Nvdsosd is not drawing bounding boxes
• Jetson
• Deepstream 7.1
• Jetpack 6.2.1
• TensorRT 10.3
• Type: Bug
I am running a deepstream pipeline with an IP camera. But there is some issue with the nvdsosd element. It was producing some kind of artifacts between frames and after some times it would stop drawing completely. I was using nvurisrc element in my program when this happened. For debugging I used two gst-launch templates.
nvurisrcbin
gst-launch-1.0 nvurisrcbin uri='rtsp://192.168.0.183:554/cam/realmonitor?channel=1&subtype=0' latency=200 ! m.sink_0 nvstreammux name=m width=3840 height=2160 batch-size=1 live-source=1 ! nvinfer unique-id=1 config-file-path=config/config_infer_scrfd.txt ! nvdsosd ! nveglglessink sync=true
rtspsrc
gst-launch-1.0 rtspsrc location=‘rtsp://192.168.0.183:554/cam/realmonitor?channel=1&subtype=0’ latency=200 ! rtph265depay ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 live-source=1 width=3840 height=2160 ! nvinfer unique-id=1 config-file-path=config/config_infer_scrfd.txt ! nvdsosd ! nveglglessink sync=true
I am also using a custom parse function to debug this.
extern "C"
bool NvDsInferParseDummyObjects(
    std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
    NvDsInferNetworkInfo const &networkInfo,
    NvDsInferParseDetectionParams const &detectionParams,
    std::vector<NvDsInferObjectDetectionInfo> &objectList) {
    constexpr NvDsInferObjectDetectionInfo object{
        .classId = 1,
        .left = 100,
        .top = 100,
        .width = 30,
        .height = 30,
        .detectionConfidence = 0.4,
    objectList.push_back(object);
    std::printf("Object pushed\n");
    return true;
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseDummyObjects)
no bounding boxes are appearing on the frame with these gst-launch templates.
My nvinfer configuration
[property]
gpu-id=0
net-scale-factor=1.0
offsets=127.5;127.5;127.5
model-color-format=0
process-mode=1
labelfile-path=../models/scrfd-labels.txt
batch-size=1
network-mode=2  # 0=FP32, 1=INT8, 2=FP16
onnx-file=../models/scrfd_2.5g_kps.onnx
model-engine-file=../models/scrfd_2.5g_kps.engine
num-detected-classes=1
network-type=0
parse-bbox-func-name=NvDsInferParseDummyObjects
custom-lib-path=../lib/libnvds_infer_custom_scrfd.so
output-blob-names=score_8;score_16;score_32;bbox_8;bbox_16;bbox_32;kps_8;kps_16;kps_32
force-implicit-batch-dim=1
cluster-mode=4
output-tensor-meta=1
This isn’t an issue with nvosd; your nvinfer post-processing and configuration files have several errors. Please try the following code and configuration file.
# SCRFD Face Detection Model Configuration for DeepStream nvinfer
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
# ONNX model path
onnx-file=../scrfd.onnx
model-engine-file=../scrfd.onnx_b1_gpu0_fp16.engine
# Input dimensions
batch-size=1
network-mode=2
# Supported network modes:
# 0 - FP32
# 1 - INT8
# 2 - FP16
# Network input shape
infer-dims=3;640;640
maintain-aspect-ratio=0
network-type=3
# Custom instance mask parser (for face detection with keypoints)
parse-bbox-instance-mask-func-name=NvDsInferParseCustomSCRFD
custom-lib-path=libnvdsinfer_custom_impl_scrfd.so
# Number of classes (face detection has 1 class)
output-instance-mask=1
interval=0
gie-unique-id=1
process-mode=1
# 1 - Primary GIE, 2 - Secondary GIE
# Clustering and grouping
cluster-mode=4
