• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.1
• TensorRT Version
Using the following pipeline: streammux ! pgie ! nvtracker ! sgie ! nvdsanalytics ! tiler ! nvvidconv ! nvosd ! transform ! hlssink, the coordinates of the lines or ROI zones is set in the config_nvdsanalytics.txt. So the coordinates are read in the deepstream_nvdsanalytics_test.cpp → /* Configure the nvdsanalytics element for using the particular analytics config file*/
g_object_set (G_OBJECT (nvdsanalytics),
“config-file”, “config_nvdsanalytics.txt”,
NULL);
I want to be able to change the coordinates of the lines/ROI’ s “on the fly” without having to stop and start the pipeline. Is there a way in the main cpp code to override (some parts of) the configfile?
