at 800 mV
[ 1.914110] i2c i2c-4: deserialize_i2c ret -22
[ 1.917672] i2c i2c-4: — message dump for debugging —
[ 1.923073] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.928206] i2c i2c-4: 2d
[ 1.930984] i2c i2c-4: f2
[ 1.933602] i2c i2c-4:
[ 1.936044] max77620-pmic max20024-pmic: Regulator 10 mode set failed: -22
[ 1.942997] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo5
[ 1.951749] max77620-ldo5: at 3300 mV
[ 1.955524] random: fast init done
[ 1.958907] max77620-ldo6: at 1800 mV
[ 1.962946] max77620-ldo7: at 1000 mV
[ 1.966748] max77620-ldo8: at 800 mV
[ 1.970365] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 1.980729] i2c i2c-4: deserialize_i2c ret -22
[ 1.983136] i2c i2c-4: — message dump for debugging —
[ 1.988533] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.993589] i2c i2c-4: 0d
[ 1.996363] i2c i2c-4: ef
[ 1.998990] i2c i2c-4:
[ 2.001427] max77620 4-003c: Failed to sync masks in d
[ 2.007031] max77620 4-003c: max77620 probe successful
[ 2.012965] sn65dsi85_dsi2lvds_panel_create_debugfs: dsi2lvds->debugdir = ffffffc1d28cb870
[ 2.020051] sn65dsi85_dsi2lvds_panel_create_debugfs: debugfs_create_file returned ffffffc1d28cb960
[ 2.028934] sn65dsi85_i2c_probe: returning with err=0
[ 2.034003] max929x_i2c_client_init: called
[ 2.038245] max929x_i2c_probe: returning 0
[ 2.043062] tegra_hv_wdt tegra_hv_wdt: id=32 irq=23 peer=3 num=1 size=128
[ 2.043065] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
[ 2.054513] vdd-1v1: Bringing 0uV into 1100000-1100000uV
[ 2.059768] vdd-1v1: 1100 mV
[ 2.062978] vdd-1v2: Bringing 0uV into 1200000-1200000uV
[ 2.068019] vdd-1v2: 1200 mV
[ 2.071160] vdd-1v8-ddr: Bringing 0uV into 1800000-1800000uV
[ 2.076575] vdd-1v8-ddr: 1800 mV
[ 2.080064] vdd-3v3: Bringing 0uV into 3300000-3300000uV
[ 2.085260] vdd-3v3: 3300 mV
[ 2.088436] spmic-sd4: Bringing 0uV into 1100000-1100000uV
[ 2.093701] spmic-sd4: 1100 mV
[ 2.097024] vdd-1v8-pll: Bringing 0uV into 1800000-1800000uV
[ 2.102416] vdd-1v8-pll: 1800 mV
[ 2.105904] spmic-ldo1: Bringing 0uV into 800000-800000uV
[ 2.111155] spmic-ldo1: 800 mV
[ 2.114426] vdd-v3v-ao: Bringing 0uV into 3300000-3300000uV
[ 2.119830] vdd-v3v-ao: 3300 mV
[ 2.123360] en-vdd-rtc: Bringing 0uV into 800000-800000uV
[ 2.128446] en-vdd-rtc: 800 mV
[ 2.131765] vdd-1v8-ao: Bringing 0uV into 1800000-1800000uV
[ 2.137154] vdd-1v8-ao: 1800 mV
[ 2.140634] vdd-1v05: Bringing 0uV into 1050000-1050000uV
[ 2.145863] vdd-1v05: 1050 mV
[ 2.149023] spmic-ldo8: Bringing 0uV into 800000-800000uV
[ 2.154230] spmic-ldo8: 800 mV
[ 2.158658] vdd-1v8: supplied by vdd-1v8-ddr
[ 2.161731] vdd-1v8: 1800 mV
[ 2.164904] vdd-rtc: supplied by en-vdd-rtc
[ 2.168776] vdd-rtc: at 800 mV
[ 2.172255] vdd-usb2-5v: supplied by vdd-1v8
[ 2.176267] vdd-usb2-5v: 5000 mV
[ 2.288154] mxm-pwr-gpio-1: 5000 mV
[ 2.288912] mxm-pwr_en: supplied by mxm-pwr-gpio-1
[ 2.402714] mxm-pwr_en: 5000 mV
[ 2.405468] camchar: rtcpu character device driver loaded
[ 2.408267] clocksource: Switched to clocksource arch_sys_counter
[ 2.445164] VFS: Disk quotas dquot_6.6.0
[ 2.445915] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.461255] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 2.466534] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 2.475099] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.483464] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.492128] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 2.500404] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tj-therm
[ 2.508736] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 2.517422] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type Tegra_tx
[ 2.525747] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type Tegra_rx
[ 2.535551] isomgr_init(): iso emc max clk=1600000KHz
[ 2.539123] isomgr_init(): max_iso_bw=23040000KB
[ 2.543817] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.550767] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000cec00000,822083584
[ 2.557740] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 2.558156] NET: Registered protocol family 2
[ 2.559038] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.559676] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 2.561141] TCP: Hash tables configured (established 65536 bind 65536)
[ 2.561234] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.561590] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.562118] NET: Registered protocol family 1
[ 2.562792] RPC: Registered named UNIX socket transport module.
