[overcrowding-stream-0]
enable=1
roi-OC=295;643;579;634;642;913;56;828
#no of objects that will trigger OC
object-threshold=2
class-id=-1
how to get the property value of 'object-threshold ’
enable=1
object-threshold=2
class-id=-1
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) – GPU
• DeepStream Version – 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) CUDA 11.2
i have already implemented , can i get the value of the property to an variable ? Is there a way to check nvdsanalystics used values
Maybe you can add one plugin property to quire those value.
can you help me how add the plugin property ? and integrate
Sorry for later response. Suppose you can refer the implementation of other property or read those value from your configure file.