# 0 - OpenCV groupRectangles
# 1 - DBSCAN
# 2 - NMS (non-maximum suppression)
# 3 - DBSCAN + NMS hybrid
# 4 - No clustering
# Network input configuration
# Model expects RGB input
# 0 - RGB
# 1 - BGR
# 2 - GRAY
# Performance tuning
# Increase for better throughput on high-resolution streams
network-input-order=0
# 0 - NCHW
# 1 - NHWC (Tensor RT prefers NCHW for conv layers)
[class-attrs-all]
pre-cluster-threshold=0.25
 * DeepStream NvInfer Custom Parser for SCRFD Face Detection Model
 * Model Outputs:
 *   - score_8, score_16, score_32: [batch, num_anchors, 1] - face classification scores (sigmoid)
 *   - bbox_8, bbox_16, bbox_32: [batch, num_anchors, 4] - distance predictions (left, top, right,
 * bottom)
 *   - kps_8, kps_16, kps_32: [batch, num_anchors, 10] - keypoint offsets (dx, dy) * 5
 * Strides: 8, 16, 32
 * Anchors per location: 2
#include <algorithm>
#include <cmath>
#include <cstring>
#include <iostream>
#include <vector>
#include "nvdsinfer_custom_impl.h"
#define MIN(a, b) ((a) < (b) ? (a) : (b))
#define MAX(a, b) ((a) > (b) ? (a) : (b))
#define CLIP(a, min, max) (MAX(MIN(a, max), min))
static const int kNumAnchorsPerLocation = 2;
static const int kNumKeypoints = 5;
static const int kNumKeypointsCoords = kNumKeypoints * 2;  // 10 coordinates
struct FaceDetectionParams {
  float scoreThreshold = 0.5f;
  float nmsThreshold = 0.45f;
  int inputWidth = 640;
  int inputHeight = 640;
struct AnchorGenerator {
  int stride;
  int width;
  int height;
  void generateAnchors(std::vector<std::pair<float, float>>& anchors) const {
    anchors.clear();
    int fmapW = width / stride;
    int fmapH = height / stride;
    // Generate anchor centers: matches official np.mgrid[:height, :width][::-1]
    // This creates grid points at integer positions: [0, 1, 2, ..., H-1]
    for (int i = 0; i < fmapH; i++) {
      for (int j = 0; j < fmapW; j++) {
        for (int k = 0; k < kNumAnchorsPerLocation; k++) {
          // Official: anchor_centers = (anchor_centers * stride)
          // No +0.5 offset - use corner-based grid
          float cx = j * stride;
          float cy = i * stride;
          anchors.push_back({cx, cy});
static float calculateIoU(const NvDsInferInstanceMaskInfo& a, const NvDsInferInstanceMaskInfo& b) {
  float areaA = a.width * a.height;
  float areaB = b.width * b.height;
  float interX1 = MAX(a.left, b.left);
  float interY1 = MAX(a.top, b.top);
  float interX2 = MIN(a.left + a.width, b.left + b.width);
  float interY2 = MIN(a.top + a.height, b.top + b.height);
  float interW = MAX(0.0f, interX2 - interX1);
  float interH = MAX(0.0f, interY2 - interY1);
  float interArea = interW * interH;
  float unionArea = areaA + areaB - interArea;
  return (unionArea > 0) ? (interArea / unionArea) : 0.0f;
static void nmsSort(std::vector<NvDsInferInstanceMaskInfo>& detections, float nmsThreshold) {
  std::stable_sort(detections.begin(), detections.end(),
                   [](const NvDsInferInstanceMaskInfo& a, const NvDsInferInstanceMaskInfo& b) {
                     return a.detectionConfidence > b.detectionConfidence;
  std::vector<bool> suppressed(detections.size(), false);
  for (size_t i = 0; i < detections.size(); i++) {
    if (suppressed[i]) continue;
    for (size_t j = i + 1; j < detections.size(); j++) {
      if (suppressed[j]) continue;
      float iou = calculateIoU(detections[i], detections[j]);
      // printf("nmsThreshold %f, IoU between box %zu and box %zu: %f\n", nmsThreshold,  i, j, iou);
