I am currently working on the deployment of a qt application on jetsonTX2 (connect tech orbitty motherboard) with a graphical user interface.
I have installed l4t32.2.1 (ubuntu 18.04) on the TX2. My application start automatically at boot with a rc.local script. To achieve this I uninstall all the graphical environment such as lightdm and the desktop environment. Everything works in console mode.
Everything works well except that after 10 min the screen goes to sleep. I tried this command :
setterm -powerdown 0
but it does not change anything. I also tried to stop these services
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target suspend-then-hibernate.target
but it does not work either.
Here is the result of the dmesg command just after the screen goes to sleep and once it comes out to sleep.
[ 613.459925] tegradc 15210000.nvdisplay: blank - powerdown
[ 613.512005] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 613.512008] Extcon AUX1(HDMI) disable
[ 613.534349] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 613.534446] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 613.535276] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 630.476058] tegradc 15210000.nvdisplay: unblank
[ 630.476878] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 630.476970] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 630.477052] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 630.478364] Parent Clock set for DC plld2
[ 630.481267] tegradc 15210000.nvdisplay: hdmi: tmds rate:71000K prod-setting:prod_c_hdmi_54m_111m
[ 630.482498] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 630.482504] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 630.519005] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 630.519009] Extcon AUX1(HDMI) enable
[ 630.521507] tegradc 15210000.nvdisplay: unblank
I think there is something with nvdisplay but I don’t know how to configure this to stop the screen goes to sleep. Any help would be appreciated.
thanks.
