NvDsObjectMeta object_id is giving different output
• RTX3050
• Detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hi, I am currently developing an LPR app using python. I would like to obtain the object detection ID from trafficcamnet and match it with the license plate it detected.
However, I have try using obj_meta.object_id from NvDsObjectMeta, it outputs a random number for each car plate it detect. Below is the code:
while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
            except StopIteration:
                break
            if args[3] == '0':
                #no ROI
                l_class = obj_meta.classifier_meta_list
                while l_class is not None:
                    try:
                        class_meta = pyds.NvDsClassifierMeta.cast(l_class.data)
                        break
                    print(obj_meta.object_id)
                    l_label = class_meta.label_info_list
Output:
18446744073709551615
If i change the location of printing the object_id (before looping it into l_class) , it works fine as it outputs the object id from trafficcamnet.
            try:
                break
            if args[3] == '0':
                #no ROI
                    try:
                        break
Output:
4
3
1
2
0
4
3
1
2
0
4
3
1
2
0
Besides, any idea of what 18446744073709551615 means?
Moving to DeepStream forum.
@yingliu thanks
Could you attach your whole pipeline and where the probe function is added?
I am using this repo GitHub - preronamajumder/deepstream-lpr-python-version: Python version for NVIDIA Deepstream's LPR. https://developer.nvidia.com/blog/creating-a-real-time-license-plate-detection-and-recognition-app/
print(obj_meta.object_id) is added to line111 and line125, resulting in different output
This value is actually -1 for 64-bit data. It is possible that python binding is causing this data exception. You can address this issue directly to the project owner in the github.
I see. But in the results, even i print on line 111 still resulting -1 and the actual object ID. Any idea on why the object ID is not printed out on line125, but only -1
Maybe there are some problems with some of your configurations of nvtracker. I have tried to print the object_id in our demo code deepstream_test_2.py#L79, it works normally. You can refer to our demo code and modify your project code.