[ 2.562795] RPC: Registered udp transport module.
[ 2.562796] RPC: Registered tcp transport module.
[ 2.562798] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.562966] Unpacking initramfs…
[ 2.577856] Freeing initrd memory: 4628K (ffffffc003420000 - ffffffc0038a5000)
[ 2.595969] host1x 13e10000.host1x: initialized
[ 2.606097] genirq: Flags mismatch irq 66. 00002004 (host_status) vs. 00002004 (host_status)
[ 2.606152] host1x 13e20000.host1xb: general irq request failed, but continuing
[ 2.606879] host1x 13e20000.host1xb: initialized
[ 2.607702] irq: type mismatch, failed to map hwirq-328 for /interrupt-controller@3881000!
[ 2.607787] irq: type mismatch, failed to map hwirq-329 for /interrupt-controller@3881000!
[ 2.607885] irq: type mismatch, failed to map hwirq-330 for /interrupt-controller@3881000!
[ 2.607996] irq: type mismatch, failed to map hwirq-331 for /interrupt-controller@3881000!
[ 2.608224] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.610765] audit: initializing netlink subsys (disabled)
[ 2.610796] audit: type=2000 audit(2.604:1): initialized
[ 2.611312] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.615783] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.616713] NFS: Registering the id_resolver key type
[ 2.616734] Key type id_resolver registered
[ 2.616741] Key type id_legacy registered
[ 2.616753] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.616798] ntfs: driver 2.1.32 [Flags: R/O].
[ 2.617210] fuse init (API version 7.26)
[ 2.626716] NET: Registered protocol family 38
[ 2.626740] io scheduler noop registered
[ 2.626742] io scheduler deadline registered
[ 2.626963] io scheduler cfq registered (default)
[ 2.630790] irq: no irq domain found for /aconnect@2a41000/agic-controller@2a41000 !
[ 2.630892] iommu: Adding device 2993000.rtcpu to group 44
[ 2.631485] irq: no irq domain found for /aconnect@2a41000/agic-controller@2a41000 !
[ 2.632519] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 2.632788] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 2.635019] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 2.638612] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.640250] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 2.742080] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 2.742773] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 2.743533] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.743955] kfuse 3830000.kfuse: initialized
[ 2.748513] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.750008] console [ttyS0] disabled
[ 2.863332] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
[ 2.871733] 3110000.serial: ttyS0 at MMIO 0x3110000 (irq = 44, base_baud = 25500000) is a Tegra
[ 2.880482] console [ttyS0] enabled
[ 2.887277] bootconsole [uart8250] disabled
[ 2.902517] nvmap: nvmap_setup_t18x_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 2.967373] loop: module loaded
[ 2.968395] zram: Added device: zram0
[ 3.027744] nvmap: nvmap_select_cache_ops() nvmap cache ops set to (null)
[ 3.028370] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 3.028376] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 3.028379] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 3.028383] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.028386] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 3.028593] iommu: Adding device 0000:00:01.0 to group 45
[ 3.028736] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.029146] iommu: Adding device 0000:01:00.0 to group 46
[ 3.029184] tegra_profiler: Branch: Dev
[ 3.029185] tegra_profiler: Version: 1.114
[ 3.029187] tegra_profiler: Samples version: 41
[ 3.029189] tegra_profiler: IO version: 22
[ 3.029195] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.029198] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.029201] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.029203] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.029207] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.029208] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 3.029211] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.029213] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.029215] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.029217] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.029220] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.029222] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.030424] tegra_profiler: auth: init
[ 3.040419] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.040856] iommu: Adding device 0000:02:02.0 to group 47
[ 3.041302] iommu: Adding device 0000:02:0a.0 to group 48
