Nvdisasm fatal : Value 'SM75' is not defined for option 'binary'
I have a problem related to ‘cuobjdump’.
I want to disassemble the Cuda executable file to the SASS code.
I got Cuda executable file by this commend
nvcc -g -o test -arch=sm_75 -lcublas -lcurand test.cu
And type cuobjdump commend,
cuobjdump -sass test
Then, an error message is poped,
Fatbin elf code:
arch = sm_75
code version = [1,7]
producer =
host = linux
compile_size = 64bit
    code for sm_75
Fatbin elf code:
arch = sm_75
producer =
host = linux
    code for sm_75
            Function : _Z12BMMA_examplePjS_PiS0_
nvdisasm fatal : Value ‘SM75’ is not defined for option ‘binary’
My version of nvcc and cuobjdump is 10.1.105
cuobjdump: NVIDIA ® fat binary listing tool
Copyright © 2005-2019 NVIDIA Corporation
Built on Fri_Feb__8_19:08:17_PST_2019
Cuda compilation tools, release 10.1, V10.1.105
And this is path for cuda,
export PATH=/usr/local/cuda-10.1/bin:$PATH
export PATH="$PATH:/usr/local/cuda-8.0/bin"
export LD_LIBRARY_PATH=/usr/local/cuda-10.1/lib64:/lib64:$LD_LIBRARY_PATH
How can I fix it? help me…
