• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version 7.1.3
We have a gst-launch-1.0 pipeline running with Deepstream plugins. We have a system out in the field with it running consistently for 20 days. Then it threw a core dump error and the gst pipeline stopped running. And we applied the following patch to build the lib_nvdsinfer.so.
The diagnostic is below:
Using host libthread_db library “/lib/aarch64-linux-gnu/libthread_db.so.1”.
Core was generated by `gst-launch-1.0 udpsrc do-timestamp=true port=6000 buffer-size=60000000 ! applic’.
Program terminated with signal SIGABRT, Aborted.
#0 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
51 ../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
[Current thread is 1 (Thread 0x7fae6e0a50 (LWP 7921))]
(gdb) bt
#0 0x0000007fae28e4d8 in __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
#1 0x0000007fae28f8b4 in __GI_abort () at abort.c:79
#2 0x0000007fad11610c in __gnu_cxx::__verbose_terminate_handler() () at /usr/lib/aarch64-linux-gnu/libstdc++.so.6
#3 0x0000007fad113c54 in () at /usr/lib/aarch64-linux-gnu/libstdc++.so.6
#4 0x0000007fad112b5c in () at /usr/lib/aarch64-linux-gnu/libstdc++.so.6
#5 0x0000007fad113340 in __gxx_personality_v0 () at /usr/lib/aarch64-linux-gnu/libstdc++.so.6
#6 0x0000007fad06c9b4 in () at /lib/aarch64-linux-gnu/libgcc_s.so.1
#7 0x0000007fad06cf6c in _Unwind_Resume () at /lib/aarch64-linux-gnu/libgcc_s.so.1
#8 0x0000007f831978d0 in nvinfer1::throwNvmError(char const*, char const*, int, int, char const*) () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#9 0x0000007f8317b3bc in () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#10 0x0000007f83193728 in nvinfer1::trtCudaFree(nvinfer1::IGpuAllocator*, void*, char const*, char const*, int) () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#11 0x0000007f8316ca60 in nvinfer1::rt::SafeExecutionContext::~SafeExecutionContext() () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#12 0x0000007f82eecaa4 in nvinfer1::rt::ExecutionContext::~ExecutionContext() () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#13 0x0000007f82eecb94 in nvinfer1::rt::ExecutionContext::~ExecutionContext() () at /usr/lib/aarch64-linux-gnu/libnvinfer.so.7
#14 0x0000007fa3016358 in nvdsinfer::UniquePtrWDestroy<nvinfer1::IExecutionContext>::UniquePtrWDestroy(nvinfer1::IExecutionContext*)::{lambda(nvinfer1::IExecutionContext*)#1}::operator()(nvinfer1::IExecutionContext*) const ()
at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#15 0x0000007fa301637c in nvdsinfer::UniquePtrWDestroy<nvinfer1::IExecutionContext>::UniquePtrWDestroy(nvinfer1::IExecutionContext*)::{lambda(nvinfer1::IExecutionContext*)#1}::_FUN(nvinfer1::IExecutionContext*) ()
#16 0x0000007fa3016280 in std::unique_ptr<nvinfer1::IExecutionContext, void (*)(nvinfer1::IExecutionContext*)>::reset(nvinfer1::IExecutionContext*) () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#17 0x0000007fa30141c4 in nvdsinfer::TrtBackendContext::~TrtBackendContext() () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#18 0x0000007fa301615c in nvdsinfer::FullDimTrtBackendContext::~FullDimTrtBackendContext() () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#19 0x0000007fa301617c in nvdsinfer::FullDimTrtBackendContext::~FullDimTrtBackendContext() () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#20 0x0000007fa2fcbca0 in std::default_delete<nvdsinfer::BackendContext>::operator()(nvdsinfer::BackendContext*) const () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#21 0x0000007fa2fc763c in std::unique_ptr<nvdsinfer::BackendContext, std::default_delete<nvdsinfer::BackendContext> >::reset(nvdsinfer::BackendContext*) () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#22 0x0000007fa2fbbb90 in nvdsinfer::NvDsInferContextImpl::~NvDsInferContextImpl() () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#23 0x0000007fa2fbc01c in nvdsinfer::NvDsInferContextImpl::~NvDsInferContextImpl() () at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infer.so
#24 0x0000007fa30bead0 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so
#25 0x0000007fa30b6040 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so
#26 0x0000007faddb739c in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#27 0x0000005588e44460 in ()
(gdb)