[ 3.041429] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.041439] pci 0000:02:0a.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.041818] pci 0000:03:00.0: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR0 for 64 VFs)
[ 3.041847] pci 0000:03:00.0: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit] (contains BAR3 for 64 VFs)
[ 3.042276] iommu: Adding device 0000:03:00.0 to group 49
[ 3.045060] qspi_mtd spi6.0: s25fs512s SSG 8 0 1000 4000000
[ 3.045063] qspi_mtd spi6.0: s25fs512s (65536 Kbytes)
[ 3.045067] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00040000 (256KiB) .numeraseregions = 0
[ 3.045293] 1 ofpart partitions found on MTD device spi6.0
[ 3.045294] Creating 1 MTD partitions on “spi6.0”:
[ 3.045297] 0x000000000000-0x000004000000 : “Whole_flash”
[ 3.045626] libphy: Fixed MDIO Bus: probed
[ 3.045878] tun: Universal TUN/TAP device driver, 1.6
[ 3.045880] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.046137] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.046139] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.046268] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.046270] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.047261] PPP generic driver version 2.4.2
[ 3.047379] PPP BSD Compression module registered
[ 3.047382] PPP Deflate Compression module registered
[ 3.047398] PPP MPPE Compression module registered
[ 3.047401] NET: Registered protocol family 24
[ 3.047430] usbcore: registered new interface driver asix
[ 3.047461] usbcore: registered new interface driver ax88179_178a
[ 3.047475] usbcore: registered new interface driver cdc_ether
[ 3.047496] usbcore: registered new interface driver smsc95xx
[ 3.047510] usbcore: registered new interface driver net1080
[ 3.047523] usbcore: registered new interface driver cdc_subset
[ 3.047543] usbcore: registered new interface driver zaurus
[ 3.047565] usbcore: registered new interface driver cdc_ncm
[ 3.052942] iommu: Adding device 0000:04:00.0 to group 50
[ 3.054016] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b ac 0 4c
[ 3.054658] libphy: dwc_phy: probed
[ 3.054899] tegra-xusb 3530000.xhci: USB2 port 2 has OTG_CAP
[ 3.054903] tegra-xusb 3530000.xhci: No USB3 port has OTG_CAP
[ 3.057279] Could not get extcon-dev /xhci@3530000:id(0)
[ 3.059561] usbcore: registered new interface driver usb-storage
[ 3.060568] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 3.061018] mousedev: PS/2 mouse device common for all mice
[ 3.061097] usbcore: registered new interface driver xpad
[ 3.061582] i2c /dev entries driver
[ 3.062566] usbcore: registered new interface driver uvcvideo
[ 3.062568] USB Video Class driver (1.1.1)
[ 3.062894] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 3.063116] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 3.063120] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 3.063425] FAN dev name: pwm-fan
[ 3.063514] FAN:gpio request success.
[ 3.063688] pwm_fan_driver pwm-fan: cap state:5, cap pwm:256
[ 3.063743] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.064043] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.064148] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.064171] pwm_fan_driver pwm-fan: tach period: 400
[ 3.064654] pci 0000:00:01.0: BAR 15: assigned [mem 0x58000000-0x77ffffff 64bit pref]
[ 3.064658] pci 0000:00:01.0: BAR 14: assigned [mem 0x50400000-0x527fffff]
[ 3.064661] pci 0000:00:01.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.064668] pci 0000:01:00.0: BAR 15: assigned [mem 0x58000000-0x77ffffff 64bit pref]
[ 3.064671] pci 0000:01:00.0: BAR 14: assigned [mem 0x50800000-0x527fffff]
[ 3.064674] pci 0000:01:00.0: BAR 0: assigned [mem 0x50400000-0x5043ffff]
[ 3.064680] pci 0000:01:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.064686] pci 0000:02:0a.0: BAR 15: assigned [mem 0x58000000-0x6fffffff 64bit pref]
[ 3.064689] pci 0000:02:0a.0: BAR 14: assigned [mem 0x50800000-0x51ffffff]
[ 3.064693] pci 0000:02:02.0: BAR 14: assigned [mem 0x52000000-0x522fffff]
[ 3.064697] pci 0000:02:02.0: BAR 15: assigned [mem 0x70000000-0x702fffff 64bit pref]
[ 3.064700] pci 0000:02:0a.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.064707] pci 0000:03:00.0: BAR 0: assigned [mem 0x70000000-0x701fffff 64bit pref]
[ 3.064723] pci 0000:03:00.0: BAR 6: assigned [mem 0x52000000-0x5207ffff pref]
[ 3.064727] pci 0000:03:00.0: BAR 4: assigned [mem 0x70200000-0x70203fff 64bit pref]
[ 3.064743] pci 0000:03:00.0: BAR 7: assigned [mem 0x52080000-0x5217ffff 64bit]
[ 3.064753] pci 0000:03:00.0: BAR 10: assigned [mem 0x52180000-0x5227ffff 64bit]
[ 3.064761] pci 0000:02:02.0: PCI bridge to [bus 03]
[ 3.064768] pci 0000:02:02.0: bridge window [mem 0x52000000-0x522fffff]
[ 3.064774] pci 0000:02:02.0: bridge window [mem 0x70000000-0x702fffff 64bit pref]
