• Hardware Platform (Jetson / GPU) GPU • DeepStream Version Docker 6.3 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
When I run the command ./apps/deepstream-parallel-infer/deepstream-parallel-infer -c configs/apps/bodypose_yolo_lpr/source4_1080p_dec_parallel_infer.yml with the repo deepstream_parallel_inference_app, I met the error:
DeepStream doesn’t support this display mode. If you want to display video, you need a monitor device on the host. Then you can display the video remotely through NoMachine or other similar software.
Thanks for your reply, I had solved this probleam. And I want to modify the deepstream-app.cpp, where can I find it? /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app?
Yes. And you can also find some source code in the opt\nvidia\deepstream\deepstream\sources\apps\apps-common path. If you have any other issues, you can file a new topic.
