NvDsFaceObject in DeepStream 4
I noticed this type, in the documentation ( https://docs.nvidia.com/metropolis/deepstream/dev-guide/DeepStream_Development_Guide/baggage/structNvDsFaceObject.html ).
Browsing the sources, it only seems to be used in sources/libs/nvmsgconv/nvmsgconv.cpp. Is there any way to get nvinfer to produce this?
If any moderators see this, perhaps you could move it to the DeepStream forum? I hadn’t previously noticed it:
https://devtalk.nvidia.com/default/board/209/deepstream-sdk/
Moved to DeepStream SDK.
nvinfer will not produce that structure. It is only used to communicate with IoT servers when message converter and broker is used
