Hi
With a simple vector add program (only one kernel), I get the following error with nvdisasm
nvdisasm fatal : vec_add is not a supported Elf file
I tried the following build commands:
nvcc -o vec_add -arch=sm_86 -Xptxas -O3,-v vec_add.cu
nvcc -o vec_add -arch=sm_86 -g -G vec_add.cu
I have to say that cuobjdump vec_add -sass
works fine. Is there a way to see the output of nvdisasm