      if (iou > nmsThreshold) {
        suppressed[j] = true;
  std::vector<NvDsInferInstanceMaskInfo> filtered;
    if (!suppressed[i]) {
      filtered.push_back(detections[i]);
    } else {
      // Free allocated mask memory for suppressed detections
      if (detections[i].mask != nullptr) {
        delete[] detections[i].mask;
  detections = std::move(filtered);
static void decodeBBoxes(const float* scores, const float* bboxes, const float* keypoints,
                         const std::vector<std::pair<float, float>>& anchors, int stride,
                         const FaceDetectionParams& params,
                         std::vector<NvDsInferInstanceMaskInfo>& results) {
  for (size_t i = 0; i < anchors.size(); i++) {
    float score = scores[i];
    if (score < params.scoreThreshold) {
      continue;
    float cx = anchors[i].first;
    float cy = anchors[i].second;
    // Decode bounding box using distance2bbox
    // Official: bbox_preds = bbox_preds * stride (done in inference)
    // bbox format: [left, top, right, bottom] distances from anchor center
    float left = bboxes[i * 4 + 0] * stride;
    float top = bboxes[i * 4 + 1] * stride;
    float right = bboxes[i * 4 + 2] * stride;
    float bottom = bboxes[i * 4 + 3] * stride;
    // distance2bbox: x1 = cx - left, y1 = cy - top, x2 = cx + right, y2 = cy + bottom
    float x1 = cx - left;
    float y1 = cy - top;
    float x2 = cx + right;
    float y2 = cy + bottom;
    // Clip to image bounds
    x1 = CLIP(x1, 0.0f, (float)params.inputWidth);
    y1 = CLIP(y1, 0.0f, (float)params.inputHeight);
    x2 = CLIP(x2, 0.0f, (float)params.inputWidth);
    y2 = CLIP(y2, 0.0f, (float)params.inputHeight);
    NvDsInferInstanceMaskInfo det;
    det.classId = 0;  // face class
    det.left = x1;
    det.top = y1;
    det.width = CLIP(x2 - x1, 0.0f, (float)params.inputWidth);
    det.height = CLIP(y2 - y1, 0.0f, (float)params.inputHeight);
    det.detectionConfidence = score;
    // Skip invalid detections
    if (det.width < 1.0f || det.height < 1.0f) {
      continue;
    // Store keypoints in mask field
    // Format: [x1, y1, conf1, x2, y2, conf2, ..., x5, y5, conf5] = 15 floats
    const size_t kKeypointMaskSize = kNumKeypoints * 3;  // 5 keypoints * (x, y, confidence)
    det.mask = new float[kKeypointMaskSize];
    det.mask_size = kKeypointMaskSize * sizeof(float);
    det.mask_width = kNumKeypoints;  // 5 keypoints
    det.mask_height = 3;             // x, y, confidence per keypoint
    // Decode keypoints using distance2kps
    // Official: kps_preds = kps_preds * stride (done in inference)
    // kps format: [dx1, dy1, dx2, dy2, ..., dx5, dy5] offsets from anchor
    for (int k = 0; k < kNumKeypoints; k++) {
      float dx = keypoints[i * kNumKeypointsCoords + k * 2] * stride;
      float dy = keypoints[i * kNumKeypointsCoords + k * 2 + 1] * stride;
      // distance2kps: px = cx + dx, py = cy + dy
      float kp_x = cx + dx;
      float kp_y = cy + dy;
      det.mask[k * 3 + 0] = CLIP(kp_x, 0.0f, (float)params.inputWidth);
      det.mask[k * 3 + 1] = CLIP(kp_y, 0.0f, (float)params.inputHeight);
      det.mask[k * 3 + 2] = 1.0f;  // Confidence (always 1.0 for SCRFD)
    results.push_back(det);
/* Custom parser for SCRFD face detection model.
 * Uses NvDsInferInstanceMaskInfo to store facial keypoints in the mask field.