[ 3.064784] pci 0000:04:00.0: BAR 1: assigned [mem 0x60000000-0x6fffffff 64bit pref]
[ 3.064797] pci 0000:04:00.0: BAR 3: assigned [mem 0x58000000-0x59ffffff 64bit pref]
[ 3.064809] pci 0000:04:00.0: BAR 0: assigned [mem 0x51000000-0x51ffffff]
[ 3.064816] pci 0000:04:00.0: BAR 6: assigned [mem 0x50800000-0x5087ffff pref]
[ 3.064819] pci 0000:04:00.0: BAR 5: assigned [io 0x1000-0x107f]
[ 3.064825] pci 0000:02:0a.0: PCI bridge to [bus 04]
[ 3.064828] pci 0000:02:0a.0: bridge window [io 0x1000-0x1fff]
[ 3.064834] pci 0000:02:0a.0: bridge window [mem 0x50800000-0x51ffffff]
[ 3.064839] pci 0000:02:0a.0: bridge window [mem 0x58000000-0x6fffffff 64bit pref]
[ 3.064845] pci 0000:01:00.0: PCI bridge to [bus 02-04]
[ 3.064850] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 3.064855] pci 0000:01:00.0: bridge window [mem 0x50800000-0x527fffff]
[ 3.064860] pci 0000:01:00.0: bridge window [mem 0x58000000-0x77ffffff 64bit pref]
[ 3.064867] pci 0000:00:01.0: PCI bridge to [bus 01-04]
[ 3.064870] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 3.064875] pci 0000:00:01.0: bridge window [mem 0x50400000-0x527fffff]
[ 3.064880] pci 0000:00:01.0: bridge window [mem 0x58000000-0x77ffffff 64bit pref]
[ 3.064945] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=1400, rru=20, rrd=20, state:2
[ 3.064949] pwm_fan_driver pwm-fan: index 1: pwm=102, rpm=2300, rru=20, rrd=20, state:2
[ 3.064972] pwm_fan_driver pwm-fan: index 2: pwm=154, rpm=3700, rru=10, rrd=10, state:2
[ 3.064975] pwm_fan_driver pwm-fan: index 3: pwm=179, rpm=4500, rru=10, rrd=10, state:2
[ 3.064978] pwm_fan_driver pwm-fan: index 4: pwm=205, rpm=4900, rru=10, rrd=10, state:3
[ 3.064980] pwm_fan_driver pwm-fan: index 5: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 3.064983] pwm_fan_driver pwm-fan: index 6: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 3.064986] pwm_fan_driver pwm-fan: index 7: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.064989] pwm_fan_driver pwm-fan: index 8: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.064991] pwm_fan_driver pwm-fan: index 9: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.065147] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 3.065151] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.065153] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 3.065155] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 3.065157] pci 0000:02:0a.0: Signaling PME through PCIe PME interrupt
[ 3.065160] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 3.066590] nvgpu 0000:04:00.0: enabling device (0000 → 0003)
[ 3.067645] trusty-virtio trusty:virtio: initializing
[ 3.067931] trusty_ipc virtio0: vring0: va¶ ffffffc1cf5b2000(0) qsz 32 notifyid 1
[ 3.067945] trusty_ipc virtio0: vring1: va¶ ffffffc1cf5b8000(0) qsz 32 notifyid 2
[ 3.068101] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 → Gen-2
[ 3.068362] trusty_ipc virtio0: is online
[ 3.068482] trusty-virtio trusty:virtio: initializing done
[ 3.068794] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 3.069062] device-mapper: uevent: version 1.0.3
[ 3.069327] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.069704] sdhci: Secure Digital Host Controller Interface driver
[ 3.069706] sdhci: Copyright(c) Pierre Ossman
[ 3.069708] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.070821] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.071063] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.072069] usbcore: registered new interface driver usbhid
[ 3.072072] usbhid: USB HID core driver
[ 3.073726] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.073738] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.077031] CHRDEV “tegra_hv_pm_ctl” major number 233 goes below the dynamic allocation range
[ 3.077163] tegra_hv_pm_ctl tegra_hv_pm_ctl: tegra_hv_pm_ctl_probe: Probed
[ 3.077838] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 3.077959] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 3.078026] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 3.078167] isc-pwm isc_pwm_gen: isc_pwm_probeing…
[ 3.078211] isc-pwm isc_pwm_gen: isc_pwm_probe success to get PWM
[ 3.078319] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 3.078321] nct1008_nct72 0-004c: starting parse dt
[ 3.078392] nct1008_nct72 0-004c: success parsing dt
[ 3.078462] nct1008_nct72 0-004c: success in enabling nct72 VDD rail
[ 3.078969] THERMAL EST: found 2 subdevs
[ 3.078972] THERMAL EST num_resources: 0
[ 3.078975] [THERMAL EST subdev 0]
[ 3.078978] [THERMAL EST subdev 1]
[ 3.079300] thermal thermal_zone9: Registering thermal zone thermal_zone9 for type thermal-fan-est
[ 3.079303] THERMAL EST: thz register success.
