GPU
• DeepStream Version
7.0
• TensorRT Version
8.6
550.107.02
bugs
Previously, I mentioned that the parent
variable in the NvDsObjectMeta
class was being set to None
when adding a non-NVIDIA GStreamer component, as referenced in this post:
However, after running some tests, I noticed that the component actually responsible for setting NvDsObjectMeta.parent
to None
is Gst-nvvideoconvert
What’s interesting is that all other metadata remains intact, but specifically, NvDsObjectMeta.parent
is set to None
after the metadata passes through Gst-nvvideoconvert
Could someone explain why only the parent
field is affected and whether there’s a workaround for this behavior?