extern "C" bool NvDsInferParseCustomSCRFD(std::vector<NvDsInferLayerInfo> const& outputLayersInfo,
                                          NvDsInferNetworkInfo const& networkInfo,
                                          NvDsInferParseDetectionParams const& detectionParams,
                                          std::vector<NvDsInferInstanceMaskInfo>& objectList) {
  static FaceDetectionParams params;
  params.scoreThreshold = detectionParams.perClassThreshold[0];
  params.nmsThreshold = detectionParams.perClassThreshold[0];  // Can be customized
  params.inputWidth = networkInfo.width;
  params.inputHeight = networkInfo.height;
  // Expected 9 outputs: score_8, score_16, score_32, bbox_8, bbox_16, bbox_32, kps_8, kps_16,
  // kps_32
  if (outputLayersInfo.size() != 9) {
    std::cerr << "ERROR: Expected 9 output layers for SCRFD model, got " << outputLayersInfo.size()
              << std::endl;
    return false;
  // Map output layers by name
  const float* score_8 = nullptr;
  const float* score_16 = nullptr;
  const float* score_32 = nullptr;
  const float* bbox_8 = nullptr;
  const float* bbox_16 = nullptr;
  const float* bbox_32 = nullptr;
  const float* kps_8 = nullptr;
  const float* kps_16 = nullptr;
  const float* kps_32 = nullptr;
  for (const auto& layer : outputLayersInfo) {
    const char* layerName = layer.layerName;
    if (strcmp(layerName, "score_8") == 0) {
      score_8 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "score_16") == 0) {
      score_16 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "score_32") == 0) {
      score_32 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "bbox_8") == 0) {
      bbox_8 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "bbox_16") == 0) {
      bbox_16 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "bbox_32") == 0) {
      bbox_32 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "kps_8") == 0) {
      kps_8 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "kps_16") == 0) {
      kps_16 = static_cast<const float*>(layer.buffer);
    } else if (strcmp(layerName, "kps_32") == 0) {
      kps_32 = static_cast<const float*>(layer.buffer);
  // Verify all outputs are found
  if (!score_8 || !score_16 || !score_32 || !bbox_8 || !bbox_16 || !bbox_32 || !kps_8 || !kps_16 ||
      !kps_32) {
    std::cerr << "ERROR: Failed to find all required output layers" << std::endl;
    return false;
  std::vector<NvDsInferInstanceMaskInfo> allDetections;
  // Process stride 8
    AnchorGenerator anchorGen;
    anchorGen.stride = 8;
    anchorGen.width = params.inputWidth;
    anchorGen.height = params.inputHeight;
    std::vector<std::pair<float, float>> anchors;
    anchorGen.generateAnchors(anchors);
    decodeBBoxes(score_8, bbox_8, kps_8, anchors, 8, params, allDetections);
  // Process stride 16
    anchorGen.stride = 16;
    decodeBBoxes(score_16, bbox_16, kps_16, anchors, 16, params, allDetections);
  // Process stride 32
    anchorGen.stride = 32;
    decodeBBoxes(score_32, bbox_32, kps_32, anchors, 32, params, allDetections);
  // Apply NMS
  nmsSort(allDetections, params.nmsThreshold);
  // Move results to output list
  objectList.clear();
  objectList = std::move(allDetections);
  return true;
/* Check that the custom function has been defined correctly */
CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomSCRFD);
Then execute this command line. i have tried it, It works fine.
gst-launch-1.0 nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov ! m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=1 ! nvinfer config-file-path=config_infer_primary_scrfd.txt ! nvdsosd  ! nvvideoencfilesinkbin output-file=out.mp4
This post-processing library stores landmarks in NvDsInferInstanceMaskInfo. To display these landmarks, a probe function needs to be added to the nvinfer source pad, similar to this link:
It worked. Thanks for your help. But the issue with the bounding box bleeding is still there when tried with a rtsp source.
This issue is caused by network jitter, not a problem with DeepStream. Please try increasing latency and using TCP: nvurisrcbin latency=5000 select-rtp-protocol=4
This did not work.
However I followed this thread
RTSP nvdsosd causes bleeding artifacts?
Then saw that his problem went away when he tried the IP camera video format to h264 from h265H. I also did the same on my Lorex IP camera. Changed the encoding strategy to normal as well.
Note: The issue persists when I use the super encoding strategy on the camera.
Can we conclude that this a NVIDIA decoder problem?
This could also be due to the RTSP camera using H.265H encoding and outputting a non-standard H.265 bitstream. Please use the command below to dump the bitstream; I’ll try to analyze it locally. Also, what is the brand and model of this RTSP camera?
gst-launch-1.0 rtspsrc location=rtsp://xxx protocols=4 ! queue ! parsebin ! queue ! h265parse ! mpegtsmux ! filesink location=rtsp.ts
And what is the SDP output of this command line ?