[ 3.079336] THERMAL EST: end of probe, return err: 0
[ 3.079499] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 3.079608] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=2090250, vi_iso_bw=2577095, max_bw=2577095
[ 3.081935] tsec 15500000.tsec: initialized
[ 3.083230] tsec 15100000.tsecb: initialized
[ 3.086103] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 3.086958] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 3.087784] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 3.088716] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 3.089570] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 3.090439] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 3.091292] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 3.092054] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 3.094729] vhost-client 15340000.vic: initialized
[ 3.095554] vhost-client 154c0000.nvenc: initialized
[ 3.098510] vhost-client 15480000.nvdec: initialized
[ 3.099315] vhost-client 15380000.nvjpg: initialized
[ 3.099856] CHRDEV “tegra_dc_ext” major number 232 goes below the dynamic allocation range
[ 3.099955] scrncapt: init (heads:3 wins:6 planes:4)
[ 3.100035] ds90ub947_probe: entered
[ 3.100143] tegradccommon 15200000.dc_common: host1x channel mapped
[ 3.100149] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 3.100203] tegradccommon 15200000.dc_common: dma mapping done
[ 3.100501] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor
[ 3.100731] tegradc 15200000.nvdisplay: DT parsed successfully
[ 3.100749] tegradc 15200000.nvdisplay: Display dc.ffffff800bb90000 registered with id=0
[ 3.104034] ds90ub947-q1 6-000c: initializing registers failed
[ 3.104041] ds90ub947_probe: returning -5
[ 3.104110] ds90ub947-q1: probe of 6-000c failed with error -5
[ 3.106664] tegra186-cam-rtcpu 2993000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.107259] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 3.107261] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 3.107262] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 3.107315] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 3.107318] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 3.110549] tegradc 15200000.nvdisplay: probed
[ 3.112286] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.128720] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.128731] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.132612] tegra-ivc ivc-2993000.rtcpu: region 0: iova=0xa0090000-0xa009d0ff size=53504
[ 3.132926] tegra-ivc ivc-2993000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.132965] tegra-ivc-cdev ivc-2993000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.133087] tegra-ivc ivc-2993000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.134388] tegra-ivc ivc-2993000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5a00-0x6e80 TX[16x320]=0x6e80-0x8300
[ 3.134439] tegra-ivc ivc-2993000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8300-0x8780 TX[16x64]=0x8780-0x8c00
[ 3.134488] tegra-ivc ivc-2993000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8c00-0x8e00 TX[1x384]=0x8e00-0x9000
[ 3.134518] tegra-ivc-cdev ivc-2993000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.134631] tegra-ivc ivc-2993000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9000-0xb080 TX[1x8192]=0xb080-0xd100
[ 3.135081] tegra186-cam-rtcpu 2993000.rtcpu: using cam RTCPU IRQ (407)
[ 3.135083] tegra186-cam-rtcpu 2993000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.135211] nct72: Enabled overheat logging at 102.00C
[ 3.135261] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 3.136348] tegra186-cam-rtcpu 2993000.rtcpu: firmware version cpu=ape cmd=4 sha1=4d72ea1f4580f39d9f3dc17e51116f9dfe677e6a
[ 3.138350] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.138556] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.138657] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.138780] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 3.138782] tegra18_denver_serr_enable:mce write failed: error=0x0
[ 3.138814] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 3.138816] tegra18_denver_serr_enable:mce write failed: error=0x0
[ 3.138967] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 3.139031] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.139596] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.139848] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 3.139944] tegra_mce_write_uncore_perfmon: failed (ret=-1)
[ 3.139950] perfmon status error: 4294967295
[ 3.139951] ARI CMD:1 REG:6 CTR:0 Data:2
[ 3.139975] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 3.140013] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.140087] Denver: backdoor interface is NOT available.
