I don’t have a A3000 GPU, but I have tried on many other GPUs. Cause I can’t reproduce the issue, so Could you help try to debug this? Try to set the userData.quality to 95. It will affect the quality of jpeg coding. Thanks
@syther666 , I have tried in Ampere architecture GPU, it still have no problem. So I think we can only rely on you and your own environment to debug this problem.
There are two methods I can think to try:
1.just change the source (sample_720.h264…)
2.You can refer the link below to get the data from NvBufSurface directly, and see if it’s the same issue. Then we’ll know whether it is the jpeg coding problem or the plugin processing problem. Thanks
