Nvdla failed to power on
Jetson AGX Xavier
Jetpack 4.2.3
TRT 5.1
I get this error in dmesg when attempts to YOLOv3 engine assembly.
[ 1670.748968] 15880000.nvdla0:nvhost_nvdla_finalize_poweron: Fw version of kernel [1.1.0] doesn’t match with actual version[0.12.10]
[ 1670.750795] 15880000.nvdla0:nvhost_nvdla_finalize_poweron: Fw version of kernel [1.1.0] doesn’t match with actual version[0.12.10]
[ 1670.752033] 15880000.nvdla0:nvhost_nvdla_finalize_poweron: Fw version of kernel [1.1.0] doesn’t match with actual version[0.12.10]
[ 1670.752050] nvdla 15880000.nvdla0: nvhost_module_finalize_poweron: failed to start the device
[ 1670.774277] nvdla 15880000.nvdla0: nvhost_module_busy: failed to power on, err -22
The error indicates some compatibility issue.
Did you launch the YOLOv3 engine that built on same environment?
Please noticed that TensorRT engine is not portable.
The engine file is quite sensitive to library version and deploy platform.
Yes engine going to in the same environment.