[ 3.140729] tegra_hv_vse vse@15810000: Virtual SE Stream ID: 72
[ 3.140733] tegra_hv_vse vse@15810000: Virtual SE channel number: 76
[ 3.141337] tegra_hv_vse vse@15820000: Virtual SE Stream ID: 72
[ 3.142394] tegra_hv_vse vse@15830000: Virtual SE Stream ID: 72
[ 3.143213] tegra_hv_vse vse@15840000: Virtual SE Stream ID: 72
[ 3.144838] tegra18x-cpufreq: Using hv path
[ 3.146519] cpufreq: platform driver Initialization: pass
[ 3.147872] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.151399] GACT probability NOT on
[ 3.151408] Mirror/redirect action on
[ 3.151416] u32 classifier
[ 3.151417] Actions configured
[ 3.151422] Netfilter messages via NETLINK v0.30.
[ 3.151930] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.152089] ctnetlink v0.93: registering with nfnetlink.
[ 3.152593] xt_time: kernel timezone is -0000
[ 3.152600] IPVS: Registered protocols ()
[ 3.152678] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.152779] IPVS: Creating netns size=1744 id=0
[ 3.153245] IPVS: ipvs loaded.
[ 3.153323] gre: GRE over IPv4 demultiplexor driver
[ 3.153694] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.153806] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 3.153918] Initializing XFRM netlink socket
[ 3.154449] NET: Registered protocol family 10
[ 3.155484] mip6: Mobile IPv6
[ 3.155555] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.156844] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.157387] ip6_gre: GRE over IPv6 tunneling driver
[ 3.157618] NET: Registered protocol family 17
[ 3.157632] NET: Registered protocol family 15
[ 3.157673] 8021q: 802.1Q VLAN Support v1.8
[ 3.157698] Key type dns_resolver registered
[ 3.157936] Registered cp15_barrier emulation handler
[ 3.157997] Registered setend emulation handler
[ 3.159935] registered taskstats version 1
[ 3.163644] tegra-xusb 3530000.xhci: USB2 port 2 has OTG_CAP
[ 3.163647] tegra-xusb 3530000.xhci: USB3 port 0 has OTG_CAP
[ 3.164349] tegra-xusb-padctl 3520000.xusb_padctl: enabling OTG on multiple USB3 ports
[ 3.164848] tegra-xusb-padctl 3520000.xusb_padctl: enabling OTG on multiple USB2 ports
[ 3.167227] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[ 3.167362] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 3.167407] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.167962] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.169319] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 3.169706] isc-mgr isc-mgr.0: isc_mgr_probe: success to get PWM
[ 3.170131] CHRDEV “isc-mgr.7.a” major number 231 goes below the dynamic allocation range
[ 3.170432] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 3.170492] isc-mgr isc-mgr.1: isc_mgr_probe: success to get PWM
[ 3.170778] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.170931] CHRDEV “isc-mgr.2.c” major number 230 goes below the dynamic allocation range
[ 3.171199] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 3.171281] isc-mgr isc-mgr.2: isc_mgr_probe: success to get PWM
[ 3.171770] CHRDEV “isc-mgr.1.e” major number 229 goes below the dynamic allocation range
[ 3.173327] hvc_sysfs: log is available
[ 3.173331] hvc_sysfs: pct is available
[ 3.176917] isp 15600000.isp: initialized
[ 3.226358] tegra-xusb 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 3.226377] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.226394] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 3.227197] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 3.227459] tegra-xusb 3530000.xhci: irq 61, io mem 0x03530000
[ 3.227611] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.227615] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.227618] usb usb1: Product: xHCI Host Controller
[ 3.227620] usb usb1: Manufacturer: Linux 4.9.38-rt25-tegra xhci-hcd
[ 3.227622] usb usb1: SerialNumber: 3530000.xhci
[ 3.227844] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.227856] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 3.227992] hub 1-0:1.0: USB hub found
[ 3.228020] hub 1-0:1.0: 4 ports detected
[ 3.228465] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 3.228473] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 3.228701] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.228705] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.228708] usb usb2: Product: xHCI Host Controller