{ printf 'DESCRIBE rtsp://xxxx/media/video1 RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: nc\r\nAccept: application/sdp\r\n\r\n'; } \
| timeout 5 nc -w 5 RTSP_IP_XXX 554 \
| awk 'BEGIN{body=0} {sub(/\r$/,""); if(body) print; else if($0=="") body=1}' \
| awk 'BEGIN{s=0} /^v=0/{s=1} s{print}'
I dumped the H265 streams with two encoding strategies available on the camera.
Normal encoding
h265-normal-encoding-rtsp.zip (5.8 MB)
Super encoding
h265-super-encoding-rtsp.zip (2.6 MB)
The IP camera is a Lorex LNB9393. They are rebranding Dahua IP cameras.
The SDP outputs nothing. The command just exists after some time.
Whatever I play the h265-normal-encoding-rtsp.ts or h265-super-encoding-rtsp.ts with nvv4l2decoder, It is normal,
so I think this issue is not related hardware decoder.
You can try this command.
gst-launch-1.0 -v filesrc location=h265-normal-encoding-rtsp.ts/h265-super-encoding-rtsp.ts ! tsdemux name=d   d. ! queue ! h265parse ! video/x-h265,stream-format=byte-stream,alignment=au !   nvv4l2decoder ! nv3dsink
If you play rtsp stream directly, these any bleeding artifacts in screen ?
gst-launch-1.0 rtspsrc location=rtsp://xxx protocols=4 ! queue ! parsebin ! queue ! h264parse ! nvv4l2decoder ! nv3dsink
If playing RTSP directly can also cause overflow artifacts. I believe the problem is that the SDP described by the camera is not standard content.
 { printf 'DESCRIBE rtsp://xxxx RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: nc\r\nAccept: application/sdp\r\n\r\n'; } | timeout 5 nc -w 5 ip port
There are no artifacts if I just played the stream directly from the camera. The issue only happens when nvdsosd comes in. Only the bounding boxes are bleeding even then. That is why my first thought was this is an issue with nvdsosd.
I think the SDP output did not came because RTSP authentication problem. I gave the username and password like this but the response is coming as 401.
{ printf 'DESCRIBE rtsp://admin:password@192.168.0.183:554/cam/realmonitor?channel=1&subtype=0 RTSP/1.0\r\nCSeq: 1\r\nUser-Agent: nc\r\nAccept: application/sdp\r\n\r\n'; } | nc 192.168.0.183 554 -w 5
RTSP/1.0 401 Unauthorized
CSeq: 1
WWW-Authenticate: Digest realm="Login to ND012309019307", nonce="2433ffe82606a763911f3a1e49a85118"
I tried using ffprobe to get the stream information as well. Here is the output of that.
ffprobe -protocol_whitelist file,udp,rtp,rtsp,tcp -i 'rtsp://admin:password@192.168.0.183:554/cam/realmonitor?channel=1&subtype=0'
ffprobe version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2007-2021 the FFmpeg developers
  built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
  configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 70.100 / 56. 70.100
  libavcodec     58.134.100 / 58.134.100
  libavformat    58. 76.100 / 58. 76.100
  libavdevice    58. 13.100 / 58. 13.100
  libavfilter     7.110.100 /  7.110.100
  libswscale      5.  9.100 /  5.  9.100
  libswresample   3.  9.100 /  3.  9.100
  libpostproc    55.  9.100 / 55.  9.100
Input #0, rtsp, from 'rtsp://admin:password@192.168.0.183:554/cam/realmonitor?channel=1&subtype=0':
  Metadata:
    title           : Media Server
  Duration: N/A, start: 0.080000, bitrate: N/A
  Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt470bg/bt470bg/smpte170m), 3840x2160, 25 fps, 25 tbr, 90k tbn, 25 tbc
If the bounding box is drawn using the CPU mode of nvdsosd, will the overflow artifacts disappeard?
nvdsosd process-mode =0
Yes. The bleeding disappeared now after setting nvsosd to cpu mode.
This issue is related to the rtsp stream. Besides setting nvdsosd to CPU mode, there’s a workaround: add an nvvideoconvert for copy buffer before entering nvstreammux
nvurisrcbin uri=xxxx  ! nvvideoconvert disable-passthrough=true  !  nvstreammux  !  .....