[ 3.228710] usb usb2: Manufacturer: Linux 4.9.38-rt25-tegra xhci-hcd
[ 3.228712] usb usb2: SerialNumber: 3530000.xhci
[ 3.229085] hub 2-0:1.0: USB hub found
[ 3.229109] hub 2-0:1.0: 3 ports detected
[ 3.229714] Wake76 for irq=199
[ 3.229716] Wake77 for irq=199
[ 3.229718] Wake78 for irq=199
[ 3.229719] Wake79 for irq=199
[ 3.229720] Wake80 for irq=199
[ 3.229721] Wake81 for irq=199
[ 3.229722] Wake82 for irq=199
[ 3.250635] mmc0: hw tuning done …
[ 3.250636] ======= mmc0: Tuning windows =======
[ 3.250639] mmc0: tuning window[0]: 0xfffffffe
[ 3.250642] mmc0: tuning window[1]: 0xffffc3ff
[ 3.250643] mmc0: tuning window[2]: 0xfc7fffff
[ 3.250645] mmc0: tuning window[3]: 0xffffffff
[ 3.250647] mmc0: tuning window[4]: 0xffffff8f
[ 3.250648] mmc0: tuning window[5]: 0xfff0ffff
[ 3.250650] mmc0: tuning window[6]: 0xfffffff
[ 3.250652] mmc0: tuning window[7]: 0x7fffffff
[ 3.250653] sdhci: Tap value: 0 | Trim value: 5
[ 3.250654] ==================================
[ 3.250655] Vendor clock ctrl: 0x564d069
[ 3.250656] Vendor SysSW ctrl: 0x38607002
[ 3.250657] Vendor Err interrupt status : 0x40000
[ 3.250659] Vendor Cap overrides: 0x1107
[ 3.250660] Vendor Misc ctrl: 0xfffd0081
[ 3.250661] Vendor Misc ctrl_1: 0x0
[ 3.250662] Vendor Misc ctrl_2: 0x20e00000
[ 3.250663] Vendor IO trim ctrl: 0x11
[ 3.250664] Vendor Tuning ctrl: 0x7c028017
[ 3.250665] SDMEM comp padctrl: 0x8000007
[ 3.250666] Autocal config: 0x20010505
[ 3.250668] Autocal status: 0xe0d0908
[ 3.256118] mmc0: new HS400 MMC card at address 0001
[ 3.256414] mmcblk0: mmc0:0001 064G32 59.3 GiB
[ 3.256543] mmcblk0rpmb: mmc0:0001 064G32 partition 3 4.00 MiB
[ 3.258133] mmcblk0: p1 p2 p3 p4
[ 5.137152] nvmap_page_pool_init: Total RAM pages: 1705715
[ 5.137154] nvmap_page_pool_init: nvmap page pool size: 213214 pages (832 MB)
[ 5.137205] nvmap_background_zero_thread: PP zeroing thread starting.
[ 5.137671] misc nvmap: created heap generic-0 base 0x00000000cec00000 size (802816KiB)
[ 5.164141] tegradc 15200000.nvdisplay: fb registered
[ 5.169745] gpio tegra-gpio wake19 for gpio=120(P:0)
[ 5.174465] nvcsi 150c0000.nvcsi: initialized
[ 5.181000] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/dsi
[ 5.187677] tegradc 15210000.nvdisplay: No hpd-gpio in DT
[ 5.193134] tegradc 15210000.nvdisplay: DT parsed successfully
[ 5.198864] tegradc 15210000.nvdisplay: Display dc.ffffff800bfc0000 registered with id=1
[ 5.207139] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 5.213208] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 5.220684] tegradc 15210000.nvdisplay: DSI: HS clock rate is 445500
[ 5.226857] tegradc 15210000.nvdisplay: probed
[ 5.230654] tegradc 15210000.nvdisplay: fb registered
[ 5.236459] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 5.241534] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 5.247532] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 5.487050] sn65dsi85_dsi2lvds: PLL not locked
[ 5.516617] tegra-vi4 15700000.vi: initialized
[ 5.526323] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[ 5.530323] tegradc 15220000.nvdisplay: DT parsed successfully
[ 5.536156] tegradc 15220000.nvdisplay: Display dc.ffffff800d010000 registered with id=2
[ 5.544400] tegradc 15220000.nvdisplay: vblank syncpt # 14 for dc 2
[ 5.550516] tegradc 15220000.nvdisplay: vpulse3 syncpt # 15 for dc 2
[ 5.558938] tegradc 15220000.nvdisplay: hdmi: board prod-setting covers partial!
[ 5.565443] tegradc 15220000.nvdisplay: probed
[ 5.568955] tegradc 15220000.nvdisplay: fb registered
[ 5.573931] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 5.576588] Freeing unused kernel memory: 4736K (ffffffc0011c0000 - ffffffc001660000)
[ 5.586644] tegradc 15220000.nvdisplay: hdmi: plugged
[ 5.590872] INITRAMFS STARTS
Getting target_board from device-tree …
[ 5.704413] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
[ 5.709983] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
[ 5.856300] tegra-xusb 3530000.xhci: entering ELPG
[ 5.861155] tegra-xusb 3530000.xhci: entering ELPG done
[ 5.953996] EXT4-fs (mmcblk0p3): recovery complete
[ 5.956441] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 6.020653] Trying chroot to /new_root
[ 6.021232] INITRAMFS END
[ 6.061038] systemd[1]: System time before build time, advancing clock.
[ 6.081529] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRY
PT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.096631] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 16.04 LTS!
[ 6.117099] systemd[1]: Set hostname to .
[ 6.235787] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 6.252417] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.268395] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 6.288376] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 6.308493] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 6.324342] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ OK ] Listening on Device-mapper event daemon FIFOs.
[ 6.344327] systemd[1]: Listening on LVM2 metadata daemon socket.
[ OK ] Listening on LVM2 metadata daemon socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on LVM2 poll daemon socket.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Swap.
[ OK ] Created slice System Slice.
Mounting Debug File System…
Starting Create list of required st… nodes for the current kernel…
Starting Load Kernel Modules…
Mounting POSIX Message Queue File Syste[ 6.482123] usbcore: registered new interface driver rndis_host
m…
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting nv-run-date.service…
Starting Monitoring of LVM2 mirrors… dmeventd or progress polling…
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Braille Device Support.
[ OK ] Reached target User and Group Name Lookups.
[ OK ] Reached target Slices.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
Starting Journal Service…
Starting Remount Root and Kernel File Systems…
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Started Create list of required sta…ce nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started nv-run-date.service.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Journal Service.
[ OK ] Started LVM2 metadata daemon.
Starting Flush Journal to Persistent Storage…
Starting udev Coldplug all Devices…
Starting Load/Save Random Seed…
Mounting Configuration File System…
Mounting FUSE Control File System…
Starting Apply Kernel Variables…
Starting Create Static Device Nodes in /dev…
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Configuration File System.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Monitoring of LVM2 mirrors,…ng dmeventd or progress polling.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Found device /dev/ttyS0.
[ OK ] Found device /dev/disk/by-partlabel/devota-fs.
Starting File System Check on /dev/disk/by-partlabel/devota-fs…
[ OK ] Started File System Check Daemon to report status.
[ OK ] Started File System Check on /dev/disk/by-partlabel/devota-fs.
Mounting /driveota…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Mounted /driveota.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Local File Systems.
Starting Tell Plymouth To Write Out Runtime Data…
Starting Create Volatile Files and Directories…
Starting LSB: AppArmor initialization…
Starting Set console keymap…
Starting Clean up any mess left by 0dns-up…
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Set console keymap.
[ OK ] Started Clean up any mess left by 0dns-up.
[ OK ] Started LSB: AppArmor initialization.
Starting Raise network interfaces…
Starting Update UTMP about System Boot/Shutdown…
Starting Network Time Synchronization…
[ OK ] Started Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Started CUPS Scheduler.
[ OK ] Reached target Paths.
Starting Socket activation for snappy daemon.
[ OK ] Listening on GPS (Global Positioning System) Daemon Sockets.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Avahi mDNS/DNS-SD Stack…
Starting LSB: Speech Dispatcher…
Starting Board specific initialization…
Starting board specific init …
Starting Permit User Sessions…
[ OK ] Started tos_daemon_service assists … storage TA with FS operations…
[ OK ] Started mnand refresh daemon service.
Starting Accounts Service…
Starting System Logging Service…
[ OK ] Started Hypervisor initiated Shutdown Service.
[ OK ] Started crash report submission daemon.
[ OK ] Started Run anacron jobs.
Starting Modem Manager…
Starting Restore /etc/resolv.conf i…re the ppp link was shut down…
[ OK ] Started Regular background program processing daemon.
Starting LSB: Set the CPU Frequency Scaling governor to “ondemand”…
Starting LSB: automatic crash report generation…
Starting Login Service…
[ OK ] Started GPS (Global Positioning System) Daemon.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Make remote CUPS printers available locally.
[ INFO ] Network Manager is not active.
[DEPEND] Dependency failed for Network Manager Wait Online.
Starting oFono Mobile telephony stack…
Starting Network Service…
[ OK ] Started System Logging Service.
[ OK ] Started Permit User Sessions.
[ OK ] Started Restore /etc/resolv.conf if…fore the ppp link was shut down.
[ OK ] Started Network Service.
[ OK ] Started LSB: Speech Dispatcher.
[ OK ] Started oFono Mobile telephony stack.
[ OK ] Started Raise network interfaces.
[ OK ] Started LSB: Set the CPU Frequency Scaling governor to “ondemand”.
[ OK ] Started LSB: automatic crash report genera
